Indorile 0 Posted January 14, 2015 Author Report Share Posted January 14, 2015 Nabavih crnu "komorastu" lasnu sto ide na podbranik, te mi je od spolja ostalo da nabavim maglenke, eventualno bubrege u crno + is lip, mada se nesto cimam da bih ga svugde kacio. Motor jos malo pa presao 1000, te uskoro ide na dotezanje i menjazu ulja pa cemo znati kolko poteze od 0 do 100 :D Taman i prednja sedista kod Zokijevog prijatelja da resimo. Link to post Share on other sites
ZoranM 0 Posted January 14, 2015 Report Share Posted January 14, 2015 :thumbsup: :thumbsup: :thumbsup: Link to post Share on other sites
pepsy 0 Posted January 15, 2015 Report Share Posted January 15, 2015 Kol'ko para lajsna, ako nije tajna? Dobro izgleda! Link to post Share on other sites
BugerMan 0 Posted January 16, 2015 Report Share Posted January 16, 2015 Ubica je, nista mu ne bi dirao sem sto bi dodao maglenke. :D Daj neki snimak da cujemo tu azdaju. :D Link to post Share on other sites
Indorile 0 Posted January 16, 2015 Author Report Share Posted January 16, 2015 Dve crvene je lajsna :) Sledeci vikend ide na dotezanje, pa ce biti snimak i zvuka i ubrzanja, ne teram ga u obrtaje do tada :D Link to post Share on other sites
djapedjape 0 Posted January 17, 2015 Report Share Posted January 17, 2015 Lep auto nema sta ? Link to post Share on other sites
Indorile 0 Posted January 25, 2015 Author Report Share Posted January 25, 2015 Sklepali smo kozu najzad :) Link to post Share on other sites
pepsy 0 Posted January 25, 2015 Report Share Posted January 25, 2015 Odlicno je ispalo! U svemu ovome,po meni, bode oci crvena kozica oko rucice menjaca. Ubaci crnu kozicu sa crvenim savom da se slozi sa bojom auta i crvenim detaljima u istrument tabli i skini onu sivu boju oko casovnika i sa onog pravougonika pored polugica za ventilaciju i enterijer prva liga! ;) Link to post Share on other sites
Indorile 0 Posted January 29, 2015 Author Report Share Posted January 29, 2015 Malo nekog testiranja danas, zakljucak da dole povlaci opasno dok se gore gusi. Vrlo verovatno da ga izduv gusi, moracu da izmerim precnik cevi izjutra. Link to post Share on other sites
StunterSM 0 Posted January 29, 2015 Report Share Posted January 29, 2015 Jesi menjao filter goriva? Link to post Share on other sites
Indorile 0 Posted January 29, 2015 Author Report Share Posted January 29, 2015 Pre nekih ~2500 km. Link to post Share on other sites
BOX 0 Posted January 29, 2015 Report Share Posted January 29, 2015 Zar ne bi trebalo jos bolje da povlaci? Ovo mi se cini onako, nista specijalno ili ga nisi bas poterao kako treba brate? Link to post Share on other sites
Indorile 0 Posted January 29, 2015 Author Report Share Posted January 29, 2015 Prvi poteg je iz prve, ostalo je sve iz druge. Do 4 hiljade ide, posle kao da vrti u prazno (a posle 4k bi trebao da je najjaci), glavna sumnja mi je auspuh s'obzirom da mi je Pirke uradio neku varijantu koja je dovoljna za 2.0, da bi ispalo jeftinije (je uvek skuplje). Link to post Share on other sites
NS_320i 0 Posted January 30, 2015 Report Share Posted January 30, 2015 Vidis kako dimi napred kod motora verovatno ti pusta dihtung izduvne grane ili negde imas rupu na grani ako si stavljao od nje do kraja novo, bar mi tako deluje na snimku. Kocka bas lepo izgleda jedino bi zamenio kozicu menjaca i stavio fabricku rucicu ili od e36... Link to post Share on other sites
Moki88 0 Posted January 30, 2015 Report Share Posted January 30, 2015 Aj opisi malo detaljnije sta je tacno radjeno oko motora,struja,dizne,komp... Nesto tu ne stima deluje mi kao da moj 2.0 brze napuni prva druga... Link to post Share on other sites
Indorile 0 Posted January 30, 2015 Author Report Share Posted January 30, 2015 Izmerio sam cev danas, spoljni precnik je 52, sto ce reci da je iznutra 50, a to je jelte malo. Trenutno sto je odradjeno jeste busenje bloka na 84mm, radilica od 2.4 dizela, klipovi i klipnjace od m70, karike dihtunzi i lezajevi novo, dakle posao oko samog motora. Ostalo nije dirano za sada, ali ce ici usis od 2.5 zasigurno dok ce glava 2.5 i ubrizgavanje 3.5 sacekati malo (vise). Sad treba da vidim sa Pirketom sta raditi oko izduva, jel moze da se stavi veca cev ili mora sve komplet da se menja. Edit: Do 4 hiljade (gde treba da napravi max moment) ga zavrti ko 2.0 do blokade, ali posle kao da ne proizvodi snagu. Do 100 ako ga vrtim do 4k i promenim 5 brzina isto stigne kao kad ga vrtim do 6 i kusur i promenim 3. Link to post Share on other sites
325ixA 0 Posted January 31, 2015 Report Share Posted January 31, 2015 A mapa od redovnog motora? Link to post Share on other sites
StunterSM 0 Posted January 31, 2015 Report Share Posted January 31, 2015 Ako ti fali goriva spalices motor vozeci ga tako Link to post Share on other sites
FILIP-M3 0 Posted January 31, 2015 Report Share Posted January 31, 2015 dimi dimi sta se dimi :D Link to post Share on other sites
Glisa 0 Posted January 31, 2015 Report Share Posted January 31, 2015 dimi dimi sta se dimi :D Pusnjara bas nesto i to plavooo :blink: :blink: Link to post Share on other sites
Indorile 0 Posted January 31, 2015 Author Report Share Posted January 31, 2015 Ma menjao sam klinaste pa je majstor prilikom vadjenja hladnjaka malo zalio motorni prostor, otuda dim spreda :) Elem za nedelju dve radim izduv 60, pa cemo videti kako ce se tada ponasati. Link to post Share on other sites
NS_320i 0 Posted February 1, 2015 Report Share Posted February 1, 2015 Pa jel vidis na snimku kako punis gas tako istim ritmom izbacuje dim napred, proveri izduvnu i taj dihtug izduvne zameni ako treba kostao je nesto smesno kad sam ja uzimao pre dve godine ~800din koliko se secam... I sto kaze 325ixA mapa ne moze stara i dizne ako su stock imaju slab protok Link to post Share on other sites
Moki88 0 Posted February 2, 2015 Report Share Posted February 2, 2015 U principu nista nisi uradio dok ne stavis 2.5 glavu i ubrizgavanje... Link to post Share on other sites
Indorile 0 Posted February 24, 2015 Author Report Share Posted February 24, 2015 Elem jedan klip je pobrljavio pa je onako bangavo isao, sredismo to i sada ide lepse :) Dizne su tu, cekaju se suske za usis pa sve to lepo da montiramo i bice druga prica. U medjuvremenu smo i maglenke nabacili, sad iauto izgleda ozbiljnije. Link to post Share on other sites
StunterSM 0 Posted February 24, 2015 Report Share Posted February 24, 2015 Sad je vec to to, jbg tako ozbiljan auto da ima poklopce nema smisla B) Link to post Share on other sites
