Formulica 0 Posted February 19, 2012 Report Share Posted February 19, 2012 ljudi mislim da mi je na ovim minusima puko blok motora ,kako to da proverim ,primetio sam da mi curi neka tecnost negde iznad alternatora ali sa prednje strane bloka ,auto normalno pali radi ,lepo vuce i na benz i na plin ,u pitanju je E30 318 m40 ,pomozite ako je neko imao slican problem!!! Link to post Share on other sites
SLOBOMIHA 0 Posted February 19, 2012 Report Share Posted February 19, 2012 proveri dati nije procurela pumpa za vodu Link to post Share on other sites
Formulica 0 Posted February 19, 2012 Author Report Share Posted February 19, 2012 pa da odem do majstora sutra pa da vidimo ,hvala na savetu Link to post Share on other sites
Formulica 0 Posted February 19, 2012 Author Report Share Posted February 19, 2012 ima antifriz ali kad su bili oni jaki minusi nisam nesto siguran da ga je bilo dovoljno a sad cim je popustila ova zima krenulo to da mi curi, aj idem na ovaj drugi forum da vidim sta ce reci ,hvala jos jednom Link to post Share on other sites
Formulica 0 Posted February 19, 2012 Author Report Share Posted February 19, 2012 pre svega zdravo svima ja sam Sale Formulica iz Jagodine i sad sam prvi put na ovom forumu, imam problem sa autom mislim da mi je puko blok motora na ovim jakim minusima pocela je da mi curi neka tecnost iznad alternatora ali na prednjoj strani bloka,kako da proverim to , u pitanju je E30 318 m40, auto pali normalno lepo radi i vuce kako na plinu tako i na benzinu, neznam sta jos da vam napisem osim pomozite !!! Link to post Share on other sites
Sasquatch 0 Posted February 19, 2012 Report Share Posted February 19, 2012 Cao Sale, Jel moze neka slika? Koja tecnost? Ulje, voda, mesavina ulja i vode (bele sivkaste boje)? Jel si proverio ulje, jel cisto ili ima nesto u ulju? Ako je blok u pitanje, ne bi potrosio neke pare na m40, naj lakse je zameniti (m40 nije nesto skup) pozdrav Link to post Share on other sites
Sasquatch 0 Posted February 19, 2012 Report Share Posted February 19, 2012 Da dodam, http://realoem.com/bmw/showparts.do?model=AF51&mospid=47254&btnr=11_4335&hg=11&fg=35 Moze biti crevo ili nesto vezano za rasladni sistem. pozdrav Link to post Share on other sites
CasperBg82 0 Posted February 19, 2012 Report Share Posted February 19, 2012 Otisla je vodena pumpa verovatno.. Link to post Share on other sites
Formulica 0 Posted February 19, 2012 Author Report Share Posted February 19, 2012 pozz sasquatch,nisam siguran sta je u pitanju da li je voda ili ulje probao sam da slikam nepristupacno je totalno nista se ne vidi, proverio sam ulje izgleda cisto Link to post Share on other sites
Sasquatch 0 Posted February 19, 2012 Report Share Posted February 19, 2012 Jel dize temperaturu kad ostane u ler? Ako nisi pokusao to da vidis ako predje pola gasi auto. Pozdrav Link to post Share on other sites
Formulica 0 Posted February 19, 2012 Author Report Share Posted February 19, 2012 za creva bi mogo da kazem da su suva bar ova oko kojih se javlja to curenje, Link to post Share on other sites
Formulica 0 Posted February 19, 2012 Author Report Share Posted February 19, 2012 ma temperaturu prebaci malo iznad plave crte kazi ga do sledeca jedva stigne ,nisam imao frke sa tim ,auto lepo mirno radi na ler kad izadje iz plave Link to post Share on other sites
Formulica 0 Posted February 19, 2012 Author Report Share Posted February 19, 2012 a da zamalo da zaboravim ,grejanje nema nista to je verovatno crko termostat zar ne, posto mi ventilator u kabini radi noramlno na sve 4 brzine Link to post Share on other sites
Sasquatch 0 Posted February 19, 2012 Report Share Posted February 19, 2012 Neznam koliko imas osveljenja, ali samo sto ti izgleda suvo ne znaci na nisu napukla. Vise mi lici kao da je u pitanje razhladni sistem. A kao sto Casper kaze, moze lako biti pumpa. U odnosu da je ulje cisto ne verujem da je puko blok. Jel mozes mi reci kada si primetio da curi nesto? pozdrav Link to post Share on other sites
Formulica 0 Posted February 19, 2012 Author Report Share Posted February 19, 2012 pa pre jedno 3 dana taman kad je popustio ovaj minus ,bem mu minus,imam svetlo u garazi ali je to deo ispod creva za vodu sto ide iz motora u hladnjak( ono gornje crevo ) pa ne mogu da pridjem aparatom da slikam jbg a daj boze da je samo rashladni sistem u pitanju to se lako resi ako je blok gurnucu ga u reku :) Link to post Share on other sites
Sasquatch 0 Posted February 19, 2012 Report Share Posted February 19, 2012 Jel moze da se ugreje motor? Imas li vodu/antifriz u sistemu? jel prestalo da greje u istom trenutku kada si primetio da curi? Kad si zadnji put menjao, proverio stanje vode/antifriza u kolima? pozdrav Link to post Share on other sites
SLOBOMIHA 0 Posted February 19, 2012 Report Share Posted February 19, 2012 ja ti rekoh proveri pumpu za vodu a ti kako hoces Link to post Share on other sites
Sasquatch 0 Posted February 19, 2012 Report Share Posted February 19, 2012 kad pukne bolk ili kada se iskrivi glava to se primeti, tako sto gubis kompresiju tj snagu. Sto ne stavis papir ili karton ispod motora, pa kad to izcuri mozes od prilike da vidis odakle i sta tacnije curi iz motora. Pozdrav Link to post Share on other sites
Formulica 0 Posted February 19, 2012 Author Report Share Posted February 19, 2012 slikao sam nesto sad cu da probam da ubacim slike , antifriz sam imao ali kad je bio onaj jak minus nisam siguran da ga je bilo dovoljno ,grejanje nema jos od letos, antifriz i vodu proveravam stalno to ima ,jbm li ga sta je Link to post Share on other sites
Formulica 0 Posted February 19, 2012 Author Report Share Posted February 19, 2012 e aj mi daj email da ti pustim slike ne mogu da se snadjem ovde bas najbolje Link to post Share on other sites
Sasquatch 0 Posted February 19, 2012 Report Share Posted February 19, 2012 Poslao sam ti Private Message, ali mozes da napravis nalog za image shack http://imageshack.us/ uploadujes ili nakacis slike, pa da ovde postavis link za forum (daje ti taj sajt opciju kada nakacis sliku). Pametnije da vise ljudi vide o cemu je rec. pozdrav Link to post Share on other sites
Formulica 0 Posted February 19, 2012 Author Report Share Posted February 19, 2012 http://imageshack.us/f/21/dsc00016resizes.jpg/ Link to post Share on other sites
Formulica 0 Posted February 19, 2012 Author Report Share Posted February 19, 2012 jbt konacno ,evo jedna slika nadam se da ce pomoci Link to post Share on other sites
Sasquatch 0 Posted February 19, 2012 Report Share Posted February 19, 2012 Eto, koliko mogu da vidim to je voda/antifriz. Proveri gde curi i vidi da sredis. Pozdrav Link to post Share on other sites
Formulica 0 Posted February 19, 2012 Author Report Share Posted February 19, 2012 nema druge sutra kod majstora ranom zorom :D Link to post Share on other sites
