pcx 0 Posted March 12, 2019 Report Share Posted March 12, 2019 1. Ima li neko iskusva mogu li style 244 17" 7.5j et20 na e46 krompiras 2004 bez nekih modifikacija?Trenutno su na autu style 156 16" 7j et34 sa gumama 205x55 2. Ako mogu, koje dimenzije guma da vijam : 215, 225 sa 45 ili 50 ... uzmite u obzir da auto ne planiram da spustam, vozim na nasim "extra" putevima svakodnevno ... Po kalkulatorima sa neta style 244 bi bile oko 2cm isturenije od trenutnog setapa ... To mi se ovako na nevidjeno cini mnogo ... Iako volim da tocak nije uvucen. Hvala svim konstruktuvnim komentatorima unapred! Sent from my ONE E1003 using Tapatalk Link to post Share on other sites
TOKYO 0 Posted March 12, 2019 Report Share Posted March 12, 2019 Stavili smo kod prijatelja zimus 17 7.5 et25 nazad s gumama 225/45 i bilo je prilicno napeto, ne znam bas sta bi se desilo da se optereti, zavisi i od kalupa gume, razlikuju se jako, et 20 je jos 5mm napolje, mislim da ti nije pametno, a ne moze biti ni lepo... Link to post Share on other sites
TOKYO 0 Posted March 12, 2019 Report Share Posted March 12, 2019 https://www.bmw-syndikat.de/bmw-syndikat/homepage/felgen-bilder-marken.asp?G_HERSTELLER=0&G_FAHRZEUG=E46&G_ZOLL=17 Ovde imas brdo slika za 17, sa raznim sirinama, i offset-ima, pise i dimenzija gume i dal ima distancere ili nema, pa uporedi sa tim sto hoces. . . Link to post Share on other sites
pcx 0 Posted March 13, 2019 Author Report Share Posted March 13, 2019 Hvala za info. I ja se toga bojim. Onda tragam style 68.Sent from my ONE E1003 using Tapatalk Link to post Share on other sites
joca_kg 0 Posted March 13, 2019 Report Share Posted March 13, 2019 (edited) Ja sam vozio BBS RS 17", et20, 8J, sa 205/45, na m vesanju, i nije kacilo. Jeste nategnuto, ali moze da se vozi ? Sent from my SNE-LX1 using Tapatalk Edited March 13, 2019 by joca_kg Link to post Share on other sites
pcx 0 Posted March 13, 2019 Author Report Share Posted March 13, 2019 E da je M-vesanje kod mog krompirasa ... Lepo su mu legle, samo 205x45 na 8j je bas nategnuto ... Ali lepo izgleda.Sent from my ONE E1003 using Tapatalk Link to post Share on other sites
pcx 0 Posted March 13, 2019 Author Report Share Posted March 13, 2019 Ovog sam zagledao sa style 244, ali je taj spusten pa mu je verovatno zato stala felna Plus je mozda i razvlacio blatobrane. Meni se mnooogo svideo : Danas treba da vidim neke style 68, pa ako su u dobrom stanju da ih pazarim. A onda lov na gume ... Link to post Share on other sites
marko13 0 Posted March 13, 2019 Report Share Posted March 13, 2019 Ne treba se zezati. Aj zadnje se nekako ubudze ali frka nastaje sa prednjim. Sve i kada je neko sport vesanje bude frka. Evo situacija. Sve je na knap, udjes u krivinu nista jako i ako ima uzbrdica, nizbrdo, bilo kakva izbocina dobija udarac i kaci prednje krilo kada je tocak u skretanju 100%. To ti ne treba. Link to post Share on other sites
La Haine 0 Posted March 13, 2019 Report Share Posted March 13, 2019 (edited) Joco probaj moje opruge, zalepi ga za patos, moze to jos dole ihaa Mada, to su bas mali tockovi, mozda 1 cm dobijes samo, 1.5 od oka max 2 :p Edited March 13, 2019 by La Haine Link to post Share on other sites
joca_kg 0 Posted March 13, 2019 Report Share Posted March 13, 2019 Moze,moze, nego da ne bude mnogo [emoji16][emoji1787]Sent from my SNE-LX1 using Tapatalk Link to post Share on other sites
La Haine 0 Posted March 13, 2019 Report Share Posted March 13, 2019 Salim se, dobar ti je auto! Link to post Share on other sites
La Haine 0 Posted March 13, 2019 Report Share Posted March 13, 2019 Meni je šus pleh izubijan full..a gewinde nisam montirao na navoje pozadi, nego samo opruge hehe, da vidim koliko moze dole :p Posle sam namestio kako treba jbg, ruzno izgleda kad se pretera Link to post Share on other sites
La Haine 0 Posted March 13, 2019 Report Share Posted March 13, 2019 Skripala su mi stakla u vratima kad je auto bio u libeli, mlogo tvrdo vesanje na gewindama. Od kad je blago naboden napred, nema vise skripe! Link to post Share on other sites
