sladjanbekonja 0 Posted June 18, 2010 Report Share Posted June 18, 2010 kako rasiriti zadnji deo a da se ne prepravljaju rubovi i dal moze? Link to post Share on other sites
sladjanbekonja 0 Posted June 19, 2010 Author Report Share Posted June 19, 2010 нeko da pomogne :) Link to post Share on other sites
Suki 0 Posted June 19, 2010 Report Share Posted June 19, 2010 kako nasuti 2 litra vode u flasu od jedan litar a da nemijenjas vlasu???? Link to post Share on other sites
Vanyonni 0 Posted June 19, 2010 Report Share Posted June 19, 2010 :) :dance3: :lol2: Link to post Share on other sites
DangaraBMW 0 Posted June 19, 2010 Report Share Posted June 19, 2010 Kako to misliš?...da malo izbaciš točkove? Link to post Share on other sites
sladjanbekonja 0 Posted June 20, 2010 Author Report Share Posted June 20, 2010 znaci nista bez prepravki rubova i stavljanja distancera? :) Link to post Share on other sites
Coa_16v 0 Posted June 27, 2010 Report Share Posted June 27, 2010 Moze, ali zavisi koliko hoces da ih prosiris :pleasantry: Uploaded with ImageShack.us Link to post Share on other sites
sladjanbekonja 0 Posted June 29, 2010 Author Report Share Posted June 29, 2010 pa ne mnogo ko ovo radi kod nas ja bih tako nesti da nemoram da secem rubove?hvala Link to post Share on other sites
sladjanbekonja 0 Posted July 11, 2010 Author Report Share Posted July 11, 2010 zna neko?hvala Link to post Share on other sites
alpinac1 0 Posted July 11, 2010 Report Share Posted July 11, 2010 Imam ja alat za to ali se sa njim nemoze puno uraditi to jets izvuci rub nesto nezanemarljivo sa prednjim je lakse ali su zadnji malo problem posto moze da se desi pucanje boje i da mora da se farba rub.Sve zavisi koliko oces da prosiris rubove i sta ustvari oces to je sve pitanje ? Link to post Share on other sites
alkonibmw 0 Posted July 11, 2010 Report Share Posted July 11, 2010 Ima moj ortak taj set za izduvavanje rubova.. Ali ako se malo pretera u previse ispumpa, hoce da puca boja/lak.. Sve u granicama normale.. onda stavis distancere/odstojnike i prosiris mu trap Link to post Share on other sites
Sicko 0 Posted July 11, 2010 Report Share Posted July 11, 2010 Treba da se greje rub, industriskim fenom, naravno ne previse da osteti lak, pre izvlacenja.... Link to post Share on other sites
sladjanbekonja 0 Posted July 17, 2010 Author Report Share Posted July 17, 2010 nebih ja to mnogo recimo distanceri 10 di 15 santimotara(oba) i gume 225 alpinac1 mislis da moze toliko?hvala Link to post Share on other sites
alpinac1 0 Posted July 17, 2010 Report Share Posted July 17, 2010 sve zavisi koji su ti et felne i dokle dolaze do ruba mozda i nemors to sve zavisi,mozda i nemoras nego samo onaj unutrasnji rub saviti unutra i tek tek izbaciti rub Link to post Share on other sites
wice 0 Posted July 17, 2010 Report Share Posted July 17, 2010 znaci mislis distancere od 50-75mm po strani? mislim da se ne moze toliko raziriti rub bez secenja ma koji god et da stavis Link to post Share on other sites
alpinac1 0 Posted July 17, 2010 Report Share Posted July 17, 2010 ne en mislio je 10 do 15 mm to onda nemora da se siri rub i opet kazem zavisi od et-a felne Link to post Share on other sites
wice 0 Posted July 18, 2010 Report Share Posted July 18, 2010 ok ako su milimetri u pitanju onda nije problem,nego napisao je santimetri,pa sam se zacudio :( Link to post Share on other sites
sladjanbekonja 0 Posted July 18, 2010 Author Report Share Posted July 18, 2010 felne su mi fabricke 16tice od e46(neznam koji je ET) mislio sam 10cm ukupno da prosirim zadnji trap znaci distanceri 5cm.jel moze? hvala! Link to post Share on other sites
wice 0 Posted July 19, 2010 Report Share Posted July 19, 2010 zavisi od et felne,ali mislim da nece moci na ovaj nacin,slikaj pa okaci sliku Link to post Share on other sites
alpinac1 0 Posted July 19, 2010 Report Share Posted July 19, 2010 neces moci 10cm to je malo neizvodljivo i izace ko svetog petra kajgana to je krvav posao mada postoje mogucnosti a najlakse ti je felne prosiriti ili traziti felne sa jako malim et a toliko prosiriti zadnji trap nemoze se uraditi sa samo izvlacenjem rubova morasce druge raditi tako da neznam sta da ti kazem.sto kaze wice okaci sliek pa cemo videti sta ti mislis i pomoci koliko mozemo Link to post Share on other sites
Suki 0 Posted July 19, 2010 Report Share Posted July 19, 2010 ma kako nece moci....moze bre... Link to post Share on other sites
Suki 0 Posted July 19, 2010 Report Share Posted July 19, 2010 nebih ja to mnogo recimo distanceri 10 di 15 santimotara(oba) i gume 225 alpinac1 mislis da moze toliko?hvala sve zavisi koji su ti et felne i dokle dolaze do ruba mozda i nemors to sve zavisi,mozda i nemoras nego samo onaj unutrasnji rub saviti unutra i tek tek izbaciti rub Link to post Share on other sites
BMW Shone 0 Posted July 19, 2010 Report Share Posted July 19, 2010 kako nasuti 2 litra vode u flasu od jedan litar a da nemijenjas vlasu???? Pa sipas pepela u flasu i stace 2L! Link to post Share on other sites
Sutlandjanin 0 Posted July 19, 2010 Report Share Posted July 19, 2010 Pa sipas pepela u flasu i stace 2L! hehe da da bas smo o tome pricali veceras..istina.. :preved: moze da se ubudzi ;) Link to post Share on other sites
StunterSM 0 Posted July 19, 2010 Report Share Posted July 19, 2010 Ozbiljno? Link to post Share on other sites
