srki81 0 Posted February 25, 2010 Report Share Posted February 25, 2010 Interesuje me kako utvrditi ispravnost senzora temperature(PLAVOG) i za sta mu sluzi onaj braon boje pored njega?Povecala mi se potrosnja na neverovatnih 18lit. pa sumnjam na to. :angry: :angry: Testirao sam vise puta i sa razlicitim gorivom ali uvek isto 15 do 18lit.Motor 1.8/115ks m40. Link to post Share on other sites
StunterSM 0 Posted February 25, 2010 Report Share Posted February 25, 2010 I mene zanima, i gde stoji kod e36 2.0? Link to post Share on other sites
Suki 0 Posted February 26, 2010 Report Share Posted February 26, 2010 Interesuje me kako utvrditi ispravnost senzora temperature(PLAVOG) i za sta mu sluzi onaj braon boje pored njega?Povecala mi se potrosnja na neverovatnih 18lit. pa sumnjam na to. :angry: :angry: Testirao sam vise puta i sa razlicitim gorivom ali uvek isto 15 do 18lit.Motor 1.8/115ks m40. Link to post Share on other sites
zverko 0 Posted February 26, 2010 Report Share Posted February 26, 2010 suki, a cetvoropolni senzor tj multifunkcionalni. koji pin je za sta? Link to post Share on other sites
srki81 0 Posted February 26, 2010 Author Report Share Posted February 26, 2010 Hvala za info.Ustanovio sam da neradi ba cu ovih dana da se raspitam koliko kosta nov,ako neko zna cenu neka napise. Link to post Share on other sites
Suki 0 Posted February 27, 2010 Report Share Posted February 27, 2010 @ne kontam,koji cetveropolni,koji auto,gdje bude....'?? Link to post Share on other sites
bmw e30 drifter 0 Posted February 27, 2010 Report Share Posted February 27, 2010 Hvala za info.Ustanovio sam da neradi ba cu ovih dana da se raspitam koliko kosta nov,ako neko zna cenu neka napise. 1250din Link to post Share on other sites
bmw e30 drifter 0 Posted February 27, 2010 Report Share Posted February 27, 2010 I mene zanima, i gde stoji kod e36 2.0? ispod usisne grane u glavi, blize prednjem delu motora... Link to post Share on other sites
bmw e30 drifter 0 Posted February 27, 2010 Report Share Posted February 27, 2010 Interesuje me kako utvrditi ispravnost senzora temperature(PLAVOG) i za sta mu sluzi onaj braon boje pored njega?Povecala mi se potrosnja na neverovatnih 18lit. pa sumnjam na to. :rolleyes: :) Testirao sam vise puta i sa razlicitim gorivom ali uvek isto 15 do 18lit.Motor 1.8/115ks m40. braon sluzi za pokazivac temperature na km satu... Link to post Share on other sites
zverko 0 Posted February 27, 2010 Report Share Posted February 27, 2010 @suki: M44 motor ima cetvoropolni koji ujedno daje signal na ECU i na tablu. Link to post Share on other sites
prodigy 0 Posted February 27, 2010 Report Share Posted February 27, 2010 offtopic, iz kog programa je ova slicica ? Link to post Share on other sites
srki81 0 Posted February 27, 2010 Author Report Share Posted February 27, 2010 Hvala za info BMW drifteru. Link to post Share on other sites
StunterSM 0 Posted February 28, 2010 Report Share Posted February 28, 2010 Jel moram skinuti granu da bi dosao do njega drifteru? :rolleyes: Link to post Share on other sites
bmw e30 drifter 0 Posted February 28, 2010 Report Share Posted February 28, 2010 Jel moram skinuti granu da bi dosao do njega drifteru? :rolleyes: ne moras, tesno je ali ima taman dovoljno mesta da mozes da zavuces kljuc i lagano odvrces... Link to post Share on other sites
R.P.M. 0 Posted February 28, 2010 Report Share Posted February 28, 2010 jeli na e39 520i "98g četvoropolni ili ima dva davača temperature za tablu i ecu Link to post Share on other sites
StunterSM 0 Posted February 28, 2010 Report Share Posted February 28, 2010 Obicni bi trebalo da ima.. Link to post Share on other sites
srki81 0 Posted February 28, 2010 Author Report Share Posted February 28, 2010 Zamenjen senzor,nemogu vam opisati koliko mirnije radi i kada je hladan,nema trunke dima ni mirisa benzina kao pre a potrosnja se vratila na 12 do 13 lit.I Naravno ubrzava kao blesav bez trzuckasnja. od 0 do 100 za 11 sek.Tako mali deo a da toliko sranja napravi coveku i zivce pokida.Jos cu i landa sondu da proverim. Link to post Share on other sites
R.P.M. 0 Posted February 28, 2010 Report Share Posted February 28, 2010 Obicni bi trebalo da ima.. ima li slika gdje bi trebao da se nalazi davač temp. za ecu Link to post Share on other sites
AlexBMW 0 Posted February 28, 2010 Report Share Posted February 28, 2010 ima li slika gdje bi trebao da se nalazi davač temp. za ecu Dupli je , pod brojem 14: http://bmwfans.info/parts/catalog/E39/Seda...der_head_vanos/ Link to post Share on other sites
R.P.M. 0 Posted March 1, 2010 Report Share Posted March 1, 2010 Hvala ! :girl_cray2: Link to post Share on other sites
NGGORCHE 0 Posted March 1, 2010 Report Share Posted March 1, 2010 offtopic, iz kog programa je ova slicica ? Odgovor na offtopic VIVID Workshop Data. :girl_cray2: Link to post Share on other sites
prodigy 0 Posted March 1, 2010 Report Share Posted March 1, 2010 Odgovor na offtopicVIVID Workshop Data. :girl_cray2: Hvala. Link to post Share on other sites
licmi 320i 0 Posted March 6, 2010 Report Share Posted March 6, 2010 Odgovor na offtopic VIVID Workshop Data. :2u4pvecna8: [/quottažio sam da skinem ovu datu ali moguće ju je samo kupiti, imali gdje da se skine for free Link to post Share on other sites
StunterSM 0 Posted March 7, 2010 Report Share Posted March 7, 2010 Potrazi na rapidu.. Link to post Share on other sites
doubledjoka 0 Posted February 25, 2017 Report Share Posted February 25, 2017 Imam problem na autu bmv 320d e46 2002god Cim dam kontakt (auto mi ne radi nekoliko dana), temperatura mi skoci na skroz crveno. Auto sam nosio u jedan servis i "majstor" nije mogao da nadje problem, pa sam oterao u drugi servis (elektricar) da ga pogleda. Javlja mi danas da je otisao neki senzor (ne znam koji tacno) na valjda glavi motora, ali ne moze da pridje njemu i da ga zameni. Pa ako ne sredi u naredna dva tri dana, da ga oteram opet kod nekog mehanicara da ga zameni. Ne znam sta vec da radim, ovaj problem mi se vuce vec dva meseca, bez auta sam i imam glavobolju od svega. Moze neka pomoc, savet ili sta? Link to post Share on other sites
