mikson 0 Posted January 29, 2021 Report Share Posted January 29, 2021 Da li neko moze da mi protumaci ove greske? Auto je bio garaziran i nije vozen par godina. Najvise me interesuje sta moze da bude problem sa abs i kontrolom proklizavanja(zamenjen mu je modul i senzor prednjeg levog tocka) i ovi silni erori sa parking senzorima.Auto ima fabricke xenone i ponekad hoce da mu blicaju ring light iako je svetlo ugaseno. Odradjen mu je mali servis, zamenjen separator ulja. Treba da ga registrujem, palim ga povremeno i hoce da dimi sivkasto. Cudno je sto kad ga upalim nema uopste dima,pa nakon par minuta ima, pa kad se zagreje nema a nakon turiranja ima pa kad se smiri na leru opet nema. Nisam ga jos registrovao, pa ne mogu da ga provozam na duze. Kodovi gresaka Diesel (M57D25 - 256D1 - DDE 4.0 - MT/AT) DTC Opis 3505 - Glow Plug Module Control Circuit Brake (ABS/ASC/DSC - Diagnose) DTC Opis 33 - Front left wheel speed sensor faulty signal Instrument (Instrument (Instrument cluster ) - Diagnose) DTC Opis 21 - Control unit; internal error Climate (Climate control - IHKA/IHKR (IHKA/IHKR: Climate control)) DTC Opis Nema kodova gresaka Imobilajzer (Immobiliser - Diagnose) DTC Opis Nema kodova gresaka Ogranicenja (Airbag - Diagnose) DTC Opis 02 - Driver pretensioner squib; resistance too high - Intermittent Multifunkcija (Central Body - AIC/RLS (Automatic interval control)) DTC Opis Nema kodova gresaka Multifunkcija (Central Body - PDC (Parking assistance system)) DTC Opis 10 - Distance sensor, rear left - Signal, open circuit - Permanent Fault frequency 70 11 - Distance sensor, rear right - Deviation - Permanent Fault frequency50 12 - Distance sensor, rear center left - Signal, open circuit - Permanent Fault frequency 70 13 - Distance sensor, rear center right - Signal, open circuit - Permanent Fault frequency 70 14 - Distance sensor, front left - Signal, open circuit - Permanent Fault frequency 70 15 - Distance sensor, front right - Signal, open circuit - Permanent Fault frequency 70 16 - Distance sensor, front center left - Signal, open circuit - Permanent Fault frequency 70 17 - Distance sensor, front center right - Signal, open circuit - Permanent Fault frequency 70 18 - Voltage converter - ----- - Intermittent Fault frequency Multifunkcija (Central Body - ZKE (Central body electronics)) DTC Opis 64 - Interior lighting Multifunkcija (Lights center - LCM (Lights control)) DTC Opis 1 - Thermal oil level sensor 126 - Fl fog lamp open 153 - Numberplate light, defective Multifunkcija (Lights center - LRA (Vertical headlight aiming)) DTC Opis Nema kodova gresaka Link to post Share on other sites
