speed01 0 Posted March 27, 2016 Report Share Posted March 27, 2016 Pozdrav ljudi. Kupio sam pre 10tak dana bmw e46 320ci coupe 2002 2.2L 125kw. Danas mi se pojavio problem jer mi nekada (ne uvek) na leru blicne crvena lampica od ulja, cim pipnem gas, tacnije prebacim 850-900 obrtaja ugasi se. Ima li neko ideju sta li moze biti? Hvala unapred. Link to post Share on other sites
Milan Dimke Dimitrijevic 0 Posted March 27, 2016 Report Share Posted March 27, 2016 Probaj da zamenis senzor pritiska ulja a ne bi bilo lose i filter ulja, to ako ne resi problem onda je pumpa ulja problem. Link to post Share on other sites
speed01 0 Posted March 27, 2016 Author Report Share Posted March 27, 2016 Probaj da zamenis senzor pritiska ulja a ne bi bilo lose i filter ulja, to ako ne resi problem onda je pumpa ulja problem. Danas sam zamenio taj senzor, isto se ponasa. Tacije ovo sa slike http://autodbase.ru/26_2015_2q_bitcoin17/images/24/1713047.jpg Pokusacu sa zamenom ulja ako ne i to onda cu otici da pogledaju i izmere pritisak ulja u motoru. Link to post Share on other sites
Milan Dimke Dimitrijevic 0 Posted March 27, 2016 Report Share Posted March 27, 2016 Na to sam mislio.. Obavezno napisi sta je bilo, mozda je nakupio prljavstinu na sito od pumpe, to je cest slucaj kod vw 1.8t.. Link to post Share on other sites
speed01 0 Posted March 28, 2016 Author Report Share Posted March 28, 2016 Na to sam mislio.. Obavezno napisi sta je bilo, mozda je nakupio prljavstinu na sito od pumpe, to je cest slucaj kod vw 1.8t.. Zamenio ulje i filter ulja, isto se ponasa opet blinka samo na leru, s tim sto se sada upali na leru i gori non-stop. Cim pipnem gas opet se ugasi. Motor bez obzira na nju radi bez ikakvih promena. Link to post Share on other sites
StunterSM 0 Posted March 28, 2016 Report Share Posted March 28, 2016 Nece jos dugo, izmeri pritisak Link to post Share on other sites
Stefan L. 0 Posted March 28, 2016 Report Share Posted March 28, 2016 smrdi mi na uljnu pumpu buraz, al ne mora da znaci Link to post Share on other sites
speed01 0 Posted March 28, 2016 Author Report Share Posted March 28, 2016 Pa toga se i bojim da nece jos dugo. :) Izmericu pritisak ulja u nekom servisu u sredu pa cu javiti sta se desava, necu moci ranije zbog posla. U svakom slucaju hvala na savetima. PS sipao sam castrol 10w40 to je ok za ovaj motor? Link to post Share on other sites
777.boban 0 Posted March 29, 2016 Report Share Posted March 29, 2016 Aj prvo promeni ulje,sipaj recimo motul pa ako se ponovo isto dogadja onda ides dalje,ja sam imao taj problem i resio ga zamenom ulja i nikad vise castrol nissam sipao u nijedan auto. Link to post Share on other sites
speed01 0 Posted April 1, 2016 Author Report Share Posted April 1, 2016 Pritisak ulja dobar, danas sam merio. Za sada sam zamenio dakle ulje 10w40, senzor pritiska ulja i proverio pritisak. Dijagnostika ne prikazuje ni jedne greske. Pitao sam majstora za lezaje radilice, auto je ostao kod njega dan i rekao je kao da je sve ok, Citiram "Motor radi savrseno, bukvalno se ne cuje." Rekao mi je da je moguce da zeza senzor nivoa ulja na karteru, sta vi mislite da li je to moguce i da li ima potrebe menjati? Hvala... Link to post Share on other sites
StunterSM 0 Posted April 1, 2016 Report Share Posted April 1, 2016 Mislim da ne znate sta radite ni ti ni on. Koliki je pritisak na leru? Link to post Share on other sites
speed01 0 Posted April 15, 2016 Author Report Share Posted April 15, 2016 Pritisak na leru je 0.8. Dakle zamenio sam senzor pritiska, senzor na karteru, ulje, filtere, ocistio karter i mrezicu na uljnoj pumpi i dalje se isto ponasa, identicni simptomi :/ Link to post Share on other sites
zYx 0 Posted April 18, 2016 Report Share Posted April 18, 2016 Da li si promenio dva mala o-ringa na "osovini" poklopca filtera ulja? Na samom vrhu te osovine su i vise ne dolaze sa filterom ulja kao ranije. Link to post Share on other sites
speed01 0 Posted April 18, 2016 Author Report Share Posted April 18, 2016 Nisam te gumice zamenio. Zamenio sam ovu veliku. Pokusacu i to. Ne znam vise sta da menjam, danas sam zamenio i uljnu pumpu opet isto Link to post Share on other sites
speed01 0 Posted April 19, 2016 Author Report Share Posted April 19, 2016 zamijeni ulje t.j prospi to i uspi drugo ulje sam zamenio pre 10tak dana mobil 10w40 sipao, predlazete neko drugo? ps lampica se pali samo kad postigne radnu temparaturu, dok je hladan nista. Link to post Share on other sites
wice 0 Posted April 19, 2016 Report Share Posted April 19, 2016 proveri ponovo.ako je pritisak na manometru u leru ok onda te zeza davac pritiska ulja,ili kabl od njega Link to post Share on other sites
bokilic 0 Posted April 19, 2016 Report Share Posted April 19, 2016 negde pusta pritisak kad se zagreje,dal je radilica,dal je bregasta,uglavnom nesto negde propusta pritisak,eventualno da negde nesto nije stegnuto ili zadihtovano Link to post Share on other sites
speed01 0 Posted April 19, 2016 Author Report Share Posted April 19, 2016 Mozete predloziti kod koga da odem da izmerim pritisak ulja, merio sam pre nego sto sam ista radio al opet cu otici da vidim sta ce biti. Da li ima smisla zameniti samo lezajeve na radilici bez obrade iste? Link to post Share on other sites
darec032 0 Posted April 19, 2016 Report Share Posted April 19, 2016 Ne Link to post Share on other sites
speed01 0 Posted April 19, 2016 Author Report Share Posted April 19, 2016 Nemam pojma sta da pokusavam dalje, da jos bude gore danas mi upali lampicu check engine, na dijagnostici prikazuje "nepaljene klipa 4" i "nepaljenje klipa 2". Uradio bih bilo sta pa cak to i radilica bila ali je problem sto ne moze da se ustanovi sta je tacno, promjenio sam dosta stvari, odem kod majstora i kad kazem sta sam izmenjao kaze ne znam sta bi moglo biti.... Jedan mi je rekao i tvrdi da je kvar u unutrasnjosti motora 100% i predlozio mi je da zacepim crevo za dovod ulja u vanos i rekao ako bude treptala kad to zacepim onda je problem u donjem delu motora inace je u gornjem, jos to nisam probao Link to post Share on other sites
speed01 0 Posted August 30, 2016 Author Report Share Posted August 30, 2016 Samo da javim da sam nedavno resio problem. Problem je bilo crevo koje ide sa meraca ulja na separator uljih para, puklo je na jako nepreglednom mestu tako da smo ga tek uocili kada smo krenuli da zamenimo separator. Hvala svima na ukazanom vremenu. Link to post Share on other sites
