StunterSM 0 Posted May 12, 2019 Report Share Posted May 12, 2019 Ista je cena, samo kod njega lupa a kod tebe trza. Razlicite stvari su u pitanju Link to post Share on other sites
Mirsad 0 Posted May 12, 2019 Author Report Share Posted May 12, 2019 47 minutes ago, StunterSM said: Kod tebe na atc400 ne ulaze nutovi kardana u reduktor vec imas 4 srafa. Tako da to nije moguce na x3 tvom. Problem je lanac i kvacilo kod tebe ~800e sa uljnom pumpom. Kompletan remont je 950 Kod mene je atc 500 x5 e53 2004 FL Link to post Share on other sites
Mirsad 0 Posted May 12, 2019 Author Report Share Posted May 12, 2019 X5 3.0d M57N (From 01.10.2003) Transfer case ATC 500 Link to post Share on other sites
StunterSM 0 Posted May 12, 2019 Report Share Posted May 12, 2019 Onda mozes imati problem sa luftom u nutovima i u pocetku je lupanje, na kraju izgubis pogon kad proklize i to je to Link to post Share on other sites
Mirsad 0 Posted May 12, 2019 Author Report Share Posted May 12, 2019 (edited) 50 minutes ago, StunterSM said: Onda mozes imati problem sa luftom u nutovima i u pocetku je lupanje, na kraju izgubis pogon kad proklize i to je to jucer sam se vozao na novim gumam tj. dimenziji koje po fabrickim standardim, (255-50-19 i 285-45-19 na 9J prednja 10J zadnje felge) i danas sam ga prikljucio na bmw scanne i promijenio mi je gresku ? ABS* -> 5DEB/A0 - Info: clutch gearbox-ECU: reduction torque intervention because of to high tire size tolerance. kad sam uradio brisanje greske vise mi se nije javljalo ? odo sutra da uradim optiku trapa posto sam nove gume stavio da i to provjerim pa cu ga opet prikopcati da vidim dali sta izbacuje. Edited May 12, 2019 by Mirsad Link to post Share on other sites
Mirsad 0 Posted May 18, 2019 Author Report Share Posted May 18, 2019 (edited) Pozdrav, vratio sam se sa optike trapa posto sam nabacio zadnje nove gume i evo sad rezultata podesavanje zadovoljan uzeo sam ponovo onaj bmw scanner da ocitam greske ali sam dobio nesto cudno uopste mi vise ne ocitava ABS kaze nije nadjen (takodjer mi ne ocitava i multi funkciju volana sa tempomatom isto kaze nije nadjen a sve ima i sve radi perfektno cudno) dali je to nesto sad do ove dijagostike ? Auto ima blagi trzaj u 1 stepene nekad u 2 ako nema u 1 bude u 2 stepenu prenosa ? , i dalje imam blagi luft u malom kardanu ! prepostavljam da je ovaj trzaj od kardana i nutova, sad sta da radim dali da nadjem kakav zdrav kardan ili nesto drugo kontam ako uzem kardan kakvi su nutovi u reduktoru dali je bolje onda adapter od StunterSM. Hvala Edited May 18, 2019 by Mirsad Link to post Share on other sites
Mirsad 0 Posted May 24, 2019 Author Report Share Posted May 24, 2019 On 5/18/2019 at 3:45 PM, Mirsad said: Pozdrav, vratio sam se sa optike trapa posto sam nabacio zadnje nove gume i evo sad rezultata podesavanje zadovoljan uzeo sam ponovo onaj bmw scanner da ocitam greske ali sam dobio nesto cudno uopste mi vise ne ocitava ABS kaze nije nadjen (takodjer mi ne ocitava i multi funkciju volana sa tempomatom isto kaze nije nadjen a sve ima i sve radi perfektno cudno) dali je to nesto sad do ove dijagostike ? Auto ima blagi trzaj u 1 stepene nekad u 2 ako nema u 1 bude u 2 stepenu prenosa ? , i dalje imam blagi luft u malom kardanu ! prepostavljam da je ovaj trzaj od kardana i nutova, sad sta da radim dali da nadjem kakav zdrav kardan ili nesto drugo kontam ako uzem kardan kakvi su nutovi u reduktoru dali je bolje onda adapter od StunterSM. Hvala Nesto se umrtvio forum ? Link to post Share on other sites
