Boban_m 0 Posted January 19, 2020 Report Share Posted January 19, 2020 Moj macak mi se pentra po autu i nisam imao s tim problema dok jutros nisam vidio ogrebotine po krovu i haubi. Mozda ih i nije on ostavio, nego druge macke koje sam snimio da hoce da skoce na auto, ali u svakom slucaju moram da smislim nesto da ih odbijem od auta. Ne kupuje mi se cerada jer je smor stavljati i skidati svako vece i jutro. Ima li neko drugo pametno rjesenje? Link to post Share on other sites
Nemanja-e36 0 Posted January 19, 2020 Report Share Posted January 19, 2020 Vazdusna puska Link to post Share on other sites
Indorile 0 Posted January 19, 2020 Report Share Posted January 19, 2020 Kupi kera, sto krvolocniji to bolji. Link to post Share on other sites
Boban_m 0 Posted January 19, 2020 Author Report Share Posted January 19, 2020 Beli je moj ljubimac, tako da bilo sta sto ga moze povrijediti ne dolazi u obzir. Oprostio sam mu koznu sofu, ali ne mogu da gledam ogrebotine na 4-ci, a bila je kao ogledalo. Link to post Share on other sites
castor 0 Posted January 19, 2020 Report Share Posted January 19, 2020 Probaj u nekom pet shop-u da nađeš onaj repellent trening sprej za pse i mačke. Trebalo bi da pomogne. Problem je što mačka može da skoči uvis 1.5 m bez problema, pa treba naprskati cijeli auto... Link to post Share on other sites
Boban_m 0 Posted January 19, 2020 Author Report Share Posted January 19, 2020 Tako nesto sam imao u vidu, hemijski ili (ultra)zvucni repelent. Bilo bi sjajno ako je neko imao slican problem i zna kako... Link to post Share on other sites
cokanovic 0 Posted January 19, 2020 Report Share Posted January 19, 2020 Ma nema leka. Na mom autu se redovno šibaju mačke, nekoliko puta su uništile i haubu i gepek vrata, ali bukvalno! U toj meri da ni smirglanje laka nije pomoglo. To traje do dan danas, narocito zimi kada naskaču na toplu haubu u zimskim danima da se ogreju. Link to post Share on other sites
Vedran 0 Posted January 19, 2020 Report Share Posted January 19, 2020 Sto se tvog macka tice, jedino sto mi sad pada na pamet je flasica sa vodom. Kad god ga zateknes na autu, kupanje. Relativno brzo ce nauciti da se ne penje. Ali potrebno je "kupati" ga sto cesce je moguce, a i nece ti pomoci sa drugim mackama. Voda je generalno odlican nacin da se macka odvikne od nezeljenog ponasanja ali nije uvek prakticno i primenljivo.Sent from my SM-G973F using Tapatalk Link to post Share on other sites
Boban_m 0 Posted January 19, 2020 Author Report Share Posted January 19, 2020 (edited) 52 minutes ago, cokanovic said: Ma nema leka. Na mom autu se redovno šibaju mačke, nekoliko puta su uništile i haubu i gepek vrata, ali bukvalno! U toj meri da ni smirglanje laka nije pomoglo. To traje do dan danas, narocito zimi kada naskaču na toplu haubu u zimskim danima da se ogreju. Au... 11 minutes ago, Vedran said: Sto se tvog macka tice, jedino sto mi sad pada na pamet je flasica sa vodom. Kad god ga zateknes na autu, kupanje. Relativno brzo ce nauciti da se ne penje. Ali potrebno je "kupati" ga sto cesce je moguce, a i nece ti pomoci sa drugim mackama. Voda je generalno odlican nacin da se macka odvikne od nezeljenog ponasanja ali nije uvek prakticno i primenljivo. Sent from my SM-G973F using Tapatalk Probacu da ga istreniram, ali mi se cini da cu morati da se drkam s ceradom svaki dan 😡 Da mi je neko rekao da je keratin tvrdji od fabrickog laka ne bih mu vjerovao. Evo close-up slicice. Poliranje bi izvuklo ovo, ali ne mogu da poliram svakih 7 dana... Edited January 19, 2020 by Boban_m Link to post Share on other sites
Indorile 0 Posted January 19, 2020 Report Share Posted January 19, 2020 Imao je @Sasquatch problema sa mackama i nasao je neko sranje koje ih tera dalje poprilicno uspesno. Link to post Share on other sites
Boban_m 0 Posted January 19, 2020 Author Report Share Posted January 19, 2020 Hvala Indorile. Imas link ako je pisano na forumu ili da cekamo da se Saskvoc javi? Link to post Share on other sites
Sigtran 0 Posted January 19, 2020 Report Share Posted January 19, 2020 Ovako bezveze, padaju mi na pamet ideje: - nanopremaz laka velike tvrdoće - ultrazvučni rasterivač mačaka (doduše i pasa) - postoji i varijanta sa detekcijom pokreta tako da ne radi non-stop Link to post Share on other sites
Vedran 0 Posted January 19, 2020 Report Share Posted January 19, 2020 Nanopremaz ili tzv "keramika" nije resenje. Auto ne postaje otporan na grebanje niti bilo sta tog tipa.Sent from my SM-G973F using Tapatalk Link to post Share on other sites
Sale-Sombor 0 Posted January 19, 2020 Report Share Posted January 19, 2020 Imas ove nove PPF folije sa tzv samoizlecenjem, koje kada se izgrebu pod uticajem sunca gube se ogrebotine Link to post Share on other sites
Boban_m 0 Posted January 19, 2020 Author Report Share Posted January 19, 2020 Da, razmisljao sam o foliji na krovu, prvenstveno zastite od sunca radi (a ovde je nemiloardno), ali i zbog estetike. Mislio sam da stavim gloss crnu (kao crno staklo) ali sam pomislio kako ce nesrecna folija proci ako lak ne moze da se odupre. Sad si me podsjetio da sam negdje gledao te folije sa samoregeneracijom. Definitivno cu uzeti u obzir kao jednu od mjera. Link to post Share on other sites
Boban_m 0 Posted January 19, 2020 Author Report Share Posted January 19, 2020 (edited) . Edited January 19, 2020 by Boban_m Link to post Share on other sites
dredger 0 Posted January 19, 2020 Report Share Posted January 19, 2020 Poseci mu nokte 🙂 Link to post Share on other sites
Sasquatch 0 Posted January 27, 2020 Report Share Posted January 27, 2020 Jos uvek imam problem ali tek ponekada kada je hladno napolju a ja stignem kuci, hoce da se ugreje. Ali to tek onako, retko. Ja sam koristio neki gel sto tera macke, miris im smeta. Ima da se kupi u pet shop-u. https://m.kupujemprodajem.com/Kucni-ljubimci/Odeca-i-oprema/Gel-za-odbijanje-pasa-i-macaka-Repellent-Keep-Off-Jelly-61605456-oglas.htm#mhs0-1580120388669 Stavljao sam svuda, mozda par meseci i sada instiktivno macka mimoilazi taj prostor. Postoji nesto ovako ali nisam probao. https://m.aliexpress.ru/item/32861782664.html?trace=wwwdetail2mobilesitedetail Link to post Share on other sites
