  • 11 months later...
Dok sam vozio e30 m40 1,6 skinem stare svecke sa kojima sam ga kupio a na njnima pise NGK i BMW, stavim bosch po katalogu kupljene, i auto mnogo losije radi. Vratim stare, narucim iste takve i vozi ne razmisljaj.Znaci NGK.
  • 2 years later...
Imam problema sa autom, ponekad trokira, secka i pukne u auspuhu, uglavnom kad je hladan, kad se ugreje uglavnom nema problema. Nekad se desi upalim i sve radi kako treba, ne znam od cega da pocnem? Da li svecice mogu da prave problem da nekad trokira a nekad ne?
  • 7 months later...
Malo sam u dilemi oko svećica koje bi trebalo da zamenim. Za brend nisam u dilemi idu NGK, ali koje od ovih ponudjenih sa njihovog sajta. Auto ima plin.
Po forumima raznim vidim da preporučuju ove najskuplje (4 kraka). Ne znam da li zbog plina treba sa jednim krakom (smeša drugačija bla, bla...).
Za m54 motore ove preporučuju:
http://www.ngk.com/Automotive-NGK-c1411.aspx
Special spark plugs from NGK:
Specifically developed for gas operation
As well as the current iridium types, NGK now
also offers special spark plugs for gas-powered
vehicles. They are specifically manufactured for
use in retro-fitted vehicles and have proven
themselves in Japan for many years – for
example in taxis, which are without exception
gas-powered in that country.
It’s the plating that does it.
The spark plugs for use with gas are plated with
a chrome alloy specifically developed by NGK for
this purpose. It is able to resist the aggressive
conditions of gas operation for longer than
normal platings. At present for cars there is
no other spark plug which can offer a similar
plating.
Platinum and iridium: The dynamic duo.
In the same way as with standard iridium and
platinum spark plugs, the special spark plugs for
gas-powered cars also have a laser welded centre
electrode using an iridium chip of only 0.6 mm
diameter. In addition, the ground electrode is
fitted with a platinum chip which further
improves the durability and therefore the lifetime
of the spark plug.
An overview of the special spark plugs:
● A particularly long life thanks to a special
plating for the metal shell as well as
electrodes of platinum and iridium.
● Reliable ignition and an even spread
of the flame core.
● The best ignition properties also when
operating with gas.
● Low ignition voltage requirement.
● In comparison with standard spark plugs,
improved emission values also when operating
with gas.
A word on installation.
There is no difference between installing a spark
plug in a dual fuel engine and installing one in a
normal engine. Before removing the old spark
plug, the cylinder head should be cleaned. The
new spark plug is then screwed in by hand and
then tightened with a torque wrench to the
correct torque setting.
In some cases it has proven effective when
retro-fitting for gas operation to reduce the
electrode gap slightly, 0.3 mm at the most, in
comparison to the normal recommendation for
petrol operation to facilitate the spark discharge.
Iridium spark plug BPR6EIX-LPG
Ovo kaže ngk lično :-)
