iradic 0 Posted July 27, 2015 Report Share Posted July 27, 2015 Pozdrav svima. Već neko vreme svetla u autu se sama pale i gase. Auto radi normalno, vrata zatvorena, u toku vožnje...nema pravila. Šta da gledam, gde da krenem da tražim problem? Link to post Share on other sites
Sicko 0 Posted July 27, 2015 Report Share Posted July 27, 2015 Na pamet mi prvo pada da je otiso neki mikroprekidač Link to post Share on other sites
iradic 0 Posted July 28, 2015 Author Report Share Posted July 28, 2015 Gde se nalazi, u vratima pretpostavljam? Link to post Share on other sites
Sicko 0 Posted July 28, 2015 Report Share Posted July 28, 2015 Pa da.... Link to post Share on other sites
smg 0 Posted July 28, 2015 Report Share Posted July 28, 2015 Pretpostavljam da ti je mikroprekidač. Na e36 je na stubu za prednja vrata, u delu na koji se "zaključava" brava. Ako imaš od nekoga pozajmi pa probaj, lako se menja. Na zadnjim vratima je očigledan, i on češće odlazi. Možeš da ga probaš i tako što ćeš da ga otkačiš, ja mislim da oni spajaju masu kada su vrata otvorena ... Link to post Share on other sites
iradic 0 Posted July 28, 2015 Author Report Share Posted July 28, 2015 Tenkjuuu..... Probaću ovih dana.... Link to post Share on other sites
lacoste 0 Posted October 6, 2015 Report Share Posted October 6, 2015 Ja imam slican problem. Kada postavim prekidac u onaj polozaj gde bi trebalo da zavisi od toga da li su otvorena vrata, svetlo ostaje upaljeno bez obzira na vrata Link to post Share on other sites
vranjin 0 Posted October 6, 2015 Report Share Posted October 6, 2015 Probaj da ostavis jedno pola sata da vidis hoce li se ugasiti. Link to post Share on other sites
lacoste 0 Posted October 6, 2015 Report Share Posted October 6, 2015 Pa sta dobijam time? Link to post Share on other sites
vranjin 0 Posted October 6, 2015 Report Share Posted October 6, 2015 Ako vec ne znas onda slusas. Ako se posle 16 minuta ugase svetla onda verovatno ne rade neki od prekidaca u vratima. Ako se ne ugase neki spoj sa plusem ili ti crko generalni modul odnosno modul centralne, zavisi koje godiste. Link to post Share on other sites
lacoste 0 Posted October 7, 2015 Report Share Posted October 7, 2015 Nisam znao sta treba da cekam tih pola sata zato sam i pitao. '93 je auto. Cim mi ovi iz agencije za registraciju vrate auto uradicu ovo pa da vidim sta da mu radim. Hvala unapred :) Link to post Share on other sites
vranjin 0 Posted October 7, 2015 Report Share Posted October 7, 2015 Iskljucen kontakt i zatvorena sva vrata i gledaj. Link to post Share on other sites
iradic 0 Posted October 24, 2015 Author Report Share Posted October 24, 2015 Kod mene je malo bolja situacija sada. Iskontrolisao prekidače, i ništa se nije menjalo.Prebrljao sam po osiguračima, i ispalo je da je jedan falio.Od kada sam ga ubacio, više se ne dešava, osim kada baš jako kočim, onda se na trenutak upale. Znači ima i neki kontakt da zeza, samo treba da uhvatim vremena da pretresem svaku žicu, a to će biti otprilike nikad Link to post Share on other sites
ZoranM 0 Posted October 25, 2015 Report Share Posted October 25, 2015 nije to do žice, još te neki mikroprekidal zeza Link to post Share on other sites
777.boban 0 Posted October 25, 2015 Report Share Posted October 25, 2015 Kod mene je malo bolja situacija sada. Iskontrolisao prekidače, i ništa se nije menjalo. Prebrljao sam po osiguračima, i ispalo je da je jedan falio. Od kada sam ga ubacio, više se ne dešava, osim kada baš jako kočim, onda se na trenutak upale. Znači ima i neki kontakt da zeza, samo treba da uhvatim vremena da pretresem svaku žicu, a to će biti otprilike nikad Kad kocis pale se svetla u kabini? Link to post Share on other sites
vranjin 0 Posted October 25, 2015 Report Share Posted October 25, 2015 Pa to je neophodno, da suvozac vidi gde ce glavom da potegne :D Verovatno pod inercijom se pomeri ili prekidac ili dzek. Link to post Share on other sites
iradic 0 Posted October 25, 2015 Author Report Share Posted October 25, 2015 Kad kocis pale se svetla u kabini? Kad baš legnem na kočnicu, onda Verovatno pod inercijom se pomeri ili prekidac ili dzek. Upravo zato, jer se i dešava samo kad je jače kočenje. Link to post Share on other sites
hermes 0 Posted October 25, 2015 Report Share Posted October 25, 2015 Mikroprekidac je u pitanju, a pali se svetlo jer vrata ``rade`` u odnosu na karoseriju, pa je i to malo dovoljno kad je los mikroprekidac. A vrata se pomeraju kad jako kocis, kad silazis sa ivicnjaka i slicno. Obicno je na vozackim vratima problem, jer ta vrata su milion puta vise otvarana i zatvarana, pa se jednostavno potrosi prekidac. Link to post Share on other sites
ZoranM 0 Posted October 25, 2015 Report Share Posted October 25, 2015 kada je auto u radu,iznutra napni jako vrata prema van, jedna po jedna, i nacices koja zezaju Link to post Share on other sites
vranjin 0 Posted October 25, 2015 Report Share Posted October 25, 2015 Meni nisu pala na pamet klimava vrata :) . Kad je rec o tome vidi i da se nije izlizala plastika na prekidacu. Link to post Share on other sites
hermes 0 Posted October 25, 2015 Report Share Posted October 25, 2015 Ja na tu plastiku i mislim kad kazem prekidac :thumbsup: Link to post Share on other sites
lacoste 0 Posted November 11, 2015 Report Share Posted November 11, 2015 Izvinjavam se sto me nije bilo dugo, imao sam nekih obaveza pa nisam mogao da se javim. Mikroprekidac je u pitanju ali samo na prednjim vratima. Moze neka pomoc kako namestiti to? Link to post Share on other sites
StunterSM 0 Posted November 11, 2015 Report Share Posted November 11, 2015 Promenis ga Link to post Share on other sites
lacoste 0 Posted November 12, 2015 Report Share Posted November 12, 2015 Promenis ga Veoma duhovito. Gde se on nalazi? Link to post Share on other sites
777.boban 0 Posted November 13, 2015 Report Share Posted November 13, 2015 Nalazi se na stubu vozacevih vrata. Link to post Share on other sites
