kako programirati ključ od e39 posle zamena baterije
drugari izvinite na čekanju ali evo odgovora , naravno da ću podeliti sa vama:
1. otkljucati auto sa kljucem koji se kodira
2. pritisnuti dugme za otkljucavanje i tako pritisnutog staviti u bravu u poziciju 1
3. izvuci kljuc napolje ali dugme ne pustati
4. pritsnuti dugme za zakljucavanje 3x brzo
5. tek sad mozete pustiti dugme otkljucavanja
ako je sve uradjeno kako treba bmw treba sam da se zakljuca pa otkljuca.
mislim da sam objasnio lepo, ako ima pitanja tu sam.
u potpisu: početnik koji uči :)
naravno ovo radite kad menjate bateriju u samom kljucu sa 3 tastera: zakljucavanje, otkljucavanje, gepek
  • 3 months later...
Nemora da otkljucava vrata sa kljucem,samo ga stavi u bravu na polozaj 1,izvuce kjuc,drzi srednje dugme i 3 puta otkljucavanje.I to je to.Auto ce da se zakljuca i otkljuca.
slusaj bobana i daleko ces dogurati
Jedan kljuc me zezao i nikako nisam mogo da ga programiram.
Ovo je postupak koji sam pratio a pre toga sam probao sve živo, tj. sve ostale tutorijale.
And don't get frustrated and give up early. If you ever feel like you may have fubarred a step...just stop and start completely over...no big deal.
Step 1 and 2 usually aren't mentioned, but I like to do it just to be sure things are set and ready to go before the usual unlock step #3.
From the outside of the car using the manual door lock cylinder.....
1. Insert key and turn to the right to lock the car. (Does the car lock AND set the alarm?) Bring key back to normal vertical position.
2. Turn the key to the right again and hold it there until you hear another faint set of clicks form the door locks. (Did you hear the faint clicking?) Bring key back to vertical position.
3. Turn key to the left to unlock car and remove key.
4. Get in car and shut all doors. (do NOT lock them)
5. Insert key into ignition and turn it ON to position 1.
(the only thing on the dash that should come on is the information section in the middle and airbag light, and radio and whatnot in center console if it happened to be turn on) NO CEL, NO Traction Control, nothing else.
6. Leave key in position 1 for about 2 solid seconds and then turn it OFF.
7. Remove key from ignition and immediately press and hold button #2 (unlock button) on the key remote.
8. While still holding button #2 ... immediately press button #1 (lock button) on the key remote at a steady pace three times. (1....2....3) (not 1.2.3) Be sure to click and release each time while counting.
9. Release button #2 (unlock button) and wait for car locks to respond by self locking and unlocking.
The whole process does NOT need to be done super quick, just nice steady steps and should still only take a total of like 8-10 seconds to complete the whole procedure once you start the inside of the car portion. You can kinda pace yourself by counting it out as you do it each step of the way. 1-1000, 2-1000, 3-1000, etc, etc.
Ovo ti nije tacno nikako. Znao sam postupak napamet, i pokusavao sam da kodiram kljuc i nisam uspevao , mislio sam da sa kljucem nesto nije u redu . A greska mi je bila sto auto uopste nisam otkljucavao kljucem kojim sam hteo da kodiram. E onda sam video ovo sto je @crni82 napisao pod brojem 1. i iz prve sam uspeo da kodiram taj kljuc.
Ja sam tako kodirao 3 kljuca,sta da ti radim.I kakve veze ima brava na vratima sa kodom kljuca??Da nema mozda imobilajzer na bravi??Sta lupate gluposti,ako narezujes novi kljuc naravno da treba da proveris da li ce da otkljuca bravu vrata,ali sve oko ews-a ide preko uloska brave jer odatle dobija napon,sa brave za paljenje, a ne sa brave sa vrata.
Ali nema veze bitno je da si ti kodirao kljuc,sve ostalo je nebitno.
ljudi meni je uspelo kao sto sam i rekao sa ovim primerom sto je prikazao Crni,ali posle nekoliko dana besprekornog rada ključa i daljinskih kontrola opet je iznenada prestao da radi???ja ga programiram ponovo on radi ali svega nekoliko sati...
  • 2 months later...
