darec032 0 Posted January 19, 2015 Report Share Posted January 19, 2015 Kupio sam modul za daljinsko zakljucavanje. Gledao sam na Youtube-u nesto sto se tice povezivanja, lik je povezao modul direktno na modul centralne. E sad, negde sam citao da se ugradjuju dodatni releji, pa me zanima kako je najbolje povezati? Ako moze neka sema, jos bolje bi bilo. A da, jel okida na plus ili na minus? Link to post Share on other sites
vranjin 0 Posted January 19, 2015 Report Share Posted January 19, 2015 Najbolje je povezati prema uputstvu doticnog daljinskog. Razumes sta hocu da kazem :) Link to post Share on other sites
darec032 0 Posted January 19, 2015 Author Report Share Posted January 19, 2015 Znam, znam... ako je na semi daljinskog nacrtano da ide tu i tu, tako da stavim i da ne izmisljam toplu vodu :D Jos samo da saznam je zakljucava na masu ili na plus? Link to post Share on other sites
vranjin 0 Posted January 19, 2015 Report Share Posted January 19, 2015 Motorici su mu stalno na minusu, oba kraja, i zavisno da li otkljucava ili zakljucava pusta plus. Link to post Share on other sites
darec032 0 Posted January 19, 2015 Author Report Share Posted January 19, 2015 Znaci njega plus zakljucava i otkljucava... Da ubodem pravu semu... Link to post Share on other sites
vranjin 0 Posted January 19, 2015 Report Share Posted January 19, 2015 Da ali tu gde pustis plus moras prekimuti minus. Ako samo daljinsko to ne moze onda pomocu relea. Link to post Share on other sites
darec032 0 Posted January 19, 2015 Author Report Share Posted January 19, 2015 Ne verujem da daljinsko to moze... mada ako povezem da dobija signal kao da se otkljucava kljucem onda bi trebalo da moze bez releja? :) Link to post Share on other sites
vranjin 0 Posted January 19, 2015 Report Share Posted January 19, 2015 verovatno da mozes tako. Jel imas neki papir od tog daljinskog? Link to post Share on other sites
darec032 0 Posted January 19, 2015 Author Report Share Posted January 19, 2015 Samo semu za povezivanje... Link to post Share on other sites
smg 0 Posted January 20, 2015 Report Share Posted January 20, 2015 Druže, zavisi od godišta auta, tj koji ti je ZKE. Ne znam od kada se zke IV ugrađuje u kola. A kako se ugrađuje modul, zavisi od toga da li na izlazu prekida - ili šalje + impuls. Evo ti šema kako bi trebalo da povežeš da ne prekidaš pin od vrata (obično ti takve šeme daju uz te daljinske). Link to post Share on other sites
smg 0 Posted January 20, 2015 Report Share Posted January 20, 2015 A ovo je šema za alarm koji je došao uz moja kola. Koliko sam uspeo da vidim ovako je povezan kod mene: Stim što meni leva vrata ne okidaju fabričku centralnu :( P.S. Ukoliko ti je sve ovo strano i mrzi te da se zanimaš (testiraš), nije loše ni da ga oteraš kod prvog električara, uzimaju oko 1k do 2k din da ti to lepo povežu. Link to post Share on other sites
vranjin 0 Posted January 20, 2015 Report Share Posted January 20, 2015 Ako ćeš ti da radiš daj tu šemu i podatke za kola. Mislim da bez obzira na godište motorici centralne su stalno na masi i ne sme prostim puštanjem plus a da radi jer će praviti kratak spoj. Link to post Share on other sites
darec032 0 Posted January 20, 2015 Author Report Share Posted January 20, 2015 To je sema od daljinskog. A auto je E36 325i 1991. god. Link to post Share on other sites
smg 0 Posted January 21, 2015 Report Share Posted January 21, 2015 Ja bih onako laički rekao da ti je potrebna šema E. Link to post Share on other sites
vranjin 0 Posted January 21, 2015 Report Share Posted January 21, 2015 Šema E mu treba. Link to post Share on other sites
darec032 0 Posted January 21, 2015 Author Report Share Posted January 21, 2015 Prvo sam mislio da treba B. ali kad si rekao da je uvek na minusu, pa se prekida plusem, onda sam se dvoumio izmedju B i E. :D Sad kad znam po kojoj semi da radim, nista nije problem :D Link to post Share on other sites
GrujaBG 0 Posted January 21, 2015 Report Share Posted January 21, 2015 Ja sam čuo da ne može na modul, tj moj, direktno da se poveže (e36 kupe 11/93) pa je električar to rešio tako što se nakačio na instalaciju suvozačke brave pa što se modula tiče neko je samo otključao na ključ. Ako ne uspeš direktno razmišljaj u ovom smeru. Link to post Share on other sites
darec032 0 Posted January 21, 2015 Author Report Share Posted January 21, 2015 Pa po ovoj semi (sema E) se izmedju brave i modula ubacuje modul daljinskog... :rolleyes: Link to post Share on other sites
GrujaBG 0 Posted January 21, 2015 Report Share Posted January 21, 2015 Nisam pratio šeme, samo kažem uopšteno. Link to post Share on other sites
vranjin 0 Posted January 22, 2015 Report Share Posted January 22, 2015 Ima tu jos jedna skakljiva stvar :) . Motoric ima tri prikljucka. Da ima dva bilo bi lako, samo se preseku zice i ubaci se daljinski. Ovako, kad budes poceo da radis moraces da ispitas neka stanja i onda da povezujes. Nisam siguran da li neki kontakti ostaju prebaceni. Dacu ti broj telefona pa da se cujemo. Link to post Share on other sites
smg 0 Posted January 22, 2015 Report Share Posted January 22, 2015 Taj treći je nešto POSTN signal. Nikako nisam mogao da nađem na netu šta tačno znači POSTN :( Link to post Share on other sites
darec032 0 Posted January 22, 2015 Author Report Share Posted January 22, 2015 Evo je sema od centralnog... Plavo sam oznacio motoric vozacevih vrata. Zica 1 i 2 - zakljucavanje, otkljucavanje, a zica 3 centralno zakljucavanje, sta god da znaci :D Link to post Share on other sites
vranjin 0 Posted January 22, 2015 Report Share Posted January 22, 2015 O tome ti pricam :D . Morace malo da se cacka da se vidi sta i kako radi. Link to post Share on other sites
darec032 0 Posted January 22, 2015 Author Report Share Posted January 22, 2015 A za sta sluzi ova treca zica? tj, mozes li da pretpostavis? :D Link to post Share on other sites
vranjin 0 Posted January 22, 2015 Report Share Posted January 22, 2015 Pretpostavljam da kad zaključa prebaci kontakt na tu treću i onda na nju treba dovesti impuls za otkljucavanje. To ćeš morati da utvrdis. Link to post Share on other sites
