Vlada88 0 Posted December 9, 2013 Report Share Posted December 9, 2013 Ljudi imam problem sa strujom vec neko vreme, da ne duzim puno, kapiram da mi vuce struju negde ali imam cudan problem. Uspem da upalim auto (bez problema) ali lampica akumulatora trepce. Ugasim auto, pa ga opet upalim i opet isto... fora je sto cim stavim kablove na sekund dok je upaljen auto (i dok trepce lampica za akumulator) odmah se ista ugasi i auto normalno radi i alternator puni akumulator.. i jako cesto kad mi trepce lampica mogu vise puta da upalim i ugasim auto pa kapiram da akumulator ima snage ali mi nije jasno zasto alternator nece da puni dok ne dobije malo struje sa drugog akumulatora. Link to post Share on other sites
StunterSM 0 Posted December 9, 2013 Report Share Posted December 9, 2013 alternator Link to post Share on other sites
Vlada88 0 Posted December 9, 2013 Author Report Share Posted December 9, 2013 Servisirao sam ga vec i bio sam opet kod tog elektricara stoga je radio i on nije mogao da njadje problem, kao sve puni kako treba... nije iskljuceno doduse da je elektricar "los" posto se ja u struju razumem kao marica u kriv k**** Link to post Share on other sites
StunterSM 0 Posted December 9, 2013 Report Share Posted December 9, 2013 Kod bokija na e46 sija lampica a puni, ali ne puni dovoljno, tacnije ispod 12.5 E sad, racunam da je to kod tebe problem, ne puni dovoljno Link to post Share on other sites
Vlada88 0 Posted December 9, 2013 Author Report Share Posted December 9, 2013 Ok, a zasto pocne da puni normalno tj. prestane da trepce lampica kada na bukvalno sekund bude spojen sa drugim akumulatorom preko kablova? Ne znam kako to moze da utice na punjenje alternatora, ako je to problem naravno. Link to post Share on other sites
StunterSM 0 Posted December 9, 2013 Report Share Posted December 9, 2013 Moze, jer mu drugi auto digne napon, to mi je onako logicno jel? Link to post Share on other sites
vranjin 0 Posted December 9, 2013 Report Share Posted December 9, 2013 Verovatno tad tek pusti pobudu. Zameni alternator mada je mozda samo regler. Link to post Share on other sites
bemveac 0 Posted December 9, 2013 Report Share Posted December 9, 2013 izmeri punjenje sa upaljenim autom i popali vece potrosace! ako je ispod 14 onda zameni regler na altenatoru! Link to post Share on other sites
Vlada88 0 Posted December 9, 2013 Author Report Share Posted December 9, 2013 Pa vec sam nenjao sve to... znaci u principu alternator je? Necu nista da menjam, uzecu negde drugi polovan... zaista vise sa ovim ne zelim da petljam, zivce mi je pojeo... Link to post Share on other sites
StunterSM 0 Posted December 10, 2013 Report Share Posted December 10, 2013 Ma remontuj, znaju majstori sta rade... Svaki dan cujem od nekog kako je remontovao a opet ga neste "jebe" i sigurno nije alternator jer je remontovan... Link to post Share on other sites
BMW_E30 0 Posted February 27, 2014 Report Share Posted February 27, 2014 Ako moze pomoc u vezi anlasera, u pitanju je skuter 50 ccm. Imam sledeći problem, zamenio sam četkice na anlaseru i kupio novi akumulator 12v 4ah 20A (veci ne moze da stane, skuter je kinez, a masina Piaggio Free), i motor vergla ali nece da upali. Kada povezem akumulator od kola upali, da li je akumulator preslab ili je moguće da četkice nisu adekvatne? Link to post Share on other sites
