DEJAN74 0 Posted October 22, 2012 Report Share Posted October 22, 2012 Pozdrav,problem je sledeci,pre neki dan sam ukljucio ventilator kabine i bio je mrtav,kupio sam reostat(jez)i namontirao,sve je radilo 10 minuta kako treba i potom dolazi do toga da ventilator polako sam smanjuje brzinu,odnosno da pocinje da radi sa prekidima,kao da uzdise,nedugo zatim se ugasi,posle 5 minuta i gasenja jedinice ventilator opet vrti ali isto 10 minuta i opet staje,na centralnoj jedinice sve radi,mislim na sve komande,inace u pitanju je digitalna klima a bmw je e36 320i,sta dalje da pogledam ili isprobam Link to post Share on other sites
zlaja.so 0 Posted October 22, 2012 Report Share Posted October 22, 2012 Jesi kupio nov ili polovan reostat? http://imageshack.us/photo/my-images/48/dsc03214xv0.jpg/ Link to post Share on other sites
DEJAN74 0 Posted October 22, 2012 Author Report Share Posted October 22, 2012 nov kupio u bmw line Link to post Share on other sites
zlaja.so 0 Posted October 22, 2012 Report Share Posted October 22, 2012 Moras probati direktno ventilator bez reostata, ako vrti kako treba znaci da taj novi ima neku gresku Link to post Share on other sites
sn00py 0 Posted October 22, 2012 Report Share Posted October 22, 2012 Ako radi neko vreme pa se ugasi, znaci da se nesto zagreje pa stane [moguce da su se sjebale biksne ili lezaj ventilatora pa kad se zagreje, rasiri se i zablokira]. Probaj da zamenis jez, ako pravi i sa drugim problem, onda bih ti preporucio skidanje ventilatora.. Link to post Share on other sites
DEJAN74 0 Posted October 22, 2012 Author Report Share Posted October 22, 2012 ventilator malo bruju kad radi,ne mogu da opisem taj zvuk,kao da huci,ne znam da li moze biti problem do centralne jedinice klime tj one konzole u kabini mada ona sve pokazuje da je ok,mislim svi dugmici rade,probacu ventilator direktno da spojim,e sad,koliko dugo da ga drzim tako ukljucenog,mislim direktno Link to post Share on other sites
DEJAN74 0 Posted October 22, 2012 Author Report Share Posted October 22, 2012 i da,da li moram da skidam motor ili celu instrument tablu da bih izvadio ventilator? Link to post Share on other sites
zlaja.so 0 Posted October 22, 2012 Report Share Posted October 22, 2012 Otvoris haubu ispod poluga brisača na sredini imas jedan poklopac to skines i pridjes motoru, moram dodati tu je i filter Link to post Share on other sites
DEJAN74 0 Posted October 22, 2012 Author Report Share Posted October 22, 2012 znam ja kako da dodjem do ventilatora,ali koliko da ga drzim povezanog direktno?da vidim da li je on problem,ili novi jez ili sama konzola tj upravljacka jedinica klime Link to post Share on other sites
zlaja.so 0 Posted October 22, 2012 Report Share Posted October 22, 2012 Pa nemoras dugo znaci ukljuci ga drzi minut ako lepo vrti znaci da je jez problem http://www.bimmerfest.com/forums/showthread.php?t=393686 Link to post Share on other sites
DEJAN74 0 Posted October 22, 2012 Author Report Share Posted October 22, 2012 koliko vidim ovaj sa slike je izvadio ventilator a da nije vadio mtor iz automobila,ovde mi majstor jedan kaze da ne moze da se izvadi dok se ne izvadi ceo motor ili cela instrument tabla,redni sestak je u pitanju Link to post Share on other sites
CasperBg82 0 Posted October 22, 2012 Report Share Posted October 22, 2012 Izvuces ga sa strane, pored izduvne grane, kao ovaj na slici :) Jel mislis da bi bmw tako nesto napravio, da moras da vadis motor da bi izvadio ventilator ;) Link to post Share on other sites
DEJAN74 0 Posted October 22, 2012 Author Report Share Posted October 22, 2012 i meni je bilo cudno kad mi je rekao za vadjenje motora,da je zastava u pitanju ne bi me cudilo,ali da u bmw tako nesto naprave,to mi je bilo krajnje neozbiljno Link to post Share on other sites
zlaja.so 0 Posted October 22, 2012 Report Share Posted October 22, 2012 Taj majstor je neki zaj... izgleda, samo ti polako da nesto ne polomis, i probaj pa ces da vidis u cemu je problem Link to post Share on other sites
DEJAN74 0 Posted October 23, 2012 Author Report Share Posted October 23, 2012 Definitivno se nesto pregreva,radi tacno 10 min,kao da ima tajmer,onda stane i posle 5 min opet radi,da li postoji nacin da proverim centralnu jedinicu klime,da li je do nje problem ili da krenem od ventilatora Link to post Share on other sites
StunterSM 0 Posted October 23, 2012 Report Share Posted October 23, 2012 Imam ja jedinicu klime jednu mislim. Ako je iskopam poslacu ti je da probas sa njom Link to post Share on other sites
DEJAN74 0 Posted October 23, 2012 Author Report Share Posted October 23, 2012 ok,ako je do nje onda resen problem,platim i to je to Link to post Share on other sites
StunterSM 0 Posted October 23, 2012 Report Share Posted October 23, 2012 bas tako, samo ako je iskopam u delovima Link to post Share on other sites
DEJAN74 0 Posted October 23, 2012 Author Report Share Posted October 23, 2012 ok,mogu i doci po nju,ako si iz S.M Link to post Share on other sites
vranjin 0 Posted October 23, 2012 Report Share Posted October 23, 2012 Ako ti je digitalna klima onda bi trebao da je kod tebe onaj jez sa bodljama i na konektoru imas 5 pinova. Otkaci konektor sa jeza, Pinovi 1 i 5 su od motora a pinovi 2 i 4 dovod struje. Uzmi dva parceta zice i na konektoru(instalacije)spoj kontakte 2i 5 i kontakte 1 i 4. Tako si direktno vezao motor i treba stalno da vrti punu brzinu. Ako je to ok onda zakaci konektor na jeza. Treba ti instrument i izmeri napon na kontaktu 3. Tu treba da imas par volti kad treba da vrti ventilator, zavisi koliko je jedinica klime dala. Ako na kontaktu 3 ne dobijas napon onda ne valja jedinica klime. Ako je sve to ok onda drugi jez. Link to post Share on other sites
DEJAN74 0 Posted October 23, 2012 Author Report Share Posted October 23, 2012 jez je nov,ok provericu,a kako da znam koji je kontakt 1,2,3,4,5,ima dva gore i tri u drugom redu,koliko se secam Link to post Share on other sites
vranjin 0 Posted October 23, 2012 Report Share Posted October 23, 2012 Ima brojevi na konektoru. Link to post Share on other sites
DEJAN74 0 Posted October 23, 2012 Author Report Share Posted October 23, 2012 super,proverici,koliko sam shvatio,promena brzine na cent,jedinici treba da menja voltazu na tom kontaktu 3 Link to post Share on other sites
vranjin 0 Posted October 23, 2012 Report Share Posted October 23, 2012 Da, u zavisnosti koju brzinu zadaje jedinica klime menja se napon na kontaktu 3. Mislim da kod tebe treba da bude od 0 do 5V.Mozes odmah i skinuti jedinicu klime i tu imas jedan mali ventilator i pored njega senzor temperature, Hoce na njega da se nahvata prasine pa ocisti i to. Link to post Share on other sites
DEJAN74 0 Posted October 23, 2012 Author Report Share Posted October 23, 2012 ok druze,cackacu sutra pa da vidim sta je,mada mislim da je tu ventilator u problemu,neko pregrevanje postoji,to je sigurno Link to post Share on other sites
