firul 0 Posted November 15, 2015 Report Share Posted November 15, 2015 Zdravo svmia, juce sam ubacio pojacalo i woofer u gepek. Problem koji imam je taj sto kad ugasim auto na duze od par minuta, pa kad ponovo upalim muzika nece da radi. Nece ni fabricki zvucnici , ni woofer, posle samo izvadim ulaz iz pojacala i vratim i krene sve da radi. Kad ugasim auto samo na minut onda se sve pali kad dam kontakt normalno. Ulaz za zvuk u pojacalo sam uzeo sa zadnjeg desnog zvucnika a remote ispod haube odakle sam uzeo struju i za angel eyes, posto imam fabricku navigaciju i cd changer pa nemam fabricko pojacalo u gepeku. U cemu moze da problem? Link to post Share on other sites
firul 0 Posted November 17, 2015 Author Report Share Posted November 17, 2015 Probao sam i da odvojim L i R sa oba zadnja zvučnika i isto, jel mogu negde drugde da uzmem izlaz iz plejera za pojačalo? Link to post Share on other sites
StunterSM 0 Posted November 17, 2015 Report Share Posted November 17, 2015 Remote treba da uzmes iz fabrickog pojacala, znaci da imaju isti remote. Sto se tice zezanja oko ulaza nije mi logicno da zeza tako Link to post Share on other sites
firul 0 Posted November 17, 2015 Author Report Share Posted November 17, 2015 Ne znam gde je fabričko pojačalo, u gepeku imam samo changer i čitač za navigaciju, pojačala nema Link to post Share on other sites
firul 0 Posted November 17, 2015 Author Report Share Posted November 17, 2015 Probaću sa drugim pojacalom kasnije da vidim da li se isto desava Link to post Share on other sites
firul 0 Posted November 17, 2015 Author Report Share Posted November 17, 2015 Sa drugim pojacalom radi sve lepo Link to post Share on other sites
StunterSM 0 Posted November 17, 2015 Report Share Posted November 17, 2015 Resen problem :) samo uzmi jos remote sa pravog mesta, da ti se pojacalo pali kad i muzika u kolima Link to post Share on other sites
firul 0 Posted November 17, 2015 Author Report Share Posted November 17, 2015 jel znas mozda koje je boje kabl sa plejera, jer ovaj moj izgleda da nema pojacalo van plejera, kod mene je kasetas sa onom malom navigacijom? Link to post Share on other sites
StunterSM 0 Posted November 17, 2015 Report Share Posted November 17, 2015 Nista napamet, u nedelju dolazim kuci pa mogu pogledati seme, ako se ne snadjes do tad Link to post Share on other sites
firul 0 Posted November 17, 2015 Author Report Share Posted November 17, 2015 Sad sam stigao kuci posle voznje i opet problem i sa ovim pojacalom. Kad pojacam malo muziku i cim krene bas da bije iskljuci se muzika skroz i na zvucnicima i na vuferu, tek kad smanjim pocne ponovo, da li treba da dodam neki otprnik ili sl na ulazu? Link to post Share on other sites
StunterSM 0 Posted November 18, 2015 Report Share Posted November 18, 2015 A na tim pojacalima jel imas neki drugi ulaz? Neka imaju ulaze namenjene bas za to kad se uzima sa zvucnika signal Link to post Share on other sites
firul 0 Posted November 18, 2015 Author Report Share Posted November 18, 2015 Nema, ima samo jedan, tj. dva L i R Link to post Share on other sites
StunterSM 0 Posted November 18, 2015 Report Share Posted November 18, 2015 Vidi na skoro svakom koje sam imao bilo je ulaz na cinc i ulaz od zvucnika. Vidis na slici speaker input? Link to post Share on other sites
StunterSM 0 Posted November 18, 2015 Report Share Posted November 18, 2015 Evo nasao sam ti o cemu se radi, prostudiraj http://www.crutchfield.com/S-dCgpV4QrXmy/learn/reviews/20030812/oem_amps.html Link to post Share on other sites
firul 0 Posted November 18, 2015 Author Report Share Posted November 18, 2015 KOd mojih nema taj speaker input, verovatno jer su slabija malo, jedno je blaupunkt 350w a drugi 160w. Ima na ovom drugom sto je montiran za prebacivanje mono i stereo, bio mi je na stereo, sad sam prebacio na mono i nije se gasio, videcu kasnije u voznji sta ce da bude. Video sam sad ovde na kraju posta da mi mozda treba line output converter, navodno sluzi baz za to da se signal sa zvucnika pretvori u line out, ako ni sad nece verovatno cu morati da kupim to http://www.crutchfield.com/S-PBDJe6O2mzg/learn/reviews/20030812/oem_amps.html Link to post Share on other sites
firul 0 Posted November 18, 2015 Author Report Share Posted November 18, 2015 hehe, video sam kad sam klinuo na post da si nasao isto :) Link to post Share on other sites
StunterSM 0 Posted November 18, 2015 Report Share Posted November 18, 2015 To sto se iskljuci muzika je verovatno zastita neka da ne bi nesto izgorelo u samom pojacalu. Voltaza je problem, nadji pojacalo drugo koje ima ovaj ulaz Link to post Share on other sites
firul 0 Posted November 18, 2015 Author Report Share Posted November 18, 2015 Kupicu prvo ovaj konverter pa ako neće ni sa njim onda cu da tražim drugo pojacalo Link to post Share on other sites
firul 0 Posted November 20, 2015 Author Report Share Posted November 20, 2015 Stavio sam konverter, sad radi sve kako treba, nema vise gasenja Link to post Share on other sites
