dobrica 0 Posted July 28, 2015 Report Share Posted July 28, 2015 Mozda nekome zatreba Izracunavanje dimenzije guma Link to post Share on other sites
dredger 0 Posted July 28, 2015 Report Share Posted July 28, 2015 Nemoj da se ljutis, ali zesca glupost. Link to post Share on other sites
smg 0 Posted July 29, 2015 Report Share Posted July 29, 2015 A što je glupost? Mislim za nas sa jeftinijim ulaznicama :) Link to post Share on other sites
StunterSM 0 Posted July 29, 2015 Report Share Posted July 29, 2015 Dobra stvar, ali ima i boljih kalkulatorima sa jotazom felne, et i graficima da uporedis Link to post Share on other sites
Djoksa530i 0 Posted February 28, 2016 Report Share Posted February 28, 2016 Ovaj je dobar http://www.wheel-size.com/calc/?wheel1=225-45-17X8ET47&wheel2=245-40-18X8ET20&fcl=50mm&wcl=30mm&scl=50mm E sad pitanje , moze li na e46 245/40/18 ili je to preveliko? Link to post Share on other sites
La Haine 0 Posted October 31, 2017 Report Share Posted October 31, 2017 Da li moze da se razvuce 205 50 guma na tocak 17x8 cola tj da li ce da lici na nesto. 205 45 izgleda dobro ali je to malo za 46.. Ili mora 215 45, mozda je i to mali tocak? Link to post Share on other sites
Djoksa530i 0 Posted October 31, 2017 Report Share Posted October 31, 2017 Bez ikakavih problema, izgledace potpuno normalno. Meni su zimske 205/50, a letnje 225/45 na 8J Link to post Share on other sites
La Haine 0 Posted November 1, 2017 Report Share Posted November 1, 2017 fabrika! hvala. Link to post Share on other sites
miksa 0 Posted November 1, 2017 Report Share Posted November 1, 2017 meni su na 8j 235-45 letnja i izgleda lepo,normalno a na 8j 225-45 zimska i ne svidja mi se bas a 205 mislim da ce da izgleda jako ruzno,jer 8j=203,2mm a guma ti je 205mm,bocne strane gume ce gaziti po putu Link to post Share on other sites
Djoksa530i 0 Posted November 2, 2017 Report Share Posted November 2, 2017 Ne vidim logiku u ovom sto si napisao? 205 ce da "viri", a 235 je lepo na 8J? 205 ce biti malo strechovana ali potpuno normalno izgleda, slikacu danas i okaciti. Link to post Share on other sites
Indorile 0 Posted November 2, 2017 Report Share Posted November 2, 2017 205 je na ivici preporucenosti za 7.5 inca, moze ali nece da se ponasa lepo kao na 7 inca, realno na 8 inca bez 215 ne bi trebalo ici. Naravno pricamo o upravljivosti/korisnosti a ne dal ce il nece da izgleda "lepo", gume treba uvek gadjati da idu na "srednju" odgovarajucu sirinu felne. Da ne bude da izmisljam, inzenjeri iz Toyo-a su dali odobrene sirine felni za odredjene dimenzije guma http://www.toyo.co.uk/tirefinder Link to post Share on other sites
miksa 0 Posted November 2, 2017 Report Share Posted November 2, 2017 Djoksa,procitaj ponovo sta sam napisao. Nigde nisam napisao da ce nesto da viri. Napisao sam da je 8j=203,2mm i da guma od 205mm ima da bude kao jaje na toj felni,jer ce toliko da se razvuce da ce bocna strana gume nalegati po putu. Ajd molim te slikaj felnu od 8j i gumu od 205 na njoj,na autu dok stoji opterecena. Udji na kalkulator koji je ubacio indorile i pogledaj Za 205-50/17 preporuceno 6.5J Za 235-45/17 preporuceno 8J O tome pricam Link to post Share on other sites
Djoksa530i 0 Posted November 2, 2017 Report Share Posted November 2, 2017 205 - https://postimg.org/image/4mrn5y7pwr/ A ovo je 225 - https://postimg.org/image/60qxo5hs57/ Link to post Share on other sites
La Haine 0 Posted November 2, 2017 Report Share Posted November 2, 2017 Malo je rasirena na 205, meni je to dobro, ali nema te gume kod mene u gradu. 215 45 17 imam u radnji, ali cini mi se da je to mali tocak za e 46, i mislim da mora da bude bas spusten na gewindama.Auto mi je na oprugama -30/00 jbg Kako stoji 215 45 ne e46? Link to post Share on other sites
La Haine 0 Posted November 3, 2017 Report Share Posted November 3, 2017 On 10/31/2017 at 4:42 PM, Djoksa530i said: Bez ikakavih problema, izgledace potpuno normalno. Meni su zimske 205/50, a letnje 225/45 na 8J Hvala brate, to je to. Fabrika! Link to post Share on other sites
Gruja1595 0 Posted November 5, 2017 Report Share Posted November 5, 2017 Odstupanja..Sent from my SM-G935F using Tapatalk Link to post Share on other sites
