wice 0 Posted July 19, 2017 Report Share Posted July 19, 2017 tesko pali kada je vruc,prevezano je da pali grejace kada je vruc pa lakse pali,citajuci po netu verovatno je rotor pumpe.remont je verovatno preko 500e.sta raditi,da li uzeti polovnu za 150e?intresuje me da li mi neko moze objasniti kako se zupci pumpa?podrazumeva se da skinem granu i cevi,ali kako dalje ,kako se koristi alat za pumpu.i da li ga neko ima na zajam ili crtez sa dimenzijama da bih ga napravio.hvala Link to post Share on other sites
wice 0 Posted July 21, 2017 Author Report Share Posted July 21, 2017 ima li ko id majstora voljan da pomogne? Link to post Share on other sites
Sicko 0 Posted July 21, 2017 Report Share Posted July 21, 2017 Odavno su majstori prestali da posećuju ovaj forum, na žalost... Link to post Share on other sites
wice 0 Posted August 19, 2017 Author Report Share Posted August 19, 2017 izgleda Link to post Share on other sites
wice 0 Posted August 27, 2017 Author Report Share Posted August 27, 2017 una li ko,hocu da kupim pumpu ovih dana pa da ne lutam kako treba,ako neko moze da pomogne.dali je na kajlu,tj da li je samo ubodem ili moram da vodim racuna o necemu Link to post Share on other sites
