gagi225 0 Posted June 29, 2016 Report Share Posted June 29, 2016 Pozdrav, nije me bilo dugo.. Eh sad kupio sam e39 520i fabricki bez klime, a imam stranca sa klimom. Moze li se prebaciti sve i da li je neko radio nesto slicno? Hvala Sent from my HUAWEI P7-L10 using Tapatalk Ako moze neko da premjesti temu, slucajno promasio Link to post Share on other sites
777.boban 0 Posted June 29, 2016 Report Share Posted June 29, 2016 Moze,sve je lako osim struje koju ce morati neki krsteni elektricar da ti uveze. Link to post Share on other sites
gagi225 0 Posted June 29, 2016 Author Report Share Posted June 29, 2016 Ok hvala, ima li nekih prepravki ili se samo skida i stavlja drugo. Da nema struju razvucenu vec, jer me cudi da e39 nema klimu. Sent from my HUAWEI P7-L10 using Tapatalk Link to post Share on other sites
777.boban 0 Posted June 29, 2016 Report Share Posted June 29, 2016 MOras da pogledas ali neverujem da ima instalaciju u pripremi,ostalo je sve plug n play Link to post Share on other sites
gagi225 0 Posted July 4, 2016 Author Report Share Posted July 4, 2016 Jos jedno pitanje da li odgovara klima iz 525tds, imam sve kompletno sa instalacijom i svim Sent from my HUAWEI P7-L10 using Tapatalk Link to post Share on other sites
wice 0 Posted July 4, 2016 Report Share Posted July 4, 2016 Ne pasuje ti kompresor i cevi od kompresora.ostalo treba da je isto Link to post Share on other sites
777.boban 0 Posted July 6, 2016 Report Share Posted July 6, 2016 Ako je tvoj auto 1996-1999 i taj stranac isto onda je sve isto osim kompresora i creva,a ako je neki od njih restyling onda nista nije isto. Link to post Share on other sites
gagi225 0 Posted July 7, 2016 Author Report Share Posted July 7, 2016 Oba su 99, razmisljam da li da ugradjujem klimu ili da kupujem felne Brine me jedino struja mehanicki bi skopcao sve sam nije problem. Klima me izadje 125e kompletna to je dzabe Sent from my HUAWEI P7-L10 using Tapatalk Link to post Share on other sites
wice 0 Posted July 7, 2016 Report Share Posted July 7, 2016 Pa jbg to je bas dzabe ako dobijas bas sve Link to post Share on other sites
