324d 0 Posted November 14, 2008 Report Share Posted November 14, 2008 Interesuje me zasto mi je grejanje u kabini u poslednje vreme skroz slabo, auto treba da radi minimum 15min da bi izasao iz plavog i da nabija temperaturu, i kada postigne temperaturu ne prelazi crtu pre polovine pokazivaca, a grejanje je slabo ako vozim normalno maltene i ne greje, kada ga malo odcepim u trecoj, cetvrtoj oseti se malo jace grejanje Link to post Share on other sites
wice 0 Posted November 14, 2008 Report Share Posted November 14, 2008 dali ti je sistem ozracen?ili imas vazduha u sistemu ili nemas dovoljno antifriza,ili ti pak ne radi slavina.... Link to post Share on other sites
324d 0 Posted November 14, 2008 Author Report Share Posted November 14, 2008 koja slavina? nemam pojma zasto bi bilo vazduha u sistemu kada nista nije dirano a tokom godine je grejao kao blesav Link to post Share on other sites
wice 0 Posted November 14, 2008 Report Share Posted November 14, 2008 pa slavina ili ventil koji otvara grejanje....pa sta znam zasto ima vazduha ,to je samo pretpostavka....proveri mozda samo fali tecnosti.... Link to post Share on other sites
324d 0 Posted November 14, 2008 Author Report Share Posted November 14, 2008 ne fali mi tecnost, gledao sam, i nikada nisam dosipao, znaci ne gubi nigde tecnost, reci mi gde se nalazi ta slavina da vidim mozda je stvarno ona... bas me cud sto mi kasno nabija temperaturu kada se svaki bmw jako brzo zagreva Link to post Share on other sites
wice 0 Posted November 14, 2008 Report Share Posted November 14, 2008 sto slabo nabija temperaturu,mozda je zaglavio termostat, mada kod mene greje cim izadje iz crvenog kako ti greje kada postigne radnu temperaturu? Link to post Share on other sites
324d 0 Posted November 14, 2008 Author Report Share Posted November 14, 2008 skroz slabo... u odnosu na proslu godinu ne greje nikako Link to post Share on other sites
Lemi M5 0 Posted November 14, 2008 Report Share Posted November 14, 2008 imam isti problem, mislim da je termostat, kupio sam nov za 1000 dinara (to je skuplji), nisam ga josh zamenio, tako da ne mogu da ti kazem da li je on u pitanju.. Link to post Share on other sites
BMW E36 POWER 0 Posted November 14, 2008 Report Share Posted November 14, 2008 hahahaha...ja juce gledam nece nesto da mi grije,duva ali ne grije kad ono zaboravih vratiti onaj kotur sa plavog na crveno... Link to post Share on other sites
mihajlo24v 0 Posted November 14, 2008 Report Share Posted November 14, 2008 nema on slavinu,postoje ti kao ventili koji otvaraju/zatvaraju protok antifriza,...ja sam ranije imao problema jer su mi ventili glavili!kod kutije gde su osiguraci je ta pumpa,bosch 2 metalna kruga i djek za struju,prikljucak sa 3 zice!blago ih udari gumenim/plasticnim delom shravcigera dok ne otvore!!provalices da rade ako su ugrejani!!slikovito??!! Link to post Share on other sites
324d 0 Posted November 14, 2008 Author Report Share Posted November 14, 2008 nema on slavinu,postoje ti kao ventili koji otvaraju/zatvaraju protok antifriza,...ja sam ranije imao problema jer su mi ventili glavili!kod kutije gde su osiguraci je ta pumpa,bosch 2 metalna kruga i djek za struju,prikljucak sa 3 zice!blago ih udari gumenim/plasticnim delom shravcigera dok ne otvore!!provalices da rade ako su ugrejani!!slikovito??!! to moram ujutru probati Link to post Share on other sites
wice 0 Posted November 14, 2008 Report Share Posted November 14, 2008 nema on slavinu,postoje ti kao ventili koji otvaraju/zatvaraju protok antifriza,...ja sam ranije imao problema jer su mi ventili glavili!kod kutije gde su osiguraci je ta pumpa,bosch 2 metalna kruga i djek za struju,prikljucak sa 3 zice!blago ih udari gumenim/plasticnim delom shravcigera dok ne otvore!!provalices da rade ako su ugrejani!!slikovito??!! pa na to sam mislio ventil ili el ventil dodje mu na isto :pleasantry: opipaj creva pre i posle ventila kada je zagrejan motor i kada je grejanje pusteno trebalo bi da budu isto zagrejana Link to post Share on other sites
mihajlo24v 0 Posted November 14, 2008 Report Share Posted November 14, 2008 nisam te isprozivao nego samo malo pojasnio! jbg trazis pomoc od majstora a dobijes od laika! Link to post Share on other sites
wice 0 Posted November 14, 2008 Report Share Posted November 14, 2008 nisam ni shvatio tvoj post kao prozivku,samo sam se nadovezao,a opet daleko sam od toga da sam laik ,ali nebitno.... treba pokusati pomoci coveku dok se ne jave pravi majstori :pleasantry: Link to post Share on other sites
dacha654321 0 Posted November 14, 2008 Report Share Posted November 14, 2008 Da li neko moze da mi kaze zasto kada ukljucim grejanje u kolima prema soferci i nogama duva toplo a na centralnom delu i prema prozorima duva hladno??? Link to post Share on other sites
wice 0 Posted November 14, 2008 Report Share Posted November 14, 2008 mislim da ima veze u kom polozaju je onaj regulator kojim se usmerava protok vazduha,mislim da na njemu ima i plavo polje tj da duva hladno i kada je grejanje ukljuceno Link to post Share on other sites
dacha654321 0 Posted November 14, 2008 Report Share Posted November 14, 2008 Nema imas one tri sajle po redu odozgo na dole 1. da duva gore 2. da duva napred 3. da duva dole i svaka ima poziciju levo ili ti zatvoreno ili desno tj. otvoreno. tri tocka za podesavanje temperature levi i desni za temp. a srednji za brzinu ventilatora. Link to post Share on other sites
mihajlo24v 0 Posted November 14, 2008 Report Share Posted November 14, 2008 waice nisam mislio na tebe da si laik nego na sebe,mada niko od nas nije neki strucnjak,svi smo priuceni!! nemam ni ja regulator na sredini,centralna dva na tabli koji duvaju pravo!!pa sam cackao onaj djek kod pumpe pa sad normalno radi!ranije mi je duvalo toplo svugde sem na desnoj strani,noge ok,leva ok,soferka ok pa sam zatvarao samo desnu stranu!! Link to post Share on other sites
Obi1 0 Posted November 14, 2008 Report Share Posted November 14, 2008 Da li neko moze da mi kaze zasto kada ukljucim grejanje u kolima prema soferci i nogama duva toplo a na centralnom delu i prema prozorima duva hladno??? Kod mene ista situacija.. Link to post Share on other sites
Iga 0 Posted November 14, 2008 Report Share Posted November 14, 2008 odrsrafis tablu, podignes je toliko da mozes da izvadis ventilacionu kutiju, otkacis mali hladnjak, odsrafis kutiju iz motornog prostora, izvadis kutiju, sve klapne vratis na mesto, zalepis nove sundjere na sastavima i onda sve to nazad. Velika zajebancija... Link to post Share on other sites
BMW 528iA 0 Posted November 16, 2008 Report Share Posted November 16, 2008 Kod mene ista situacija.. Ako ne pomaze onaj tockic plavo crveno onda sigurno imas problema sa upravljackom jedinicom te funkcije. Baki, ja bih stavio drugi termostat i odzracivanje. Link to post Share on other sites
Obi1 0 Posted November 16, 2008 Report Share Posted November 16, 2008 Ako ne pomaze onaj tockic plavo crveno onda sigurno imas problema sa upravljackom jedinicom te funkcije.Baki, ja bih stavio drugi termostat i odzracivanje. Nejasno mi je, ipak.. Imam na soferki i dole, na nogama, a napred nista.. To gore-dole, levo-desno.. Ide preko sajle, valjda.. Nesto mi tu ne stima. Link to post Share on other sites
dacha654321 0 Posted November 17, 2008 Report Share Posted November 17, 2008 Ali kakve veze ima termostat i odzracivanje sa tim da napred duva hladno a prema soferci i na noge toplo??? Link to post Share on other sites
ianullrich 0 Posted November 17, 2008 Report Share Posted November 17, 2008 ljudi bre, kolko ja znam, bar kod e34, kod soferke i kod nogu duva grejanje a napred je ventilacija koja uvek duva hladno mozda ja gresim ali i kod mene je tako i na svakoj e34 koju znam Link to post Share on other sites
dacha654321 0 Posted November 17, 2008 Report Share Posted November 17, 2008 Ne znam za druge ali po mojoj logici to nije normalno. Link to post Share on other sites
