Dire
E24 / modeli, karakteristike
4 posts in this topic
BMW E24 Coupe
Model: Engine: Power: Topspeed: Year:
628CSi M30 6 cylinder 184 HP 212 km/h 1979 - 1986
630CS M30 6 cylinder 185 HP 210 km/h 1976 - 1979
633CSi M30 6 cylinder 200 HP 215 km/h 1976 - 1982
635CSi M30 6 cylinder 218 HP 229 km/h 1978 - 1990
E24 – kratak istorijat legendarne “Ajkule”
U ranim sedamdesetima celnistvo BMW-a je odlucilo da vrlo uspjesna tradicija BMW coupe-a 1968-1975 treba dostojnog nasljednika..
2000 C/CS i 3.0-3.5 CS/CSi/CSL coupei su trebali otici u mirovinu
predajuci tron novom modelu..
Uprava je odlucila da "The next generation" coupe treba imati 6-cilindricni motor, high-tec obiljezja tog vremena, luksuznost i nezamjenjiv identitet, te cvrstocu sasije koja ce odgovarati tada uvedenim rigoroznim crash testovima.
I tako je 1975g na sasiji BMW-a E12 nastala prva "Ajkula"- BMW 630CS (M30_185KS) i 633 CSi (M30_200KS)
630CS motor• Six cylinder SOHC, 30° slant installation
• Bore 89mm, stroke 80mm
• Solex 4A1 carburator
• 184bhp @ 5800rpm
• 188lb.ft @ 3500rpm
• 0-62mph 8.9 seconds
• ¼ mile drag in 16.3 seconds
• Top speed 130.4mph
633CSi motor
• Bore 89mm, stroke 86mm
• Bosch L-Jetronic fuel injection
• 200bhp @ 5500rpm
• 290Nm @ 4300rpm
• 0-62mph in 7.9 seconds
• ¼ mile drag in 15.8 seconds
• Top speed 133.5mph
Inicijalno su se proizvodili u pogonu Karmann, a slagali u BMW-u (75-77.) a nakon toga je kompletan pogon preseljen u Minhen.
Primjerak Karmann BMW 630C
BMW-ov BMW 630CS/633CSi
Sideview -77.
Prednji branik sa spoilerom
Straznji branik
Unutrasnjost
Kompletan cockpit usmjeren prema vozacu;-)
Check control 1975g ;-)
• Engine oil level
• Brake fluid level
• Brake lights
• Brake pad wear indicator
• Cooling water level
• Screen washer level
• Tail lights
E12 ovjes na prvim 6erima 75-81.
• MacPherson strut
• ZF variable assistance steering gear
• 280mm (11 inch) ventilated front disc brakes
• 272mm (10.7 inch) ventilated rear disc brakes
• 3.45:1 (630 CS) or 3.25:1 (633 CSi) final drive ratio
Prvi modeli 630CS do 75-78. su imali 4 brzinske getribe ili 3-brzinske automatike i 4u1 Solex fergazer :shock: zanimljive potrosnje 8)
1978 se prestaju ugradivati fergazeri, uveden je computer management system DME, 5-brzinske Getrag-ove getribe, ABS postaje opcija,
te su uvedena 2 nova modela: "ekonomicni" 628CSi (184KS) i top model 635CSi (218KS).
630CS se prestaje proizvoditi.
1978. BMW 635CSi
Motor
• Bore 93.4mm, stroke 84mm
• Compression ratio 9.3:1
• 218bhp @ 5200rpm
• 224 lb.ft @ 4000rpm (191 lb.ft between 2000-5900rpm)
• 0-62mph in 7.3 seconds !! ;-)
• Top speed 140mph
1981. novi zadnji branik
1982“Godina velikih promjena”
6er dobiva novu sasiju koja je laksa i cvrsca od prethodne,
vizualne promjene vidljive na prednjem i zadnjem veznom limu te branicima.
Podvozje je sada od E28 (auto postaje znatno stabilniji).
Computer management system DME2 (Bosch Motronic) sa senzorima ocitanja “polozaja motora” na getribi.
BMW 635CSi dobiva novi motor
• Bore 92mm, stroke 86mm
• 218bhp @ 5200rpm
• 290Nm @ 4300rpm
• 0-62mph in 7.4 seconds
• Top speed 229 Km/h
ABS je serijska oprema.
Promjenjena unutrasnjost (cockpit, stranice, sredisnja armatura,mehanizmi otvaranja vrata)
Check service indikacija
On Board computer
Check control display
1983. se prestaje proizvoditi 633CSi
Uvedena 4-brzinska automatska getriba.
1984 M635 CSi
Doticni zasluzuje posebni thread pa ce tako i biti ;-)
Poboljsani prednji farovi.
Automatik getribe dobivaju elektronsko-hidraulicko upravljanje.
1986 Shadow line kao opcija
Klima na zadnjim sjedalima i “frizider” izmedju sjedala kao opcija
Novi straznji spoiler –plasticno gumeni.
1987. novi prednji i zadnji branici sa amortizerima protiv udaraca.
Prestaje proizvodnja 628CSi.
Computer management DME3
Novi prednji farovi – “lece”
1989 u Travnju proizvedena zadnja “Ajkula” ili 86.216-ti primjerak :
Zanimljivosti:
BMW650CSi (koristen za testiranje mehanike za 850)
info: www.bmwclub.com.hr
Moj komšo vozi E24. Drugačiji je zvuk motora nego kod moje E34. Prilično fino uradjen auto za taj period mada hvataju ga godine, sredjuje on njega svako malo ali godine čine svoje.. neće ga prodati to je definitivno a kad bude imao novca planira ga poslati na restauraciju
Мене интересује да ли конкретно овај модел може да се увезе и оцарини као олдтајмер, с обзиром да је почетак производње 1976. Актуелни закон је из 2010 који је дозвољавао увоз аутомобила произведених до 1970године, ал то је било пре 5 година. Овај модел ће још мало па напунити 40 година.
