stojevski 0 Posted March 28, 2008 Report Share Posted March 28, 2008 imam bmw 316 odlican auto u odlicnom stanju ali vozio sam ga do juce parkiram ga ispred kuce i uvece da krenem a on ni da cuje da upali,ustanovio sam da ne,ma u opste varnice,ne daje struju,neznam sta da radim i neznam kako to od jednom.pomagaj te!!!!!!!!! :) Link to post Share on other sites
glogi-ns 0 Posted March 28, 2008 Report Share Posted March 28, 2008 pa kreni od akumulatora,probaj na kablove upaliti Link to post Share on other sites
Nidza crveni 0 Posted March 28, 2008 Report Share Posted March 28, 2008 akumulator,alternator,nesto od ta dva jeste Link to post Share on other sites
stojevski 0 Posted March 28, 2008 Author Report Share Posted March 28, 2008 sve je to ok,ali ima farove,vergla normalno sve radi ali varnice nema da je akumulator neznam dali bi radilo i to. Link to post Share on other sites
Vlada88 0 Posted March 28, 2008 Report Share Posted March 28, 2008 Mozda su svecice! Link to post Share on other sites
sone_666 0 Posted March 28, 2008 Report Share Posted March 28, 2008 Pogledaj ti razvodnik sta se desava sa njim i bombinu, u stvari moras da pregledas sve sto je vezano za struju, samo izaberi odakle ces da pocnes Link to post Share on other sites
stojevski 0 Posted March 28, 2008 Author Report Share Posted March 28, 2008 sve sam probao,uopste ne baca varnicu sa bobine ali sam probao i drugu bobinu i opet ne baca a struja dodje do bobine kad dam kontakt.poludecu majke mi!!!!!!!!!!1 Link to post Share on other sites
sone_666 0 Posted March 28, 2008 Report Share Posted March 28, 2008 Pogledaj i sam razvodnik u kakvom je stanju, a mozda su i kablovi losi. Link to post Share on other sites
BMW 528iA 0 Posted March 28, 2008 Report Share Posted March 28, 2008 e30, e36 ili e49? Daj malo infa majku mu... Link to post Share on other sites
stojevski 0 Posted March 28, 2008 Author Report Share Posted March 28, 2008 motor je e30 el.palenje ima 1.6 benzinac,karburator,razvodnik sam zamenio novim juce tako da je to ok. Link to post Share on other sites
MickoBMW 0 Posted March 28, 2008 Report Share Posted March 28, 2008 Motor M10,izvadi ceo razvodnik pogledaj da nije proslajfovao,otkaci konektor i uzmi parce zice,jedan kraj ubaci u konektor na jedan pin, drugim krajem prespajaj drugi pin,simulacija razvodnika,ako ni tada ne baca na bobini onda je do el.paljenja "Telefunken koliko se secam.deo odakle dolazi taj kabli. Link to post Share on other sites
m5lpg 0 Posted March 28, 2008 Report Share Posted March 28, 2008 Prvo dali si proverio dali imas napajanje bobine tj 12 volti na plus konrktoru jer ako ga nema nema ni varnice. uzrok moze da bude alarm, kontakt brava ili rele za paljenje a ako je paljenje elektronsko moguce da komutator ne radi iako ako ipak mislim da je alarm ili kontakt brava ali to lako mozes da proveris pa preveze jednu zicu sa + bombine do akumulatora na + klemu i probaj da zaverglas ( prvo izvuci kabl od bobine i stavi ga blizu mase da bi video dali onda baca varnicu) ako ima varnice eto ti smer sta ces dalje da gledas pozdrav Link to post Share on other sites
