Marko 0 Posted May 7, 2016 Report Share Posted May 7, 2016 skini senzor, i ocisti ga, ja sam moj sa dizelom, i posle toga je radio ok :) Link to post Share on other sites
StunterSM 0 Posted May 7, 2016 Report Share Posted May 7, 2016 Samo ga ocisti, verovatno je i dzek napunjen uljem, a ono ne provodi struju. Probaj prvo dzek da ocistis. Kako Bobane nema, ima i moj m30 matori Sent from my iPhone using Tapatalk Link to post Share on other sites
BMW_E30 0 Posted May 8, 2016 Author Report Share Posted May 8, 2016 Ocisticu danas, pa se nadam da ce biti ok :) Link to post Share on other sites
777.boban 0 Posted May 8, 2016 Report Share Posted May 8, 2016 A jbg mislio sam da nema Samo ga ocisti, verovatno je i dzek napunjen uljem, a ono ne provodi struju. Probaj prvo dzek da ocistis. Kako Bobane nema, ima i moj m30 matoriSent from my iPhone using Tapatalk zadnji m20 sam izvadio iz mog auta davne 2007 god,a nisam ih vise ni kupovao kao strance,sad imam neki 2,5 ali je u autu i jbg pogresi covek :) A i logicno je da nesto mora da upali lampicu,ali nema veze malo sam glup danas Link to post Share on other sites
StunterSM 0 Posted May 8, 2016 Report Share Posted May 8, 2016 To su masine, ovo novo je samo komercijala Sent from my iPhone using Tapatalk Link to post Share on other sites
RadeM 0 Posted May 8, 2016 Report Share Posted May 8, 2016 Jel moram da radim prstenove za njih? Posto je valjda na e39 74 a kod mene 72 mm?Ne moras da imas prstenove,ali je pozeljno,ako to trebaju jedni javi se na pm,ostavio sam negde moje pa mozemo da se dogovorimo posto mi ne trebaju.Послато са SM-N915FY уз помоћ Тапатока Link to post Share on other sites
boris74 0 Posted May 8, 2016 Report Share Posted May 8, 2016 Prstenovi obavezno Link to post Share on other sites
BMW_E30 0 Posted May 8, 2016 Author Report Share Posted May 8, 2016 Napravio sam prstenove kod strugara :) Link to post Share on other sites
BMW_E30 0 Posted May 12, 2016 Author Report Share Posted May 12, 2016 Imam problem na autu sa gubitkom rashladne tecnosti. Curelo je na hladnjaku, zamenio sam hladnjak ali i dalje trosi vodu. Radjen je co2 test, nema izduvnih gasova u rashladnom sistemu. Ne vidi se nigde da curi, a trosi vodu i dalje. Da li je moguce da je otisla membrana na isparivacu i da tu trosi vodu i kako to da proverim? Link to post Share on other sites
FILIP-M3 0 Posted May 12, 2016 Report Share Posted May 12, 2016 I ja sam imao problem isti, zamenio hladnjak jer je vidno curelo, ali sam posle dosao i do malog hladnjaka Sent from my Asus Zenfon 2 Link to post Share on other sites
wice 0 Posted May 12, 2016 Report Share Posted May 12, 2016 Pa otkaci isparivac sa sistema pa vozi na benzin Link to post Share on other sites
BMW_E30 0 Posted May 12, 2016 Author Report Share Posted May 12, 2016 Ne radi na benzin kako treba, tako da ne mogu tako da isprobam :) Link to post Share on other sites
FILIP-M3 0 Posted May 12, 2016 Report Share Posted May 12, 2016 Meni su svi pricali mali hladnjak, i na kraju je bio stvarno Sent from my Asus Zenfon 2 Link to post Share on other sites
BMW_E30 0 Posted May 12, 2016 Author Report Share Posted May 12, 2016 Pogledacu ima li tragova unutra. Jel ti bio mokar tepih? Ipak meni trosi oko 0,5l posle svake voznje od 30ak km, moralo bi da se primeti. Link to post Share on other sites
FILIP-M3 0 Posted May 12, 2016 Report Share Posted May 12, 2016 U nije meni toliko trosio Sent from my Asus Zenfon 2 Link to post Share on other sites
BMW_E30 0 Posted May 19, 2016 Author Report Share Posted May 19, 2016 Ipak sam pogledao kod drugara na kanalu, sliva se pomalo pored vodene pumpe. Majstor kada je menjao ranije nije lepo zadihtovano na tom spoju izmedju pumpe i bloka. Da li da stavim samo hermetik kad skinem pumpu, ili da pravim i neki dihtung? Link to post Share on other sites
StunterSM 0 Posted May 19, 2016 Report Share Posted May 19, 2016 Kupis novu pumpu i ne mislis o dihtovanju polovne.. Sent from my iPhone using Tapatalk Link to post Share on other sites
BMW_E30 0 Posted May 19, 2016 Author Report Share Posted May 19, 2016 Pumpa je kupljena pre 4 meseca nova, ali je jedan sraf je bio duzi od ostalih i imao je tri podloske i majstoru su ispale dve podloske i onda kad je stegao pumpu tu nije lepo dihtovala pa je morao opet da skida i sjebao je dihtung koji je isao uz pumpu i stavio samo hermetik. E sad sta je meni bolje da napravim dihtung od klingerita ili da stavim hermetik? Posto sam zvao na par mesta za taj dihtung ali je rok isporuke oko 10ak dana a ja moram kola danas sutra da sredim :) Link to post Share on other sites
BMW_E30 0 Posted June 16, 2016 Author Report Share Posted June 16, 2016 Imam siroku masku, e sad jurim siroku haubu za E34 pa me zanima da li je sve isto od uske haube? Mislim na nosace gde se kaci hauba i na amortizer haube? Ili moram sve da nabavim od siroke haube? Link to post Share on other sites
777.boban 0 Posted June 16, 2016 Report Share Posted June 16, 2016 Sve je isto,imam haubu ako trazis Link to post Share on other sites
BMW_E30 0 Posted June 17, 2016 Author Report Share Posted June 17, 2016 Koliko para samo hauba bez maske? Link to post Share on other sites
777.boban 0 Posted June 17, 2016 Report Share Posted June 17, 2016 1 hour ago, BMW_E30 said: Koliko para samo hauba bez maske? Samo u setu sa maskom 80e Link to post Share on other sites
BMW_E30 0 Posted July 4, 2016 Author Report Share Posted July 4, 2016 Pale nove felnice image hosting without registration Link to post Share on other sites
StunterSM 0 Posted July 4, 2016 Report Share Posted July 4, 2016 I ja sam izabrao te, kraj price su Link to post Share on other sites
BMW_E30 0 Posted July 4, 2016 Author Report Share Posted July 4, 2016 Jesu najbolje Uzeo sam one od osmice prednje et10 opusteno su stale napred. Jos samo da ga spustim i bice extra Link to post Share on other sites
