pimp 0 Posted July 2, 2015 Report Share Posted July 2, 2015 Pre neki dan pri kocenju osetim kada drugi treci put pritisnem pedalu, pedala je tvrda. Skinem check valve sa serva vidim usisasa,ima vakuma. Ali ima i ulja malo. Ispostavi se da ima ulja i u servu.. Sta je otislo vacum pumpa, check ventil ? U pitanju je N42 motor. Hvala. Link to post Share on other sites
NINO BMW 0 Posted July 2, 2015 Report Share Posted July 2, 2015 Vakum pumpa,već se deavalo na N42 motorima. Link to post Share on other sites
pimp 0 Posted July 2, 2015 Author Report Share Posted July 2, 2015 Citao sam po raznim forumima, al nikako da provalim da li je pumpa, ili cak CCV. Posto vidim da pominju i njega. Kazu kada se on zapusi, stvara pritisak koji vraca u motor, i zbog toga odu dihtunzi na pumpi, dekli, filteru ulja. Da li je moguce da zbog CCVa baca ulje u vacum ? Hvala Nino na odgovoru. I da li je servo ok zbog ulja u njemu ? Link to post Share on other sites
pimp 0 Posted July 2, 2015 Author Report Share Posted July 2, 2015 Koliko je vacum pumpa nova ? Ili da jurim polovnu. Link to post Share on other sites
NINO BMW 0 Posted July 2, 2015 Report Share Posted July 2, 2015 To se kupuje polovno,50e se kreću. Link to post Share on other sites
pimp 0 Posted July 2, 2015 Author Report Share Posted July 2, 2015 Hvala jos jednom. Nadam se da servo nije otisao od ulja u njemu. Kako se proverava vacum pumpa ? Sutra je skidam pa da vidim. Link to post Share on other sites
NINO BMW 0 Posted July 2, 2015 Report Share Posted July 2, 2015 Smiri zivce pred pocetak posla ako sam radis ili se ne iznenadjuj ako ti majstor naplati vise nego si ocekivao ukoliko placas rad.Skidanje vakum pumpe na N42 motoru je komplikovano. Link to post Share on other sites
pimp 0 Posted July 2, 2015 Author Report Share Posted July 2, 2015 Skidao je vec pre pola godine da je predihtujem preventivno. Skidanje i ajde, al vracanje :) . Hvala ti na savetima. Verovatno je otisao onaj nepovratni ventil na samoj pumpi. Ali sutra cu znati sve :) Link to post Share on other sites
Nidza crveni 0 Posted July 2, 2015 Report Share Posted July 2, 2015 Smiri zivce pred pocetak posla ako sam radis ili se ne iznenadjuj ako ti majstor naplati vise nego si ocekivao ukoliko placas rad.Skidanje vakum pumpe na N42 motoru je komplikovano.bas me cudi to je vrhunski motor Link to post Share on other sites
Zeljkamp 0 Posted July 2, 2015 Report Share Posted July 2, 2015 Off : Ajde, molim te, odgovori mi kakve veze ima vakum pumpa sa agregatom ? On : Pored vakum pumpe glavni vakum uredjaj zna da pravi probleme. Cena polovnih delova je oko 50e a ruke su oko 10-20e, zavisi kod koga ugradjujes. Skidanje nije komplikovano ali ovdasnji majstori vole da posole pricu kako bi za posao od 30-45 minuta uzeli vise para. Zamena glavnog vakum uredjaja traje malo jace od sat vremena. Link to post Share on other sites
pimp 0 Posted July 3, 2015 Author Report Share Posted July 3, 2015 @Nidza Vrhunski motor :) @Zeljkamp Uglavnom sve sto mogu radim sam na autu, imam alat, to je bitno, volju, internet da vidim sta kako :) . Jel si ti resio kod tebe ? Znam da je i tebe zezalo. Link to post Share on other sites
Nidza crveni 0 Posted July 3, 2015 Report Share Posted July 3, 2015 Off : Ajde, molim te, odgovori mi kakve veze ima vakum pumpa sa agregatom ? On : Pored vakum pumpe glavni vakum uredjaj zna da pravi probleme. Cena polovnih delova je oko 50e a ruke su oko 10-20e, zavisi kod koga ugradjujes. Skidanje nije komplikovano ali ovdasnji majstori vole da posole pricu kako bi za posao od 30-45 minuta uzeli vise para. Zamena glavnog vakum uredjaja traje malo jace od sat vremena. pa vidis da ima,taj agregat sprica ulje u usis posto ga i trosi kao lud.a sad ti meni reci sta ce ulje u usisu? Link to post Share on other sites
pimp 0 Posted July 3, 2015 Author Report Share Posted July 3, 2015 I ne trosi nesto puno ulja kada je se u redu. Na 10000km meni potrosi 4dcl. Od max dodje do min. Sto je skroz prihvatljivo. Do duse ja sam 80% voznje na otvorenom, i nemam tesku nogu. Link to post Share on other sites
pimp 0 Posted July 3, 2015 Author Report Share Posted July 3, 2015 Ulje je Motul 5w-40 BMW LL04 Link to post Share on other sites
marko84 0 Posted July 3, 2015 Report Share Posted July 3, 2015 @Zeljkamp ja moram da pitam, sto se ti uvek osetis prozvano kad neko spomene N42 motor u negativnom kontekstu? Link to post Share on other sites
325ixA 0 Posted July 3, 2015 Report Share Posted July 3, 2015 zato sto ima taj motor u kolima i nema problema a ne shvata da ga dzoni namerno prcka Link to post Share on other sites
Nidza crveni 0 Posted July 3, 2015 Report Share Posted July 3, 2015 Ne nego je jedan od 1000 koga sluzi taj motor Link to post Share on other sites
pimp 0 Posted July 11, 2015 Author Report Share Posted July 11, 2015 Danas skinuo servo, i bilo je bar deci ulja u njemu. Ko zna od kada je pustalo. Jel je ulje ostetilo servo ? Link to post Share on other sites
Miki s38 0 Posted July 13, 2015 Report Share Posted July 13, 2015 I ne trosi nesto puno ulja kada je se u redu. Na 10000km meni potrosi 4dcl. Od max dodje do min. Sto je skroz prihvatljivo. Do duse ja sam 80% voznje na otvorenom, i nemam tesku nogu. Od max do min imas litar Link to post Share on other sites
pimp 0 Posted September 5, 2015 Author Report Share Posted September 5, 2015 Da javim. Najzad stigla i stavljena nova Vacum pumpa Pierburg, polovan servo pojacivac jer je stari otisao od ulja, promenjeno kociono ulje, izbacen vazduh i sad pun gas :) Hvala svima. Link to post Share on other sites
La Haine 0 Posted July 18, 2019 Report Share Posted July 18, 2019 Pozdrav od tvrde pedale kocnice. @pimp gde je bio problem burazeru, na vezi sam sa Deltom da vidim servo koliko kosta, cekam mail, ima i polovnih... Imam neki vakum na crevu, nije preterano jak, ali ga ima, nepovratni ventil na ulazu u servo je postao povratni.. Pozdrav i za @NINO BMW, videh, servis mu je na izlazu iz Pazara prema CG kod LukOil pumpe, ako nekom zatreba.. Link to post Share on other sites
La Haine 0 Posted July 18, 2019 Report Share Posted July 18, 2019 Стигао маил 50475,00 rsd , poručuje se avansno , po uplati profakture , rok isporuke 3-5 radnih dana Link to post Share on other sites
StunterSM 0 Posted July 18, 2019 Report Share Posted July 18, 2019 Vrh Link to post Share on other sites
La Haine 0 Posted July 18, 2019 Report Share Posted July 18, 2019 (edited) Sutra uzimam jedno 3 kom iz originala, da imam i da podglavim vrata od podruma da ne škripe☺️ Umeju da iznenade sa cenama. Edited July 18, 2019 by La Haine Link to post Share on other sites
La Haine 0 Posted July 20, 2019 Report Share Posted July 20, 2019 Proradilo je sve samo od sebe, 2 dana je ok..mozda je gubio vakum negde..sutra jedino da spustim nešto u šešir serva da vidim ima li ulja u njemu?? Drugi servo je poručen jbg, polovan. Da li je tralala da mu se spakuju veće kočnice, kad izleti ležeći negde, prelećem ga samo tako, nema sile da uštopuje.. Link to post Share on other sites
