la-bavarac 0 Posted February 27, 2012 Report Share Posted February 27, 2012 Neradi mi auto dobro preko 4500rpm. Nastavi da gura obrtaje dalje ali nema snagu i kao da radi na 3 klipa. Da napomenem, problem se javlja i na plinu i na benzinu. Link to post Share on other sites
Paun_e36 0 Posted February 27, 2012 Report Share Posted February 27, 2012 http://www.bmwclubserbia.com/forum/index.php?showtopic=10356&st=0&p=103780&hl=+trokira%20+iznad&fromsearch=1entry103780 pogledaj tu :) Link to post Share on other sites
la-bavarac 0 Posted February 27, 2012 Author Report Share Posted February 27, 2012 Sad tek nemam ideju, menjao sam vec kablove i svecice i isto. A radi mi lepo na leru, ne duva, ne trosi ulje. Lepo poteze do tih obrtaja, ali preko toga truba. Puni do 6000rpm, ali ne kako treba. Izgleda da ce morati na kliniku... Link to post Share on other sites
srki81 0 Posted February 27, 2012 Report Share Posted February 27, 2012 Kakav ti je filter vazduha? Link to post Share on other sites
la-bavarac 0 Posted February 27, 2012 Author Report Share Posted February 27, 2012 Dobar, uradjen servis pre desetak dana. I pre i posle isti problem. Link to post Share on other sites
Paun_e36 0 Posted June 22, 2012 Report Share Posted June 22, 2012 Jel si resio problem ? Link to post Share on other sites
la-bavarac 0 Posted June 22, 2012 Author Report Share Posted June 22, 2012 Nisam, izgleda da je problem u glavi motora. U zadnjih mesec dana je bas pocela da se cuje bregasta, hidropodizaci itd. Jeli imas isti problem? Link to post Share on other sites
Paun_e36 0 Posted June 22, 2012 Report Share Posted June 22, 2012 Imam i ja problem sa tim :) moj nece ni na plinu ni na benzinu da prebaci ali nekad zatrokira na 4000 nekad na 5000 nekad na 5500 ne znam ni ja sam... ali kod mene ne lupa bregasta,cuju se podizaci ali ne toliko strasno..nekad u ler probije i dodje do 6500 ali retko kad... Link to post Share on other sites
la-bavarac 0 Posted June 23, 2012 Author Report Share Posted June 23, 2012 Kod mene dogura do kraja ali nema snagu i lep rad preko 4500, kao da radi na 3 klipa. Link to post Share on other sites
Paun_e36 0 Posted June 23, 2012 Report Share Posted June 23, 2012 ma moj nece do kraja,zaglavi tako na 4500-5000 kako kad ,na plin kad nece da progura on detonira i tako u krug :D Link to post Share on other sites
Suki 0 Posted June 23, 2012 Report Share Posted June 23, 2012 stari dobri m40... Link to post Share on other sites
la-bavarac 0 Posted June 23, 2012 Author Report Share Posted June 23, 2012 Meni nikad nije detonirao, izgleda da nas ne muci ista stvar. Link to post Share on other sites
Paun_e36 0 Posted June 23, 2012 Report Share Posted June 23, 2012 Pa i nije toliko los,ne kvari se,jedino da se vozi u 3000rpm :D Link to post Share on other sites
la-bavarac 0 Posted June 23, 2012 Author Report Share Posted June 23, 2012 Ja sam se lepo navozao, od pocetka godine sam presao 15000km, na predjenih 10000km sam dolio ukupno 500ml ulja. Potrosnja skromna, a i ne ide tako lose. Retko ko je ostajao ispred mene. Link to post Share on other sites
la-bavarac 0 Posted June 23, 2012 Author Report Share Posted June 23, 2012 Jeli tvoj 316 ili 318? Link to post Share on other sites
Paun_e36 0 Posted June 23, 2012 Report Share Posted June 23, 2012 316 je moj :) bas tako i moj ne trosi gram ulja od zamene do zamene,jedino to sto zeza tako u visokim obrtajima :) Link to post Share on other sites
Zepi E30 0 Posted July 13, 2012 Report Share Posted July 13, 2012 imao sam slican problem,kada se zagreje nije hteo da vuce gusio se. zamenjen senzor bregaste i regulator pritiska goriva. e36 318is Link to post Share on other sites
