ntesic 0 Posted June 11, 2014 Report Share Posted June 11, 2014 U pitanju je E53 3.0D 2005 godiste. Kada upalim auto i ukljucim klimu na MAX da hladi i cekam cak i 20 minuta, ne ohladi nista, duva vruce. Cim pocnem da vozim odmah pocinje hladan vazduh. Da li je to normalno tako ili nesto nije kako treba? Link to post Share on other sites
bokibmw 0 Posted June 11, 2014 Report Share Posted June 11, 2014 a sta cemo za ventilator klime...kad on ne radi ... vidis sta kaze covek cim se pokrene klima hladi..hladnjak klime greje i hladnjak vode ..i pregreva sistem.. Link to post Share on other sites
ntesic 0 Posted June 11, 2014 Author Report Share Posted June 11, 2014 a sta cemo za ventilator klime...kad on ne radi ... vidis sta kaze covek cim se pokrene klima hladi..hladnjak klime greje i hladnjak vode ..i pregreva sistem.. Cekaj, mislis da je problem ventilator klime? Da je on otisao? Link to post Share on other sites
leon63 0 Posted June 11, 2014 Report Share Posted June 11, 2014 U pravu je Boki, moja greska. Link to post Share on other sites
ntesic 0 Posted June 11, 2014 Author Report Share Posted June 11, 2014 Teracu ga onda kod nekog majstora da vidimo sta moze da se napravi ili da se stavlja drugi Link to post Share on other sites
crni82 0 Posted June 11, 2014 Report Share Posted June 11, 2014 druze i meni ventilator nije radio na e39 pa je klima hladila i u mestu i kad se auto vozao, nema veze sa tim, nesto drugo je problem, jesi pokusao da zakacis na dijagnozu Link to post Share on other sites
ntesic 0 Posted June 11, 2014 Author Report Share Posted June 11, 2014 Nisam stigao jos, moracu ovih dana da iscimam nekog za INPU da pozajmim Link to post Share on other sites
bokibmw 0 Posted June 11, 2014 Report Share Posted June 11, 2014 meni ne radi vent klime i u mestu isto imam problem kad ga przimo onda radi...sad je stvar koliko dugo.. ako na inpi izbaci electric fan gresku to je Link to post Share on other sites
ntesic 0 Posted June 11, 2014 Author Report Share Posted June 11, 2014 Nego leone jer ima neko u Nisu koji bi mogao da mi sredi to? Posalji mi na PM broj/adresu, ili mozes i ovde, mozda ce trebati nekom Link to post Share on other sites
leon63 0 Posted June 11, 2014 Report Share Posted June 11, 2014 0692810355 moj broj. Link to post Share on other sites
ntesic 0 Posted June 11, 2014 Author Report Share Posted June 11, 2014 Znas da sredis to? Link to post Share on other sites
leon63 0 Posted June 11, 2014 Report Share Posted June 11, 2014 Imam ja INPU, Car soft, Scener BMW. Nije problem. Link to post Share on other sites
ntesic 0 Posted June 11, 2014 Author Report Share Posted June 11, 2014 Ma ok, INPU cu naci lako, nego mi treba neko ko bi mogao da eventualno resi kvar Link to post Share on other sites
pak76 0 Posted June 11, 2014 Report Share Posted June 11, 2014 A da dopunis klimu za pocetak. Dok stoji auto mali broj obrtaja pokrece kompresor a kada das gas onda kompresor nabija brze pritisak i hladi bolje. Link to post Share on other sites
StunterSM 0 Posted June 12, 2014 Report Share Posted June 12, 2014 Postoji presostat, i kad fali freona ne ukljucuje kompresor jer bi isti tada riknuo. Boki je u pravu, upali klimu i vidi jel prednji ventilator vrti. Ako ne, onda je otisao Link to post Share on other sites
vranjin 0 Posted June 12, 2014 Report Share Posted June 12, 2014 Postoji presostat, i kad fali freona ne ukljucuje kompresor jer bi isti tada riknuo. Boki je u pravu, upali klimu i vidi jel prednji ventilator vrti. Ako ne, onda je otisao +1 Digni haubu i vidi da li ti radi ventilator. Ako ne radi pogledaj osigurac. Ako je osigurac ok onda je ventilator. Ima i na tom ventilatoru JEZ (nije isti kao ona morgana ali ima istu funkciju), nije leon63 omasio :) . Link to post Share on other sites
dredger 0 Posted June 12, 2014 Report Share Posted June 12, 2014 A da dopunis klimu za pocetak. Dok stoji auto mali broj obrtaja pokrece kompresor a kada das gas onda kompresor nabija brze pritisak i hladi bolje. Pobornik sam ove teorije. I meni je slabo hladila kad stoji auto maltene nikako , dok je u voznji bilo skroz korektno. kad sam dopunio, hladi full i u mestu kad radi. Link to post Share on other sites
vranjin 0 Posted June 12, 2014 Report Share Posted June 12, 2014 Moze da mu fali freona a mozda i ne, nije ovo stopostotni simptom. Da li mu radi ventilator, to moze sam proveriti. edit Moze mu biti i jedno i drugo. Hoce kod bmw-a da crkne regulator na motoru ventilatora. Link to post Share on other sites
AlexBMW 0 Posted June 12, 2014 Report Share Posted June 12, 2014 A da dopunis klimu za pocetak. Dok stoji auto mali broj obrtaja pokrece kompresor a kada das gas onda kompresor nabija brze pritisak i hladi bolje. Bas tako, samo to je problem. Link to post Share on other sites
Glisa 0 Posted June 13, 2014 Report Share Posted June 13, 2014 Da pitam ujedno ovde. Drugar ima E39,kada smo krenuli za Cacak izbilo mu je crevo od klime sto ide na hladnjak ispred. Sve je izaslo i zadimilo,malo je falilo da zapali auto,barem je meni tako delovalo...sta je se tu desilo...nije valjda moguce da je napravilo neki cep u sistemu :blink: :blink: Link to post Share on other sites
325ixA 0 Posted June 13, 2014 Report Share Posted June 13, 2014 otvori posebnu temu za problem koji nema nikakve veze sa ovim. Link to post Share on other sites
ntesic 0 Posted July 1, 2014 Author Report Share Posted July 1, 2014 Ipak je ventilator klime otisao. Sada trazim polovan. Ako ima neko neka mi posalje PM sa cenom Link to post Share on other sites
bokibmw 0 Posted July 1, 2014 Report Share Posted July 1, 2014 i sta sam rekao? Imam isti problem na mom autu javi mi se na pm Link to post Share on other sites
ntesic 0 Posted July 1, 2014 Author Report Share Posted July 1, 2014 i sta sam rekao? Imam isti problem na mom autu javi mi se na pm Imas PM Link to post Share on other sites
bokibmw 0 Posted July 2, 2014 Report Share Posted July 2, 2014 video sam Link to post Share on other sites
