StunterSM 0 Posted September 19, 2009 Report Share Posted September 19, 2009 I sad koje mi ulje preporucujete da sipam? Motor je 2.0i 150KS Link to post Share on other sites
leon63 0 Posted September 19, 2009 Report Share Posted September 19, 2009 Mobil 10 W 40. Ja sam to uvek sipao u taj motor. Sada i u 2.8 sipam isto. Zamena na 10000 km. Link to post Share on other sites
BMW 528iA 0 Posted September 19, 2009 Report Share Posted September 19, 2009 To je najgore ulja za taj motor. Unjega treba iskljucivo 0-40, a najbolji je Mobil 1 0-40. Link to post Share on other sites
[kick] 0 Posted September 19, 2009 Report Share Posted September 19, 2009 I ja sad treba da menjam ulje i rekli su mi 10w-40 ?!?! Link to post Share on other sites
supersilja 0 Posted September 19, 2009 Report Share Posted September 19, 2009 Ja sipati 5/30 sintetiku i na 1200 cini mi se da nije potrosio nista.Motor je presao 226,7 000km Link to post Share on other sites
BMW 528iA 0 Posted September 20, 2009 Report Share Posted September 20, 2009 I ja sad treba da menjam ulje i rekli su mi 10w-40 ?!?! Ko ti je rekao? Link to post Share on other sites
doktor79 0 Posted September 20, 2009 Report Share Posted September 20, 2009 Kod mene je sad ovo u motoru. MOBIL SUPER 3000 X1 5W-40 API SM/SL/SJ/CF ACEA A3/B3/B4 MB-Approval 229.3 VW 502.00/505.00 BMW Longlife 98 OPEL Diesel Service Fill GM-LL-B-025 Porsche Link to post Share on other sites
BMW 528iA 0 Posted September 20, 2009 Report Share Posted September 20, 2009 To je manje vise OK, osim Amsoila ne postolji bolje ulje od Mobil 1 0-40 za taj motor. Link to post Share on other sites
BMW-E36 0 Posted September 21, 2009 Report Share Posted September 21, 2009 Samo Mobil 1 Ja kod mene sipam 5W 40 Full sintetika i evo gazim 8000km a potrosio je svega 400ml Link to post Share on other sites
gadafi 0 Posted September 21, 2009 Report Share Posted September 21, 2009 svako ulje je dobro dok je novo . moze se sipati od 0-40 do 10 -40w Link to post Share on other sites
BMW-E36 0 Posted September 21, 2009 Report Share Posted September 21, 2009 Za M43,M40 je ovo ulje najbolje zbog sistema podmazivanja bregaste. Link to post Share on other sites
BMW 528iA 0 Posted September 21, 2009 Report Share Posted September 21, 2009 svako ulje je dobro dok je novo . moze se sipati od 0-40 do 10 -40w Ja mislim da nisu u pravu. Link to post Share on other sites
leon63 0 Posted September 21, 2009 Report Share Posted September 21, 2009 Ja zadnjih 5 godina, a sva 4 auta sipam Mobil 10W 40 (da kucnem o drvo nisam imao problema). Uvek uzimam od istog dobavljaca. Zamenu vrsim na 8 do 10 hiljada, mada kazu da moze i 12. Link to post Share on other sites
StunterSM 0 Posted September 22, 2009 Author Report Share Posted September 22, 2009 Ja zadnjih 5 godina, a sva 4 auta sipam Mobil 10W 40 (da kucnem o drvo nisam imao problema). Uvek uzimam od istog dobavljaca. Zamenu vrsim na 8 do 10 hiljada, mada kazu da moze i 12. Pa da, i kod mene je sada to i za 4000km nije ni gram potrosio. Znaci Mobil ostaje. Hvala svima Link to post Share on other sites
BMW 528iA 0 Posted September 22, 2009 Report Share Posted September 22, 2009 Zivo me interesuje kako vam pjevaju ventili kad je motor hladan i za koliko vam se potrosnja veca. Link to post Share on other sites
Djomla 0 Posted September 22, 2009 Report Share Posted September 22, 2009 Link to post Share on other sites
BMW 528iA 0 Posted September 22, 2009 Report Share Posted September 22, 2009 Ovo gore nema nikakve veze sa BMW-ovim motorima. Note that Mobil 1 0w-30, 5w-30, and 10w-30 are NOT ACEA A3 or BMW LL approved oils. This is because they all are thin 30 weight oils (approximately 9.8-10 CST@ 100c) and have HTHS of approximately 3.1. Mobil 1 0w-40 is A3 rated and the Ow-40 is BMW LL-01 approved. For 99% of climates and users 0w-40 or 5w-40 is the appropriate grade. There are some 0w-30 and 5w-30 oils (like the BMW 5w-30) that are forumlated on the heavier end of the 30 weight scale and are accordingly rated A3. These oils will work well also. LOOK FOR THAT ACEA A3 rating. If the oil doesn't have it, pass on it. I vise nemam namjeru da se raspravljam o tome. Sto se mene tice sipajte i vodu. Link to post Share on other sites
gadafi 0 Posted September 22, 2009 Report Share Posted September 22, 2009 druze to je sve marketing :driv_ing: ''BMW LL approved oils'' Link to post Share on other sites
gadafi 0 Posted September 22, 2009 Report Share Posted September 22, 2009 uostalom sve zavisi mislim ako trosi auto ulje treba sipati gušće . Link to post Share on other sites
tanja 0 Posted September 22, 2009 Report Share Posted September 22, 2009 Ovo gore nema nikakve veze sa BMW-ovim motorima. Note that Mobil 1 0w-30, 5w-30, and 10w-30 are NOT ACEA A3 or BMW LL approved oils. This is because they all are thin 30 weight oils (approximately 9.8-10 CST@ 100c) and have HTHS of approximately 3.1. Mobil 1 0w-40 is A3 rated and the Ow-40 is BMW LL-01 approved. For 99% of climates and users 0w-40 or 5w-40 is the appropriate grade. There are some 0w-30 and 5w-30 oils (like the BMW 5w-30) that are forumlated on the heavier end of the 30 weight scale and are accordingly rated A3. These oils will work well also. LOOK FOR THAT ACEA A3 rating. If the oil doesn't have it, pass on it. I vise nemam namjeru da se raspravljam o tome. Sto se mene tice sipajte i vodu. Meni sipaju u Delti na 12000 predjenih kilometara "BMW 5W-30", saznala sam da je Castrol u pitanju. Kompjuter ne pokazuje nikakvu potrosnju. Jedina mana mu je sto mu je cena jaca, oko 1500 din/l, ali zadovokjna sam. Link to post Share on other sites
max_power 0 Posted September 22, 2009 Report Share Posted September 22, 2009 Naravno da si zadovoljna, 1500 dindzi po litru da im dam i da ne budem zadovoljan....neko bi se tu davio u istom..... :driv_ing: ....sala Link to post Share on other sites
BMW 528iA 0 Posted September 23, 2009 Report Share Posted September 23, 2009 uostalom sve zavisi mislim ako trosi auto ulje treba sipati gušće . I kakve veze ima gustoca sa potrosnjom? Recimo motor je OK ali imas los CCV kroz koji ide ulje direktno u usisnu granu. Tu nece ti pomoc ni SAE 90. I to nije nikakv marketing, nego cst wanted. Link to post Share on other sites
BMW 528iA 0 Posted September 23, 2009 Report Share Posted September 23, 2009 Meni sipaju u Delti na 12000 predjenih kilometara "BMW 5W-30", saznala sam da je Castrol u pitanju. Kompjuter ne pokazuje nikakvu potrosnju. Jedina mana mu je sto mu je cena jaca, oko 1500 din/l, ali zadovokjna sam. To je Castrol SLX koji u fabrickom pakovanju ne ispunjava norme BMW-a, tj. 12.2 cst, nego uz pomoc nekih aditiva su stigli do te cifre. To ulje je vise nego OK. Link to post Share on other sites
Bmwloud 0 Posted September 23, 2009 Report Share Posted September 23, 2009 I sta smo rekli,m40-m43 koje ulje je naj i na koliko se vrsi zamena istog? Link to post Share on other sites
