wice 0 Posted August 23, 2011 Report Share Posted August 23, 2011 sta je potrebno za ugradnju tempomata? i koliko je komplikovano za dva auta e36 318i m40 i e46 320d hvala Link to post Share on other sites
zYx 0 Posted August 23, 2011 Report Share Posted August 23, 2011 Za e46 ako ima drive-by-wire komandu gasa, samo volan sa komandama (ili samo komande) i prevezivanje instalacije (link je za 318ci): http://forum.e46fanatics.com/showthread.php?t=544160 Link to post Share on other sites
wice 0 Posted August 23, 2011 Author Report Share Posted August 23, 2011 pa mislim da ima to je e46 320d 2001 godiste Link to post Share on other sites
StunterSM 0 Posted August 23, 2011 Report Share Posted August 23, 2011 Nema sanse da se ugradi, zeljko kad je prebacivao motor nije mogao da ugradi na motor koji to nema iako su oba bila 2.5 Link to post Share on other sites
zYx 0 Posted August 23, 2011 Report Share Posted August 23, 2011 pa mislim da ima to je e46 320d 2001 godiste Uh, propustih da je dizel... Ne znam kako ide kod njih :sorry: Link to post Share on other sites
325ixA 0 Posted August 23, 2011 Report Share Posted August 23, 2011 e36 http://www.scarolas.com/98e36m3/BMW%20E36%20Cruise%20Control%20Upgrade%20-%20DIY_v.2.pdf Link to post Share on other sites
zYx 0 Posted August 23, 2011 Report Share Posted August 23, 2011 http://www.kneb.net/bmw/E46/Multifunction%20steering%20wheel%20and%20cruise%20retrofit.pdf Vidi ovde da li moze retrofit na M47 ili M47TU (ne znam koji imas, posto je 2001 prelazna godina). Link to post Share on other sites
djole318 0 Posted August 23, 2011 Report Share Posted August 23, 2011 Pogledaj malo po googl - u ima nekih univezalnih, moze i to da zavrsio poso. Link to post Share on other sites
wice 0 Posted August 15, 2012 Author Report Share Posted August 15, 2012 da li se moze ugraditi na e46 karavan M43/TU 87kw. menjali smo auto Link to post Share on other sites
777.boban 0 Posted August 16, 2012 Report Share Posted August 16, 2012 MOze na svaki auto da se ugradi tempomat. Ja sam neki dan skinuo sa e36 318 m40 tempomat koji je naknadno ugradjen u auto,nikakva filozofija,ispod haube ide samo jedan dzek na zatezac sajle,u kabini na senzor kod volana,na papucicama,tasteri,i napajanje. Link to post Share on other sites
wice 0 Posted August 16, 2012 Author Report Share Posted August 16, 2012 da li je to neki univerzalni?koliko para? ja kada sam hteo fabricki kod mene rekli su mi da nema izvod za tempomat na kompu i da ne moze Link to post Share on other sites
777.boban 0 Posted August 16, 2012 Report Share Posted August 16, 2012 da li je to neki univerzalni?koliko para? ja kada sam hteo fabricki kod mene rekli su mi da nema izvod za tempomat na kompu i da ne moze Da univerzalni je,on ima svoj "komp". Nije na prodaju. Link to post Share on other sites
wice 0 Posted August 16, 2012 Author Report Share Posted August 16, 2012 hvala Link to post Share on other sites
Zeljkamp 0 Posted August 16, 2012 Report Share Posted August 16, 2012 Ja sam danas kod Bate u servisu montirao MF komande. Sve radi savrseno. :dance3: Link to post Share on other sites
pravda91 0 Posted August 17, 2012 Report Share Posted August 17, 2012 ortak je na GP 1.4 8v ugradio tempomat,mogu da ti dam njegov broj pa da vidis s njim sta i kako :) Link to post Share on other sites
wice 0 Posted August 17, 2012 Author Report Share Posted August 17, 2012 ili kada stignes samo pitaj gde je kupio kit i po kojoj ceni.hvala Link to post Share on other sites
Igyshava 0 Posted June 29, 2017 Report Share Posted June 29, 2017 Pozdrav, vidim da se radilo o tempomatu. Hteo bih da ugradim tempomat na e91 320d 110kw 2007.godiste. da li zna neko da li moze i kako? na e91 je tempomat na rucici kao npr. brisaci, zmigavci nije na volanu kao na e46. Link to post Share on other sites
Igyshava 0 Posted June 29, 2017 Report Share Posted June 29, 2017 gledao sam na yt, ali nista konkretno nisam nasao za e90/e91. Link to post Share on other sites
Igyshava 0 Posted August 20, 2017 Report Share Posted August 20, 2017 Hvala na iscrpnim odgovorima... Link to post Share on other sites
