ernest 0 Posted August 30, 2009 Report Share Posted August 30, 2009 Kao vlasnik slicnog....mogu da kazem: Svaka čast ! Link to post Share on other sites
srki 320is 0 Posted August 30, 2009 Author Report Share Posted August 30, 2009 HVALA momci, bice to jos bolje ... Zimus ga radim kompletno a na prolece NOV AUTO...... Link to post Share on other sites
Mr.BMW 0 Posted August 30, 2009 Report Share Posted August 30, 2009 Svaka ti cast,prelep je! Link to post Share on other sites
bmw2002 0 Posted August 30, 2009 Report Share Posted August 30, 2009 Sve je super osim felgi. Ja bih mu stavio BBS mrezasti. Ove sto imas dave ga malo. Link to post Share on other sites
srki 320is 0 Posted August 30, 2009 Author Report Share Posted August 30, 2009 I ja bih BBS RS ali sledeca faza kad budem menjao glavcine ide na 5 rupa pa onda i one . Link to post Share on other sites
donalbertoBMW 0 Posted August 31, 2009 Report Share Posted August 31, 2009 e onda bi mogao da mi prodaš te BORBET A ? Link to post Share on other sites
srki 320is 0 Posted August 31, 2009 Author Report Share Posted August 31, 2009 Kad budu na prodaju, okacicu ih na forum pa ces znati , nesekiraj!!!!! Link to post Share on other sites
srki 320is 0 Posted September 29, 2009 Author Report Share Posted September 29, 2009 Evo svezih slika pale nove felge RH CUP 7.5 x16 i 9x16 E da one stare BORBET A su sad na prodaju 7.5x16 sve cetri :) Link to post Share on other sites
Ljilja 0 Posted September 29, 2009 Report Share Posted September 29, 2009 FAVORIT u finalnom glasanju za najlepsi auto.... :( Imas jednog jaakog konkurenta... Link to post Share on other sites
srki 320is 0 Posted January 28, 2010 Author Report Share Posted January 28, 2010 Evo slika trenutnog stanja , kompletno rasturen i krenula restauracija. Trenutno limar radi na njemu , enterijer (sedista i tapacirunzi ) sredjeni . polako se nabavljaju stvari za zamenu od mehanike i motorne grupe ,pa polako do proleca ce biti gotov. A evo malo slika i sedista: toliko za sada ....... :huh: Link to post Share on other sites
leon63 0 Posted January 28, 2010 Report Share Posted January 28, 2010 Samo napred, kada zavrsis koju fazu, kaci slike da budemo u toku. Boja pretpostavljam da ostaje ista? Link to post Share on other sites
srki 320is 0 Posted January 28, 2010 Author Report Share Posted January 28, 2010 Bice slika kao idu radovi , a boju menjam mislim da ce ici neka bela samo jos nisam odlucio koja ...videcemo da izgleada kao recimo ovaj... Link to post Share on other sites
leon63 0 Posted January 28, 2010 Report Share Posted January 28, 2010 Bolesno lepo.... Link to post Share on other sites
Miki s38 0 Posted January 28, 2010 Report Share Posted January 28, 2010 Svaka cast druze,puno srece ti zelim,i naravno usput da nas obavestavas Link to post Share on other sites
djoleM3 0 Posted January 28, 2010 Report Share Posted January 28, 2010 Two-door (ECE, LHD): 2,542* produced from 03/88 through 11/90 (*includes one pre-production example produced 11/87) Znaci 2543 auta ikad napravljeno, pravi raritet, a ti si imao srecu da ga nadjes. zasto ti ovo pisem, nemoj mu menjati boju, jer jedino u originalnom stanju moze biti pravi oldtimer jednog dana. Imas u globalu sve delove, samo ga lepo slozi na original i uzivaj u njemu. Poz i Srecno Link to post Share on other sites
leon63 0 Posted January 28, 2010 Report Share Posted January 28, 2010 Pametno Djole zbori, razmisli malo... Link to post Share on other sites
srki 320is 0 Posted January 28, 2010 Author Report Share Posted January 28, 2010 Ovaj model je i u fabrici izlazio u beloj boji , tako da ga necu mnogo oskrnaviti , ali obzirom da mu i rubove sirim , onda prica o oldtajmeru u fabrickom stanju pada u vodu...jbg ... sta cu kad volim siroke tockove :huh: Link to post Share on other sites
GrujaBG 0 Posted January 28, 2010 Report Share Posted January 28, 2010 Auf, ajde boja, al ja ne bih dirao rubove... Link to post Share on other sites
srki 320is 0 Posted January 28, 2010 Author Report Share Posted January 28, 2010 Moram malo da ih ispravim da bih mogao da vozim bez kacenja pozadi felne od 9 J , trebalo bi to ovako da izgleda Link to post Share on other sites
pak76 0 Posted January 28, 2010 Report Share Posted January 28, 2010 Radi mu šta hoćeš i uživaj u njemu, kockica je jako lepa . Link to post Share on other sites
veljasd 0 Posted January 29, 2010 Report Share Posted January 29, 2010 auto je i sad extra,mogu samo da zamislim kakav ce da bude posle.moj stric je imao isti,prodao ga je za neke bedne pare i sad vozi 525 e39 ali kuka za ovim. a sedista iz 320is stoje kod mene u dnevnom boravku,udobnija su od bilo koje fotelje Link to post Share on other sites
TOKYO 0 Posted January 29, 2010 Report Share Posted January 29, 2010 Ooooo..., znaci ima jos ludaka!! :P Ako je cilj da lici na onog belog sa slike, onda samo napred!!! ;) Link to post Share on other sites
///Misic 0 Posted January 29, 2010 Report Share Posted January 29, 2010 Moram malo da ih ispravim da bih mogao da vozim bez kacenja pozadi felne od 9 J , trebalo bi to ovako da izgleda Uvek prvo probaj tuđ točak, ili izračunaj kakvu gumu trebaš da staviš na najširi točak koji imaš i probaj. Ovo na slici ne kači ako je jako tvrd auto i ako ne vozi pozdi nikoga. Ne bi mogao da poverujem da u drugim slučajevima ne bi kačilo. Link to post Share on other sites
srki 320is 0 Posted January 29, 2010 Author Report Share Posted January 29, 2010 @ TOKYO Pa rekao sam ti da ga rasturam i restauriram a to dal sam lud ili ne vreme ce pokazati....ma niko narmalan u ovoj krizi to ne radi znaci sigurno sam lud.....hahahah. @ ///Misic : Imam vec spremne siroke felne sa dosta visokom gumom ( 225-45/16 ) pa prema njima i pravim rubove , a i amortizeri i opruge ukoro stizu tako da ce sve da se proba...nego jel pala cena onom Mtehnik II volanu? ;) ...ili je mozda skocila? Link to post Share on other sites
TOKYO 0 Posted January 29, 2010 Report Share Posted January 29, 2010 Imam samo jednu sugestiju... Nemoj vracati one RH felne..., nisu one za ovaj auto!!! ;) Srce felne je isuvise golfovsko! Link to post Share on other sites
