777.boban 0 Posted January 26, 2017 Report Share Posted January 26, 2017 9 minutes ago, StunterSM said: U nekim slucajevima i dalje rade U kojim slucajevima? Link to post Share on other sites
vranjin 0 Posted January 27, 2017 Report Share Posted January 27, 2017 Preheating System DDE 4.0 The voltage for the preheater plugs is supplied via the preheater relay. The relay is switched by the DDE control unit. The heater plugs are designed as sheathed-element glow plugs. Preheater time control The preheating duration is dependent on the engine coolant temperature and battery voltage and is indicated by the preheating/DDE indicator. Preheating At temperatures below 5 В°C, preheating takes place for at least 4 seconds. The preheating time increases as the temperature decreases. After-heating After-heating takes place after engine start at temperatures below 20 В°C in order to improve idle and exhaust characteristics. Start preheating Start preheating takes place for approx. 10 seconds if after the preheating time has elapsed the engine is not started and the ignition remain on. Troubleshooting The DDE control unit itself detects a short/break in relay activation (type of fault "activation short-circuit ..." or "activation break ..."). The DDE control unit receives a fault signal from the preheater relay in the form of the S_GRS signal if there is a fault in the preheater plugs, preheater relay or in the voltage supply of the relay (type of fault "preheater system fault"). Fault code 3505 "Preheating system" is stored in both cases. Послато са GT-I9515 уз помоћ Тапатока Link to post Share on other sites
vranjin 0 Posted January 27, 2017 Report Share Posted January 27, 2017 Malo ima razlika u vremenima kod drugih dde Послато са GT-I9515 уз помоћ Тапатока Link to post Share on other sites
StunterSM 0 Posted January 27, 2017 Report Share Posted January 27, 2017 Eto ga Link to post Share on other sites
Igyshava 0 Posted May 21, 2017 Report Share Posted May 21, 2017 Pozz, čini mi se da imam problem sa povećanom potrošnjom, Nije zima a meni je potrošnja gradske vožnje 11,7l na bordu. dok je kombinovane grad-otvoren put oko 8l. Sa porodicom izašao van grada resetujem potrošnju na bordu odem do Palića u ZOO, otvoren put prolazim kroz naselja to je sve ukupno pređenog puta oko 100km i nikako da spustim potrošnju ispod 5,8l. To nije normalno zar ne? U pitanju je auto e91 320d 390L 110kw 2007godište. Link to post Share on other sites
milosabs 0 Posted May 21, 2017 Report Share Posted May 21, 2017 Koliko ocekujes od 150 ks? Kakav ti je protokomer? Послато са LG-D855 уз помоћ Тапатока Link to post Share on other sites
dredger 0 Posted May 21, 2017 Report Share Posted May 21, 2017 Ja prvi put cujem za e91 sa 2.0d motorom od 110kv. A sto se potrosnje tice, mozda si sipao lose gorivo. Mada tih 5,8l mi deluje prilicno korektno. Ne verujem da moze da ide ispod toga. Link to post Share on other sites
Igyshava 0 Posted May 21, 2017 Report Share Posted May 21, 2017 Eto sad čuješ da ima i takav. A protokomer nemam pojma kakav je, ne znam šta treba da pogledam niti kako da proverim. Pratio sam ono temperaturu motora i na otvorenom mi ne prelazi 70 stepeni a vidim da treba da je drži oko 90. Sumnjam na veliki protokomer, ali aj da pitam mozda ime neko još neki predlog šta bi moglo da bude. Link to post Share on other sites
StunterSM 0 Posted May 21, 2017 Report Share Posted May 21, 2017 Sredi termostate dok se dpf nije zacepio Link to post Share on other sites
milosabs 0 Posted May 22, 2017 Report Share Posted May 22, 2017 Cim ne postize temp.onda je termostat. Protokomer mozes samo preko dijagnostike da vidis Послато са LG-D855 уз помоћ Тапатока Link to post Share on other sites
Igyshava 0 Posted May 24, 2017 Report Share Posted May 24, 2017 Ok, videću da zamenim termostat. Ima veliki i mali, da li se to menja oba ili samo veliki? Link to post Share on other sites
smg 0 Posted May 25, 2017 Report Share Posted May 25, 2017 Ja sam na e46ici zamenio oba, kad je bal nek je maskembal. Oko 7000 bez antifriza su bila oba. Ali ako si voljan da se igraš, probaj prvo mali (dosta je "visoko" na motoru, i lako se menja) pa vidi da li ti rešava problem. Ako reši, ćuti smrdi i brzine menjaj, a ako ne jebiga, mora i veliki Za veliki sam morao da raskupusam pola motora Link to post Share on other sites
Igyshava 0 Posted May 25, 2017 Report Share Posted May 25, 2017 Jel mora i komplet antifriz da se menja ako se menja veliki? Koliko ide antifriza? Link to post Share on other sites
smg 0 Posted May 26, 2017 Report Share Posted May 26, 2017 Ja sam ispustio. Kontam da bi iscurelo u svakom slučaju, a ovako znam kada sam sipao i koji procenat. Mislim da 6l ide u nejga (e46). Link to post Share on other sites
Igyshava 0 Posted May 26, 2017 Report Share Posted May 26, 2017 To je isti motor kao i kod mene 110kw. Znači i 6l antifriza da spremim kad budem menjao. Link to post Share on other sites
casper e46 0 Posted May 26, 2017 Report Share Posted May 26, 2017 Proveri kod mene u 318d e46 fabricki podaci kazu 8,4. Link to post Share on other sites
Igyshava 0 Posted May 26, 2017 Report Share Posted May 26, 2017 U Auto-dati 3.38 pise 7l ide, toliko cu sipati pa cu videti gledao sam za e46 110kw. Jedno pitanje, imam malo problema sa pretragom za moj auto, motor je 110kw, a kad trazim e91 2007 imam ponudu 120kw i 130kw motore, a ne i 110kw. Kad trazim za auto trazim za e90/e91, a kad trazim za motor trazim za e46 110kw zato i pisem na ovoj temi. Da li ima jos neko ovakav slucaj? Link to post Share on other sites
idekius 0 Posted May 26, 2017 Report Share Posted May 26, 2017 U auto dati pise koliko tecnosti staje u sistem. Ti ispustas iz najnize tacke. Ne znam kako je to reseno kod BMW-a, na Alfi jednostavno odsrafis selnu na najnizem crevu. Mozda BMW ima neki drugaciji sistem, jos nisam pogledao, ali na Alfi je vrlo tesko ispustiti kompletnu rashladnu tecnost. Ono sto se nalazi u bloku motora ostaje... Jedino da parkiras auto nizbrdo, pa da onda ispustas. Zato nikada ne stane onoliko tecnosti koliko pise u uputstvu. Jos jednom da se ogradim, kao sto rekoh, ne znam kako je to kod BMW-a. Link to post Share on other sites
dredger 0 Posted May 26, 2017 Report Share Posted May 26, 2017 1 hour ago, Igyshava said: U Auto-dati 3.38 pise 7l ide, toliko cu sipati pa cu videti gledao sam za e46 110kw. Jedno pitanje, imam malo problema sa pretragom za moj auto, motor je 110kw, a kad trazim e91 2007 imam ponudu 120kw i 130kw motore, a ne i 110kw. Kad trazim za auto trazim za e90/e91, a kad trazim za motor trazim za e46 110kw zato i pisem na ovoj temi. Da li ima jos neko ovakav slucaj? Auto kao tvoj nema sa 110kw. Moze da pise sta hoces. Jedino ako neko nije ubacio motor iz e 46 od 110kv. Daj sliku da vidimo motor. Link to post Share on other sites
casper e46 0 Posted May 27, 2017 Report Share Posted May 27, 2017 Da ti nije auto iz Belgije? Tamo su svi motori smanjene snage tvoj motor je onaj od 163 konja kome je smanjena snaga remapom ili necim slicnim. Javice se neko strucniji. Link to post Share on other sites
NS_320i 0 Posted May 27, 2017 Report Share Posted May 27, 2017 7 hours ago, dredger said: Auto kao tvoj nema sa 110kw. Moze da pise sta hoces. Jedino ako neko nije ubacio motor iz e 46 od 110kv. Daj sliku da vidimo motor. Ima, to su verzije za flotnu prodaju za neznatno manjom snagom u cilju manje potrosnje - "fleet edition" Link to post Share on other sites
dredger 0 Posted May 27, 2017 Report Share Posted May 27, 2017 Moguce i Casper da je u pravu, znam da ima ta fora kod Belgijanaca. Za tu fleet edition nisam nikad cuo, ali ne tvrdim da ne postoji. Bas mi je cudno da bmw pravi takve varijante. Svakako ima i 318d, to je ustrojen 320d, zapremina motora je ista. Mozda je i neka greska u sup-u, mozda je neko pogresno ukucao podatke. Zato kazem da momak okaci sliku motora da vidimo. Link to post Share on other sites
NS_320i 0 Posted May 27, 2017 Report Share Posted May 27, 2017 Bile su i 3 i 5 u tim flotnim verzijama. I potrosnja manja a i na reg usteda jbg ko uzima 20+kom igra mu Posle FL 177ks redovan a Fleet Edition 163ks. Link to post Share on other sites
dredger 0 Posted May 27, 2017 Report Share Posted May 27, 2017 Kapiram sve. Ali sam tuzan sto bmw radi takve stvari. Pa sta je sledece? Napravice karavana teretnog? Bmw je premium brend, kakva flotna prodaja, to radi Fiat, Opel i ostala boranija. Otislo sve u pm... Link to post Share on other sites
Igyshava 0 Posted May 27, 2017 Report Share Posted May 27, 2017 Imao sam nekih obaveza i danas nisam kod kuce ceo dan, sutra slikam motor i kacim slike. Inace ja sam uvezao auto iz Nemacke i mislim da je za nemacko trziste. Link to post Share on other sites
