bokica 0 Posted August 26, 2012 Report Share Posted August 26, 2012 koliko ulja staje u e46 320d 150ks.kad da proveravam ulje kad je skroz hladan ili posle voznje da cekam 5 min.Naime majstor mi promenio ulje i danas posle voznje nekih 10 min ja da proverim ulje ohoho preko maksimuma a on kaze da mu je sipao 5.5l. Link to post Share on other sites
ianullrich 0 Posted August 26, 2012 Report Share Posted August 26, 2012 pa toliko ide, mozda nije lepo sve ispustio staro, gledaj da ispustis taj visak, nikako preko max Link to post Share on other sites
zlaja.so 0 Posted August 26, 2012 Report Share Posted August 26, 2012 Ako imas viska moze da ga izgura na nekom semeringu, tako da je bolje malo ispustiti, nemoj preko maksimuma :acute: Link to post Share on other sites
Sigtran 0 Posted August 26, 2012 Report Share Posted August 26, 2012 Proveravaj kada je hladan ili recimo posle barem 1h od kako je ugašen da ulje slije u karter. Obavezno auto da stoji na ravnoj podlozi. Link to post Share on other sites
bokica 0 Posted August 26, 2012 Author Report Share Posted August 26, 2012 proverio sam sad preko maksimuma je jedno 1cm skoro do kraja onog plasticnog dela na meracu. kakav konj on zna da ide 5.5 i toliko mu sipao bez proveravanja Link to post Share on other sites
nele11 0 Posted August 26, 2012 Report Share Posted August 26, 2012 ja sam se isto tako zajebao,gledao u autodati i tamo pise da staje 5,5 ili 5,0l nisam siguran...i posle dolazi lik i kaze da je uvece ujutru proveravao ulje i kaze da ima puno preko maximuma,ja mu ispustio visak i to je to...par puta me auto data dobro zajebala Link to post Share on other sites
bokica 0 Posted August 26, 2012 Author Report Share Posted August 26, 2012 ma ja sam presao jedno 1000 km od sipanja nisam ni proveravao,nadam se da nije pustio negde Link to post Share on other sites
nele11 0 Posted August 26, 2012 Report Share Posted August 26, 2012 moze lako neki semering da sjebe Link to post Share on other sites
zlaja.so 0 Posted August 26, 2012 Report Share Posted August 26, 2012 Sipas 5 l i skoro je do crte nedostaje mu 1dcl, 2 dcl, ali nikako 0,5 l,naravno sa filterom ;) Dobro rece ianullrich mozda nije dobro ispustio Link to post Share on other sites
ticovman 0 Posted August 26, 2012 Report Share Posted August 26, 2012 Po knjizi, trebalo bi stvarno da stane 5,5l kada se menja i ulje i filter. Ja sam imao situaciju da u moj auto jednom prilikom u servisu sipaju 5,0l i to sa novim filterom i bilo do maksimuma (to je ona varijanta kada ti majstor na brzinu ispusti ulje, skine filter, odmah vraća raf za ulje, novi filter i sipa novo ulje, onda moe bez problema da mu sa usutih 5l bude na maksimumu, a sa 5,5 prilično iznad maksimuma jer se ne ocedi svo ulje iz auta). Sa druge strane, drugi put kada su ga skroz lepo ocedili, stalo 5,5l. Po pravilu, ako bilo ta pored ulja i filtera ima da se servisira na autu (filter vazduha, klime, kajievi, paneri...), trebalo bi da ispuste ulje, ostave auto da se cedi dok ne odrade ostalo i tek na kraju sipaju novo ulje. Ulje meri 4-5 min nakon gaenja motora koji je bio na radnoj temperaturi (isto po knjizi, jer hladno ulje ima manju zapreminu od ugrejanog, tako da ti hladno ulje moe davati meru na maksimumu, a kada se ugreje iznad maksimuma), to kau gore strogo da auto bude na ravnom (da izbačen iz brzine i sa sputenom ručnom ne krene ni napred ni nazad) i najbolje je da ulje proverava uvek na istom mestu tj. u garai ili na svom parking mestu itd. (da ne bude kao kod mene kada sam se natripovao da mi raste nivo ulja, ustvari bio je blag nagib u stranu, auto nije iao nigde ali stvarno je ispadalo da je 1,5-2mm vii nivo ulja). Isputaj viak, u pravu su momci da će ti isterati na nekom semeringu, ako ne sad preko leta, onda sigurno kad dođe zima i kada mu bude trebalo vie vremena da "razbije" ulje, a dođe momenat da optereti motor (ne mora biti neko jako stiskanje gasa, desi se da vas bude vie u kolima, uzbrdo obilazi ili ubrzava iz nekog razloga itd...) Link to post Share on other sites
bokica 0 Posted August 26, 2012 Author Report Share Posted August 26, 2012 nista idem ovih dana da promenim nosace motora i da mi ispusti visak,zao mi motor besprekoran,svaka sitnica na mestu sad zbog debila da se jebavam,a i ja sam kriv nisam gledao odmah,nego racunam zna a i proveravao je valjda menjani su svi grejaci oba kaisa,plocice bio auto u servisu 4'5 sati Link to post Share on other sites
