milan e34 0 Posted September 19, 2011 Report Share Posted September 19, 2011 Imam problem sa e36 2.0 24v m50 neradi dobro u leru,nemogu da naljem u cemu je problem varira u leru od 600 do 750 obrtaja,pre neki dan sam ugradio sekvenc plin na plinu jos gore radi... menjo sam proto komer,dizne,bobine...nije do nicega!sad mislim da je do nekog senzora ili davaca... molim za pomoc ako neko zna o cemu se radi... Link to post Share on other sites
MilanKV 0 Posted September 20, 2011 Report Share Posted September 20, 2011 Senzor bregaste, meni je tako bilo na e39 M52 motoru. Link to post Share on other sites
milan e34 0 Posted September 20, 2011 Author Report Share Posted September 20, 2011 neznam dal je do toga,kad digne radnu teperaturu onda radi kao da je pod sauhom Link to post Share on other sites
pak76 0 Posted September 20, 2011 Report Share Posted September 20, 2011 Odes na dijagnostiku da provere senzore Link to post Share on other sites
milan e34 0 Posted September 22, 2011 Author Report Share Posted September 22, 2011 biojo sad dans na dijagnostici i nemogu da ga iscitaju nemogu da udju u sistem,danas sam imo vremena pa sam malo cacko...kad iskljucim protokomer radi exstra i prima gas dobro,probo sam jos 2 protokomera cim ih ukljucim uvek se isto desava...neznam sta moze to da bude... Link to post Share on other sites
777.boban 0 Posted September 23, 2011 Report Share Posted September 23, 2011 Jesu ta 2 druga protokomera ispravna?? Link to post Share on other sites
milan e34 0 Posted September 23, 2011 Author Report Share Posted September 23, 2011 jesu skinuta su sa auta koji radi exstra,danas sam menjo i ler lauf ventil,i sve vakume pregledo sve je ok.Kad iskljucim protokomer padnu obrtaji na 600 i radi ekxtra...ostalo mi jos da promenim kopijuter..neznam dal moze to da se desava ako ode lamda sonda? I neznam sto nece da ga iscita dijagnostika??? Link to post Share on other sites
milan e34 0 Posted October 13, 2011 Author Report Share Posted October 13, 2011 Zasta sluzi onaj indikator sto stoji pored klapne usisne,uvrnut je u usisnu granu izgleda ko grejac...dal to moze da zajebava sto varira u leru??? Link to post Share on other sites
