Alek 0 Posted March 17, 2009 Report Share Posted March 17, 2009 Radi se o kockici 316 sa m10 motorom,zanima me da li je sve uredu...prilikom jutarnjeg paljenja lampica za ulje mi svetli recimo 3,4 sekunde pa se ugasi,kad se ugreje i otvorim cep na poklopcu pritisak je odlican!!!Razmisljam o uljnoj pumpi,ali mislim da nema razloga za uzbunu?!Vasa misljenja... Link to post Share on other sites
Lemi M5 0 Posted March 17, 2009 Report Share Posted March 17, 2009 najnormalnija stvar! Link to post Share on other sites
BMW 528iA 0 Posted March 17, 2009 Report Share Posted March 17, 2009 Koje ulje koristis? 15 - 40? Link to post Share on other sites
Alek 0 Posted March 17, 2009 Author Report Share Posted March 17, 2009 Motul 10-40... Link to post Share on other sites
[kick] 0 Posted March 17, 2009 Report Share Posted March 17, 2009 Dok sam vozio M10 gasio je lampicu za 1 sec. mozda i manje ulje je bilo Shell 15-40 Link to post Share on other sites
Alek 0 Posted March 17, 2009 Author Report Share Posted March 17, 2009 Sta preporucujete,neku promenu ulja ili...?! Link to post Share on other sites
hermes 0 Posted March 17, 2009 Report Share Posted March 17, 2009 Nije normalna stvar, ili ti je ekstra los kvalitet ulja, ili neodgovarajuci filter ulja, ili losa pumpa za ulje, ili generalno los motor. Dobar motor odmah gasi lampicu, i leti i zimi. Link to post Share on other sites
BMW 528iA 0 Posted March 17, 2009 Report Share Posted March 17, 2009 Ja bih sipao 5-30, novi filter i ceraj dalje. Uh, kad smo kod ulja...moram spremit 100 eura za 7 litara Mobil 1 0-40 i filter. Link to post Share on other sites
hermes 0 Posted March 17, 2009 Report Share Posted March 17, 2009 Preretko je to ulje za ovaj motor....a tek ide leto. Ako hocu da budem optimista, ja tipujem na los filter, ali mi je izvesnije da u nekoj blizoj (ili malo daljoj) buducnostu tom motoru sleduje otvaranje.... Link to post Share on other sites
Alek 0 Posted March 17, 2009 Author Report Share Posted March 17, 2009 Motor je ekstra,prede i suv je kao barut...ali sam to preimetio od kada je sipan Motul i zamenjen filter,pre 2000 km!!!Pre toga je bio Castrol Magnetec 10-40,ali po preporuci predjoh na Motul!5-30...mislim da bi mi trosio tu gradaciju,zasto preporucujes to i koje ulje?!Napominjem da mi se to desava od poslednje zamene ulja.... Link to post Share on other sites
[kick] 0 Posted March 17, 2009 Report Share Posted March 17, 2009 Pa menjaj onda ulje. Link to post Share on other sites
saja 0 Posted March 17, 2009 Report Share Posted March 17, 2009 a jel ti trosi to ulje ako je lose sigurno ce da ga potrosi Link to post Share on other sites
max_power 0 Posted March 17, 2009 Report Share Posted March 17, 2009 A kad palis zagrejan motor? Koliko sam razumeo lampica ostaje duze da svetli samo prilikom jutarnjeg paljenja. tj kada je ulje gusto zbog temperature nize. Kako je gada se zagreje auto? Link to post Share on other sites
Alek 0 Posted March 18, 2009 Author Report Share Posted March 18, 2009 Jedino sto sam primetio je da je filter nosio drugu oznaku u odnosu na predhodni servis i dao sam oko 600 din za njega,a Motul je kao original i dao sam skoro 650 din. za litar!!!Ono sto sam odokativno video,mozda je opticka varka je da je taj Motul u odnosu na Castrol (oba 10-40) nekako kao gusci,bem li ga!!!Da,lampica svetli malo duze samo prilikom prvog paljenja,kada se motor ugreje,gasi se za sekundu!Dovodite me u razmisljanje da ga menjam,nemam pojma?!Ne bih menjao gradaciju,tek dolazi leto...mozda ce mi trebati i nesto gusce!?S'obzirom da servis radim na 6000,na Castrolu mi je trosio oko 100-150 ml na 1000 km!!! Link to post Share on other sites
max_power 0 Posted March 18, 2009 Report Share Posted March 18, 2009 Meni se desavalo na pasatu, nije na BMW-u isti problem, odnosno i nije nikakav problem bio. Samo tamo sam sipao 15-40 i kada je jako hladno, mraz...lampica svetli duze. Stegne se ulje a i onako je 15-40 pa dok ne napravi pritasak i to ona svetli. Kada je zagrejan i razredi ulje gasi je odmah. Ne verujem da je neki problem to, bar mislim da nije nesto sto moze ostaviti posledice. Ali opet konsultuj se na vreme. Iskreno ja nemam poverenje niti u jedno ulje. Link to post Share on other sites
daiwa 0 Posted March 18, 2009 Report Share Posted March 18, 2009 Vrlo moguce da je filter. Link to post Share on other sites
Alek 0 Posted March 18, 2009 Author Report Share Posted March 18, 2009 Evo danas sam bio po Bg-u i kada se motor ugreje i ulje razredi ugasim i odmah upalim auto lampica se gasi iste sekunde...dakle to se javlja samo prilikom prvog paljenja!!!Ipak je kastrol fuserej kod nas pa je 10-40 nekako redji a Motul je kao original i manje mi trosi njega,ne znam da li nesto da diram ili jos da teram pa da na sledecem servisu uzmem nesto drugo?! Link to post Share on other sites
marko13 0 Posted March 18, 2009 Report Share Posted March 18, 2009 Nemoj da dizes paniku oko 3-4 sec. Ako je tako samo kada je hladan i toliko kratko onda to i nije bas neki problem. Vidi koliko ti ulja trosi ako si zadovoljan samo teraj i uzivaj. Link to post Share on other sites
Alek 0 Posted March 18, 2009 Author Report Share Posted March 18, 2009 Ok,hvala svima...necu nista dirati do sledece zamene,jer je ostalo sve apsolutno normalno!!! Link to post Share on other sites
gagy80 0 Posted March 18, 2009 Report Share Posted March 18, 2009 Cim se to desava pri prvom paljenju ,ulje mu ne odgovara jer bi u suprotnom bila jos gora situacija kada je auto zagrejan!!!! Link to post Share on other sites
hermes 0 Posted March 18, 2009 Report Share Posted March 18, 2009 Posteno govoreci, ne bih ni ja dirao...... ali tih par sekundi rada bez ulja jako ostecuje pojedine lezajeve u motoru, vreme ce to pokazati Link to post Share on other sites
Alek 0 Posted March 18, 2009 Author Report Share Posted March 18, 2009 Sta sad,ne odgovara mu Motul...da se vratim na vodu od ulja Castrol,ili Mobil?! Link to post Share on other sites
hermes 0 Posted March 18, 2009 Report Share Posted March 18, 2009 A sto nikako ne razmatras opciju da ti je filter ulja los? Link to post Share on other sites
Alek 0 Posted March 18, 2009 Author Report Share Posted March 18, 2009 Prosto,kao nov je je kupljen,menja se prilikom svake zamene ulja!Je li moguce zameniti samo filter bez zamene ulja? Link to post Share on other sites
hermes 0 Posted March 19, 2009 Report Share Posted March 19, 2009 pa naravno Link to post Share on other sites
