Xeon-Alpina 0 Posted September 28, 2017 Report Share Posted September 28, 2017 Pozz svima. Interesuje me da li je neko radio prepravku,da umesto AFM senzora (protokomer) stavi MAF senzor. Ikoja je procedura za celu prepravku. hvala unapred. Link to post Share on other sites
StunterSM 0 Posted September 28, 2017 Report Share Posted September 28, 2017 Ja sam bas to hteo da odradim, ali ipak sam se prebacio na MAP senzor. Sve radi super, umesto protokomera je cevka Link to post Share on other sites
Xeon-Alpina 0 Posted September 29, 2017 Author Report Share Posted September 29, 2017 Jel si ti sam radio tu prepravku i ako mozes da mi objasnis proceduru. Link to post Share on other sites
StunterSM 0 Posted September 29, 2017 Report Share Posted September 29, 2017 Radio sam sam. Kupis Det3 Ecu Master, dalje imas na netu ili oteras kod nekog ko zna da ti odradi ozicenje i mapu. Ako resis sam da radis javi se kad kupis pa cu ti pomoci Link to post Share on other sites
Xeon-Alpina 0 Posted September 30, 2017 Author Report Share Posted September 30, 2017 Reci mi jel u tom setu ima sve sto mi treba ili moram nesto jos da kupim sa strane. Hteo sam da uradim na E28 M30b25 motoru i na M30b35 motoru. jel znas mozda neki sajt gde bi mogao da se dokumentujem o toj prepravci. Hvala unapred. Link to post Share on other sites
StunterSM 0 Posted September 30, 2017 Report Share Posted September 30, 2017 Trebalo bi sondu sirokog opsega ako ces sam mapirati, ako radis negde oni to vec imaju. Ona je u kvalitetu oko 200e sa cajgerom. Procesljaj net, ima dosta prerada i objasnjenja Link to post Share on other sites
Xeon-Alpina 0 Posted October 1, 2017 Author Report Share Posted October 1, 2017 Jel bi mogao da me uputis negde gde si ti kupio sve sto treba.... Hvala unapred. Link to post Share on other sites
StunterSM 0 Posted October 1, 2017 Report Share Posted October 1, 2017 http://www.ebay.co.uk/itm/ECU-Master-DET3-MAP-Sensor-2-5-bar-Digital-ECU-Tuner-3-the-best-piggyback-/222658724970?hash=item33d77e846a:g:KRwAAOxyHt9R1WII Link to post Share on other sites
Xeon-Alpina 0 Posted November 4, 2017 Author Report Share Posted November 4, 2017 Jos jedno pitanje. Pogledao sam ovaj proizvod sto si mi dao link. Ali na listi na koja kola moze da ide ne pise nigde e28 i mislim da meni komp nije Bosch Motronic. Jel znas mozda neko drugo resenje ili moze i kod mene da radi isto. Hvala unapred. Link to post Share on other sites
StunterSM 0 Posted November 4, 2017 Report Share Posted November 4, 2017 Koji mislis da je Link to post Share on other sites
Xeon-Alpina 0 Posted November 4, 2017 Author Report Share Posted November 4, 2017 Iskreno sad nemam mogucnost da pogledam posto sam u inostranstvu. moj motor je M30b25 stariji tip m30 motora sa razvodnikom. Link to post Share on other sites
Xeon-Alpina 0 Posted November 5, 2017 Author Report Share Posted November 5, 2017 Sad sam se konsultovao sa drugarom koji zna koji je moj komp u kolima. Kaze da kod mene je Lejetronic. Link to post Share on other sites
Xeon-Alpina 0 Posted November 6, 2017 Author Report Share Posted November 6, 2017 Mislis da moze to kod mene? Bosch Le-jetronik. Link to post Share on other sites
StunterSM 0 Posted November 6, 2017 Report Share Posted November 6, 2017 Moze sigurno. Ovo je namenjeno da pokupi signal sa protokomera, napravi se mapa ofsetuje voltaza za map senzor, malo doradi mapa i to je to. Ja imam nameru struju od M50 da nabacim na M30 i izbacim protokomer Link to post Share on other sites
Xeon-Alpina 0 Posted November 8, 2017 Author Report Share Posted November 8, 2017 Pa i M50 ima isto protokomer. Ne razumem sta dobijas i kako mislis da izbacis protokomer. Link to post Share on other sites
Torque 0 Posted November 8, 2017 Report Share Posted November 8, 2017 Pa i M50 ima isto protokomer. Ne razumem sta dobijas i kako mislis da izbacis protokomer.Jeftin Alpha N [emoji23][emoji23]Sala mala Ma greota to bez itb ... Poslato sa ALE-L21 uz pomoć Tapatoka Link to post Share on other sites
StunterSM 0 Posted November 9, 2017 Report Share Posted November 9, 2017 E nije Alfa N, nadao sam se da ces ti bar razumeti I dalje ostaje na map senzor. Struja od M50 ima mnogo prednosti, precizniji protokomer za uzimanje pocetne mape, senzor radilice koji omogucava 6 bobina, sekvencijalno ubrizgavanje, knock senzori itd. U principu dobijes EMU za 5x manju cenu, plus moze da ti se poveze da ti radi sve sto je radilo i sa m30 strujom Link to post Share on other sites
Xeon-Alpina 0 Posted November 9, 2017 Author Report Share Posted November 9, 2017 Razmisljao sam i ja o sistemu ITB ali sam za pocetak hteo da stavim direct power bombine msd i tako da izbacim razvodnik. I da stavim map senzor da izbacim AFM senzor. Link to post Share on other sites
Torque 0 Posted November 9, 2017 Report Share Posted November 9, 2017 E nije Alfa N, nadao sam se da ces ti bar razumeti [emoji4] I dalje ostaje na map senzor. Struja od M50 ima mnogo prednosti, precizniji protokomer za uzimanje pocetne mape, senzor radilice koji omogucava 6 bobina, sekvencijalno ubrizgavanje, knock senzori itd. U principu dobijes EMU za 5x manju cenu, plus moze da ti se poveze da ti radi sve sto je radilo i sa m30 strujomMa vidis da sam ironican bio cak sam I smajlice stavio [emoji23][emoji23] Poslato sa ALE-L21 uz pomoć Tapatoka Link to post Share on other sites
Torque 0 Posted November 9, 2017 Report Share Posted November 9, 2017 Ma vidis da sam ironican bio cak sam I smajlice stavio [emoji23][emoji23] Poslato sa ALE-L21 uz pomoć TapatokaInace ja u planu imam neki m50 na itb ali do tada ko zna koliko ce proci ....Poslato sa ALE-L21 uz pomoć Tapatoka Link to post Share on other sites
StunterSM 0 Posted November 9, 2017 Report Share Posted November 9, 2017 Sa m50 strujom resavas i 6 bobina i to sve za cenu 6 msd bobina Link to post Share on other sites
StunterSM 0 Posted November 19, 2017 Report Share Posted November 19, 2017 Evo cisto nesto bzvz da to sve moze da radi. Danas je izmapiran auto, u sustini nista se tu posebno ne dobija osim sto se resis protokomera i njegove godine proizvodnje Link to post Share on other sites
Xeon-Alpina 0 Posted November 22, 2017 Author Report Share Posted November 22, 2017 Odlicno, Kad budem radio to tebe cu kontaktirati da mi pomognes ako budes mogao. Hvala jos jednom na informacijama i snimku. Link to post Share on other sites
StunterSM 0 Posted November 22, 2017 Report Share Posted November 22, 2017 Nema problema. Izmereno 200ks ravno na radilici. Zanimljiva stvar da se elminisanjem protokomera dobio manji protok vazduha nego sa njim. Probano sa difuznom klapnom gasa sa vr6 i dobilo se poprilicno vazduha u smesi. Sto daje zakljucak da je protokomer pravio venturi efekat. To je sledeca stvar za ispravku, ali bas super ide, bolje se ponasa itd Link to post Share on other sites
Xeon-Alpina 0 Posted November 22, 2017 Author Report Share Posted November 22, 2017 Verujem, Ali vazduh je bitan zbog te smese. Kako mislis da resis taj problem sa vazduhom, jel imas vec neku ideju? Link to post Share on other sites
