darec032 0 Posted December 19, 2014 Report Share Posted December 19, 2014 Prilikom prvog ukljucivanja brisaca, ne bitno u koju poziciju, nastavljaju da rade iako je rucica vracena u nulti polozaj. Tako radi minut, dva i stane. Nakon toga se ponasaju normalno. Da li je modul u pitanju? Link to post Share on other sites
777.boban 0 Posted December 19, 2014 Report Share Posted December 19, 2014 jeste Link to post Share on other sites
darec032 0 Posted December 19, 2014 Author Report Share Posted December 19, 2014 Hvala na brzom odgovoru... :preved: Link to post Share on other sites
wice 0 Posted December 20, 2014 Report Share Posted December 20, 2014 kod drugara na e36 radi samo najbrza bryina,da li je modul i kod njega? Link to post Share on other sites
777.boban 0 Posted December 20, 2014 Report Share Posted December 20, 2014 kod drugara na e36 radi samo najbrza bryina,da li je modul i kod njega? Modul,rucica ili namotaji samog motora. Link to post Share on other sites
kosmajac1 0 Posted December 26, 2014 Report Share Posted December 26, 2014 Da ne otvaram novu temu imam problem sa brisacima nekad rade normalno nekkad zaglave na pola a u drugoj brzini rade uvek.. koliko sam iscitao na forum problem je najverovatnije u modulu ili releju ako he to isto? sad mene zanima gde se nalazi taj modul.. Link to post Share on other sites
777.boban 0 Posted December 26, 2014 Report Share Posted December 26, 2014 Da ne otvaram novu temu imam problem sa brisacima nekad rade normalno nekkad zaglave na pola a u drugoj brzini rade uvek.. koliko sam iscitao na forum problem je najverovatnije u modulu ili releju ako he to isto? sad mene zanima gde se nalazi taj modul.. ispod kasete Link to post Share on other sites
crni82 0 Posted December 26, 2014 Report Share Posted December 26, 2014 imam dva modula, poklanjam oba dzabe Link to post Share on other sites
kosmajac1 0 Posted December 26, 2014 Report Share Posted December 26, 2014 Treba mi jedan da probam i ako moze objasnjenje kako da dodjem do njega?hvala Link to post Share on other sites
crni82 0 Posted December 26, 2014 Report Share Posted December 26, 2014 meni su ostali od tds-a stojalisu ispod suvozacevih nogu kad se skine ona plastika ovo ventilacije za noge. ako si u bg javi se pa uzmi probaj Link to post Share on other sites
kosmajac1 0 Posted December 26, 2014 Report Share Posted December 26, 2014 Ja sam iz barajeva pa ajd da se cujemo pa da se nadjemo da uzmem da probam... Link to post Share on other sites
crni82 0 Posted December 27, 2014 Report Share Posted December 27, 2014 NIJE PROBLEM JAVI SE SUTRA PA DODJI ILI MOZE I VECERAS ALI POSLE 18I30 060 34 23 733 Link to post Share on other sites
smg 0 Posted December 29, 2014 Report Share Posted December 29, 2014 Kaseta se dosta lako skida, imaš na ovom videu: Sam modul bi trebao da se nalazi pod rednim brojem 7 na sledećoj slici: Link to post Share on other sites
kosmajac1 0 Posted February 1, 2015 Report Share Posted February 1, 2015 OPET JA sa brisacima skidao sam danas kasetu i nisam nasao nesto tako ima sa desne strane komp. Na "podu" je kao neko pojacalo a levo uzduzno stoji neka kao tabla ili sta vec i na nju dolazi gomila zica al nisam skidao nekako mi krto deluje pa reko da ne polomim. Pa jel se na nkoj nalaze ti moduli ili? Link to post Share on other sites
darec032 0 Posted February 1, 2015 Author Report Share Posted February 1, 2015 Ovaj plavi konektor je nakacen na modul brisaca. Link to post Share on other sites
kosmajac1 0 Posted February 1, 2015 Report Share Posted February 1, 2015 Ok a kako ja da dodjem do njega jel on stoji u toj crnoj kutiji uzduzno postavljenoj ili? posto sam ja nju samo video unutra i svi konektori su crni sto ulaze u nju e sad ako ona ima neku zastitnu plastiku preko nje jedino... ako moze neko obkasnjenje kako da je skinem posto sam probao i deluje mi jako nezno.... Link to post Share on other sites
darec032 0 Posted February 1, 2015 Author Report Share Posted February 1, 2015 Aj slikaj kako je kod tebe... Kad skines kasetu, ispod treba da ti je ovako kao sa slike... Skines plavi konektor (povlacis u levu stranu i nazad, to mu je mehanizam za zakljucavanje) i videces jedan zub sto ga drzi. Taj zub pritegnes i izvuces modul. Link to post Share on other sites
kosmajac1 0 Posted February 1, 2015 Report Share Posted February 1, 2015 Imam sliku ali neznam kako da je ubacim sa telefona a komp mi u sok sobi:-) Link to post Share on other sites
kosmajac1 0 Posted February 1, 2015 Report Share Posted February 1, 2015 http://postimg.org/image/yxffmaz6l/ Link to post Share on other sites
kosmajac1 0 Posted February 1, 2015 Report Share Posted February 1, 2015 http://postimg.org/image/a2vxs8ecd/ Link to post Share on other sites
darec032 0 Posted February 1, 2015 Author Report Share Posted February 1, 2015 Nista mi ovde nije jasno. :mellow: Link to post Share on other sites
kosmajac1 0 Posted February 1, 2015 Report Share Posted February 1, 2015 To je sve sto ima lad skinem kasetu da nije mozda na nekom drugom mestu. Jer ima i ispod volana nekih releja...pope mi se na glavu vise taj brisac u zadnje vreme samo najbrza brzina radi i to moram da kad iskljucujem da iskljucim u donjem polozaju kad legme na pocetnu poziciju inace ako ga pre ugasim on ostaje de ga ugasim Link to post Share on other sites
Sutlandjanin 0 Posted February 1, 2015 Report Share Posted February 1, 2015 MEni lici da je neki doktor vec ovo sve izlomio vidis da je vezano sa vezicama nesto boze ti sacuvaj. Link to post Share on other sites
wice 0 Posted February 1, 2015 Report Share Posted February 1, 2015 skoro je kolega imao isti problem i problem je bio u osiguracu,tj bio je ispravan ali je imao los kontakt Link to post Share on other sites
