M@verickE36 0 Posted July 31, 2010 Report Share Posted July 31, 2010 Skoro mi se pojavilo blago variranje ler gasa na E36 316 M43 motor, jel zna neko sta bi mogao biti uzrok? Takodje, od skoro cujem kao neko zavijanje, zvuk tipa kao kad okrenete volan do kraja i cujete servo pumpu kako zavija, slican zvuk kao taj, dal zna neko sta bi to moglo da bude? Taj zvuk se cuje i u voznji... Link to post Share on other sites
CasperBg82 0 Posted July 31, 2010 Report Share Posted July 31, 2010 Za ler gas imas u Uradi sam neka uputstva, pa pogledaj :D Link to post Share on other sites
CasperBg82 0 Posted July 31, 2010 Report Share Posted July 31, 2010 PS - Jos nisi predstavio automobil? :D Link to post Share on other sites
M@verickE36 0 Posted August 1, 2010 Author Report Share Posted August 1, 2010 Joj da, zaboravio totalno! ;) Nisam imao cime da ga slikam, tek pre neki dan sam dosao do fotoaparata pa cu postaviti neke slicice :D Link to post Share on other sites
sladjanbekonja 0 Posted August 2, 2010 Report Share Posted August 2, 2010 isti problem i kod mena al samo po nekad dal moze biti uzrok gorivo loseg kvaliteta posto na gasu na varira? il je nesto drugo zna neko? Link to post Share on other sites
M@verickE36 0 Posted August 2, 2010 Author Report Share Posted August 2, 2010 E isto i kod mene, samo po nekad, ne uvek. Ne znam, moguce da je lose gorivo pa mu tako po nekad nadodje. A u voznji ekstra, ne primecujem nista sporno... Mada, moze biti i nesto drugo. Ima li ideju neko? Mozda protokomer da se ocisti? Link to post Share on other sites
CasperBg82 0 Posted August 2, 2010 Report Share Posted August 2, 2010 http://www.bmwclubserbia.com/forum/index.php?showtopic=10312 http://www.bmwclubserbia.com/forum/index.php?showtopic=2410 Link to post Share on other sites
sladjanbekonja 0 Posted August 3, 2010 Report Share Posted August 3, 2010 ovo sam i ja nasao na netu samo me interesuje prilikom rasturanja jel imaju nekakve gumice koje mogu da se ostete da mi posle ne vuče fals vazduh.hvala m43 ja motor Link to post Share on other sites
M@verickE36 0 Posted August 3, 2010 Author Report Share Posted August 3, 2010 Da, meni ono podbadanje noza medju onu gumu na protokomeru deluje malo surovo, sta ako se osteti? Link to post Share on other sites
sladjanbekonja 0 Posted August 16, 2010 Report Share Posted August 16, 2010 jel zna neko jel ovo blago variranje moze da prouzrokuje jos nesto osim liber lauf( icv )ventila. Link to post Share on other sites
sladjanbekonja 0 Posted August 31, 2010 Report Share Posted August 31, 2010 PROBLEM SA VARIRANJEM RESEN CISCENJEM ICVa.OCISCENO SVE AXSELOM(sretstvo za odmascivanje)potom oprano vodom i DOBRO OSUSENO ispskano malo VDom.motor radi kao doksa.hvala svima na informacijama!!! Link to post Share on other sites
GrujaBG 0 Posted August 31, 2010 Report Share Posted August 31, 2010 Kako ti se manifestovalo? Ja imam isti problem na istom autu ali nekako sumnjam na senzor temperature :rolleyes: Meni dok ne izadje iz plavog padaju obrtaji, nemirno radi i oseca se gorivo na auspuhu... Cim izadje iz plavog radi ko nov. Jel tako bilo i tebi? Link to post Share on other sites
sladjanbekonja 0 Posted September 1, 2010 Report Share Posted September 1, 2010 kad ga upalim tada je najvisa varirao posle se malo smiri al i dalje varira to se desavalo i kada je zagrejan na radnu temperaturu a nisam osetio miris benzina.probaj da ocistis ICV i sva ona creva nije tesko ako se malo razumes i ako si pazljiv a nista te ne kosta.pa ako ne resis proble onda zameni senzor.moj savet Link to post Share on other sites
GrujaBG 0 Posted September 1, 2010 Report Share Posted September 1, 2010 Tim redom se i radi, a senzor mogu i da proverim :rolleyes: Link to post Share on other sites
