bata621 0 Posted June 12, 2016 Report Share Posted June 12, 2016 Neznam kako da opisem problem ali pokusacu.Imam bmw e46 320d automatik,naime pri paljenju motora je sve sasvim normalno medjutim cim upalim klimu motor pocinje neravnomerno da radi a pri polasku gas mi veoma kasni,znaci nagazim papucicu gasa a on ne reaguje neko vreme,moram da je nagazim do kraja da bi auto krenulo.Ako neko ima ili je imao slican problem bio bih mu zahvalan a voleo bih da ovaj problem resim. Link to post Share on other sites
StunterSM 0 Posted June 12, 2016 Report Share Posted June 12, 2016 Jel dize obrtaje malo kad se klima upali? Link to post Share on other sites
bata621 0 Posted June 12, 2016 Author Report Share Posted June 12, 2016 Pa dize i spusta istovremeno,znaci ide gore dole Link to post Share on other sites
bata621 0 Posted June 12, 2016 Author Report Share Posted June 12, 2016 jeste 136ps Link to post Share on other sites
bata621 0 Posted June 13, 2016 Author Report Share Posted June 13, 2016 Da li neko zna sta bi moglo da bude? Link to post Share on other sites
StunterSM 0 Posted June 13, 2016 Report Share Posted June 13, 2016 Idi na dijagnostiku Link to post Share on other sites
bata621 0 Posted June 13, 2016 Author Report Share Posted June 13, 2016 Dijagnostika nista ne pokazuje ne razumem Link to post Share on other sites
StunterSM 0 Posted June 13, 2016 Report Share Posted June 13, 2016 Koja dijagnostika i ko ti je gledao? Link to post Share on other sites
bata621 0 Posted June 13, 2016 Author Report Share Posted June 13, 2016 Gledao mi je majstor a dijagnostika je bila bosh Link to post Share on other sites
slavisa27 0 Posted June 14, 2016 Report Share Posted June 14, 2016 Eh prijatelju imam ti ama bas isti problem i to vec godinu dana i nisam ga sanirao samo sto je kod mene 136 manual. Fakticki kad upalim klimu ostaje bez snage i kad krecem treba da mu malo turiram gas il da ga do kraja stisnem da bi se vratio u normalu. Jeden prilike jedan mi je majstor rekao da je to kvar od 6eura tj da je u pitanju senzor rashladne tecnosti a ja lijenac nikako da to promjenim, Link to post Share on other sites
bata621 0 Posted June 15, 2016 Author Report Share Posted June 15, 2016 Prijatelju jesi siguran da je u pitanju taj senzor,ako je do njega ja ga odmah menjam ! Link to post Share on other sites
BMW-E36 0 Posted June 15, 2016 Report Share Posted June 15, 2016 pa ne kosta te nista ( 6e ) da probas Link to post Share on other sites
slavisa27 0 Posted June 16, 2016 Report Share Posted June 16, 2016 tako mi je rekao jedan majstor pa sad ne znam da li je do njega. Navodno je on imao taj problem i rijesio ga je tako sto je to zamjenio...Sad ja sa sigurnoscu ne mogu garantovati jer nikako da ga zamjenim , sve se nema vremena . Ja imam dijagnostiku INPU i DiS i vezano za to nemam nikakve greske. Aj ako zamjenim u skorije vrijeme javljam sta je bilo. Link to post Share on other sites
bata621 0 Posted June 16, 2016 Author Report Share Posted June 16, 2016 Ja cu da zamenim nijeneka investicija samo mi nije jasno kakomoze taj senzor da pravi takav problem? Link to post Share on other sites
slavisa27 0 Posted June 17, 2016 Report Share Posted June 17, 2016 j***m li ga, svasta je moguce. Neka sitnica moze se odraziti s neceim sa cim nema veze, Reci mi jel zimi imas problema kad upalis grijanje bez klime , jel ti tad variraju obrtaji dok je ladan ? Link to post Share on other sites
bata621 0 Posted June 17, 2016 Author Report Share Posted June 17, 2016 Ne,zimi nema ili ja nisam primetio ali mislim da zimi nema.Mene to jako nervira najvise zato sto mi kasni gas na odziv,obrukas se u saobracaj ti gazis gas a auto polazi kao da je starac u sto godina a ne bmw.Kada se zagreje motor onda je bolje,onda motor radi mirno i nemam problema. Link to post Share on other sites
