nidzola_e39 0 Posted September 4, 2018 Report Share Posted September 4, 2018 Pozdrav, Kolika je normalna potrosnja ulja za motor od 163ks? Meni ide oko ~800g na 2500km, sad ne znam da li je to ok ili ne.... Cujem razlicita misljenja, pa rekoh da proverim. Link to post Share on other sites
BorisNs96 0 Posted September 4, 2018 Report Share Posted September 4, 2018 To nije normalna potrosnja, bice samo jos gore. Proveri turbinu, zameni separator uljanih para pa ponovo prati potrosnju. Takodje pogledaj da li curi/podliva oko interkulera i creva koja idu od do njega i slicno. Link to post Share on other sites
dredger 0 Posted September 4, 2018 Report Share Posted September 4, 2018 Ne valja da trosi toliko Link to post Share on other sites
nidzola_e39 0 Posted September 4, 2018 Author Report Share Posted September 4, 2018 Da, tako sam i mislio... Proveravam sve pa javljam, u narednom periodu. Krecem od turbine, jer separator sam menjao na servisu, Link to post Share on other sites
La Haine 0 Posted September 5, 2018 Report Share Posted September 5, 2018 Skoro sam šlepao jednog drugara, propišao mu na turbini, vlasnik je pokusao da se doveze do kuće, pa mu je prolupao motor pride..pre toga sam primetio da mu vlazi oko turbine malo..tvrdoglav je kao magarac! Link to post Share on other sites
Zeljkamp 0 Posted September 5, 2018 Report Share Posted September 5, 2018 Kod mene nema potrosnje ulja ni posle predjenih 15.000km od zamene, tako da tu nesto ne valja. Trenutno 230hkm na satu. Link to post Share on other sites
nidzola_e39 0 Posted September 6, 2018 Author Report Share Posted September 6, 2018 Da... Kod mene 260hkm i problem , mada pitanje je i da li je prava km... Pitanje, da li kada otvoris cep na motoru ili kad izvuces sipku, duva malo ili ne? Ne znam da li to ima veze sa konstrukcijom samog motora (mislim na to da li ce da duva ili ne)... Link to post Share on other sites
nikolaxxx 0 Posted October 29, 2018 Report Share Posted October 29, 2018 Isti motor, presao prvih 15.000 od kad je kod mene i nije potrosio apsolutno nista. 175.000. Definitivno proveri prvo turbinu, pa ako nije, gledaj dalje... Link to post Share on other sites
gavra43 0 Posted April 15, 2021 Report Share Posted April 15, 2021 (edited) Da ne otvaram novu temu. Imam isti problem kao sto naslov kaže, e60, 520d, m47, litar ulja otprilike potroši na 1500-2000km. Nema nikakvog dima, možda malo belog dima ujutru na hladan start i to je to. Nema curenja na motoru nigde, gledano više puta. Problem se javlja otkako sam kupio auto, mislio sam da je možda separator ili ulje lose ili tako nešto, na prvom malom servisu nisam zamenio separator, to je bilo pre nekih 15ak hiljada km. Skoro radjen drugi mali servis, ulje(BMW 5w30), filteri, separator. Opet isto, posle nekih 2000km predjenih fali ulja, došao na minimum. Auto se sve vreme ponaša isto, pali, radi, vuče kako treba. Jel imao neko sličan problem možda? Edited April 15, 2021 by gavra43 Link to post Share on other sites
