bmw e30 drifter 0 Posted January 21, 2010 Report Share Posted January 21, 2010 drifteri optereceni TURBOM ;) 2.4 dizel moze da ima opusteno malo duzi diferencijal od fabrickog, a turbo dizel ce malo da umre u turbo rupi sa duzim diferencijalom, inace ja ne podnosim turbo motore da znas... Link to post Share on other sites
goransremcica 0 Posted January 22, 2010 Author Report Share Posted January 22, 2010 Stavio sam diferencijal 3.25 i nisam dobio nista,ostalo je sve isto... Link to post Share on other sites
bmw e30 drifter 0 Posted January 22, 2010 Report Share Posted January 22, 2010 ako je bio 3.45 a sad 3.25 mora da si dobio makar 200-300 obrtaja minimum... sad imas sledece mogucnosti... da ti menjac nije njegov original i da ti km sat laze sto je cesta pojava... Link to post Share on other sites
goransremcica 0 Posted January 22, 2010 Author Report Share Posted January 22, 2010 Menjac je od e34 524td,ali sve je isto od kada sam promenio menjac,na tom menjacu je bio 3.45,a sada je 3.25 i sve je isto.... Link to post Share on other sites
bmw e30 drifter 0 Posted January 23, 2010 Report Share Posted January 23, 2010 kao sto sam i rekao menjaci od e30 i e34 2.4td nisu isti... prenosi su drugaciji... evo: E34:http://bmwfans.info/parts/catalog/23001220883/ E30:http://bmwfans.info/parts/catalog/23001221131/ petica ima kraci prenos u menjacu... jbg... E34: http://bmwfans.info/parts/catalog/23001220883/ E30: http://bmwfans.info/parts/catalog/23001221131/ Link to post Share on other sites
goransremcica 0 Posted January 23, 2010 Author Report Share Posted January 23, 2010 Pa onda da stavim 2.93,sta predlazete..? Link to post Share on other sites
bmw e30 drifter 0 Posted January 23, 2010 Report Share Posted January 23, 2010 Pa onda da stavim 2.93,sta predlazete..? ako ti se sa ovom sadasnjom kombinacijom NISTA nije promenilo onda ti ni 2.93 nece resiti problem... trazi jos duzi prenos... Link to post Share on other sites
goransremcica 0 Posted January 23, 2010 Author Report Share Posted January 23, 2010 Koji diferencijal je isao na e34 524td..? Link to post Share on other sites
cabrio 0 Posted January 23, 2010 Report Share Posted January 23, 2010 Koji diferencijal je isao na e34 524td..? 3.25 sam skinuo sa e34 ali drugo je petica zbog razlike u tezini u odnosu na kocku a sto se tice 2.93 ako hoces javi jer ode u ponedeljak ako ti neces Link to post Share on other sites
goransremcica 0 Posted January 23, 2010 Author Report Share Posted January 23, 2010 Sutra stavljam 2.93... Link to post Share on other sites
goransremcica 0 Posted January 24, 2010 Author Report Share Posted January 24, 2010 Trenutno sam odustao od stavljanja 2.93,do daljneg... Link to post Share on other sites
batashole 0 Posted January 24, 2010 Report Share Posted January 24, 2010 Da li moram da trazim diferencijal bas za 324td ili pase od nekog benzinca..? diferencial od 324td i 325e i od m3 je isti Link to post Share on other sites
CasperBg82 0 Posted March 15, 2013 Report Share Posted March 15, 2013 Da ne otvaram novu temu :) zna li neko ima li i gde da se kupi puni silen blok za diferencijal od E30? Ili neki drugi da odgovara po dimenzijama a da je malo cvrsci, rekao bih da se ovaj od kocke nekako brzo "razloka" Link to post Share on other sites
bokibmw 0 Posted March 15, 2013 Report Share Posted March 15, 2013 324td je 3.45 i ja imam jedan Link to post Share on other sites
CasperBg82 0 Posted April 1, 2013 Report Share Posted April 1, 2013 Da ne otvaram novu temu :) zna li neko ima li i gde da se kupi puni silen blok za diferencijal od E30? Ili neki drugi da odgovara po dimenzijama a da je malo cvrsci, rekao bih da se ovaj od kocke nekako brzo "razloka" Niko nista? A da napravim od plastike, naravno metalnu cauru pa izmedju plastika, kako bi se to ponasalo? Ovako nesto Link to post Share on other sites
325ixA 0 Posted April 1, 2013 Report Share Posted April 1, 2013 poliuretan i udri. dobro je to ali prenosi vibracije i nije bas za svaki dan. uzmes sipku poliuretana precnika koji ti odgovara, premeris originalan busing i napravis kod strugara drugi. ja cu probati isto ali sa tvrdom, vulkanizovanom gumom. Link to post Share on other sites
vlada_v6 0 Posted April 1, 2013 Report Share Posted April 1, 2013 probao bas na kocki na diferencijalu i sjebe se diferencijal jako brzo, pojeli se lezajevi unutra, eh sada da li je zbog vec potrosenog diff-a ili nesto trece nemam pojma, samo znam da je malo uticalo, nema nista lose u fabrickom veruj mi, jer ovim ne postizes nista Link to post Share on other sites
CasperBg82 0 Posted April 1, 2013 Report Share Posted April 1, 2013 Razmislicu jos malo, ali posalji meni jedan od te vulkanizovane gume ;) A bolja je guma kad se lije, ne znam kako ce se ponasati kad je obradis na strugu Link to post Share on other sites
vlada_v6 0 Posted April 2, 2013 Report Share Posted April 2, 2013 ostalo mi je tog propilen f70mm ili kako se vec zove, ne mogu da se setim dimenzije tog, mogu ti dati, ali kazem ti dosta je kruto i dosta posle lupa, ja sam onda tu popizdeo, otisao i kupio novu original koliko se secam oko 40e i bukvalno ti traje koliko hoces Link to post Share on other sites
CasperBg82 0 Posted April 2, 2013 Report Share Posted April 2, 2013 Nasao sam neki puni silen blok, fali mi samo jedan prsten od 5mm sto treba da napravim i on ce da ide :) Link to post Share on other sites
vlada_v6 0 Posted April 2, 2013 Report Share Posted April 2, 2013 ako je o neka izrada tipa tojovic kg silen blok, onda nece dugo Link to post Share on other sites
CasperBg82 0 Posted April 4, 2013 Report Share Posted April 4, 2013 Opravio :) Link to post Share on other sites
TOKYO 0 Posted April 4, 2013 Report Share Posted April 4, 2013 Polomice poklopac diff-a... Link to post Share on other sites
CasperBg82 0 Posted April 4, 2013 Report Share Posted April 4, 2013 Mislis? Pa ovo crno je guma, ne bi trebalo valjda :huh: Link to post Share on other sites
