Baja530i 0 Posted June 24, 2017 Report Share Posted June 24, 2017 Imam problem na bmw e34,do juce je sve normalno radilo i odjednom cas hoce cas nece da rade podizaci,centralna,brisaci,siber,sad nece uopste,stavljao sam drugi generalni modul,proverio osigurace ispod sedista i ispod haube sve u redu,sta moze biti problem? Link to post Share on other sites
bobis 0 Posted June 24, 2017 Report Share Posted June 24, 2017 Proveri Fusible link 80A http://www.bmwe34.net/E34main/Maintenance/Electrical/Fusible_link.htm Link to post Share on other sites
Baja530i 0 Posted June 24, 2017 Author Report Share Posted June 24, 2017 Gde se nalazi to na 530i,ne mogu bas da se snadjem na ovom sajtu,jel ovo kod akumulatora ispod zadnjeg sedista? Link to post Share on other sites
Baja530i 0 Posted June 24, 2017 Author Report Share Posted June 24, 2017 Sad sam proveravao pozadi sve osigurace ispod zadnjeg sedista u ni jedan odigurac nema struja kao ni u releje ni module verovatno... Link to post Share on other sites
bobis 0 Posted June 24, 2017 Report Share Posted June 24, 2017 Zato sto se napajaju preko ovog osiguraca od 80A. Ukoliko je akumulator pozadi: http://www.bimmerboard.com/forums/posts/636465 Prethodni link pokazuje Fusible link ispod haube, kada je akumulator napred (slucaj kod mene). Link to post Share on other sites
Baja530i 0 Posted June 24, 2017 Author Report Share Posted June 24, 2017 Sad sam gledao ne mogu da nadjem,kako izgleda taj osigurac? Jel izgoreo? Sta se desava sa njim? Znaci to mora da bude kod akumulatora? Link to post Share on other sites
bobis 0 Posted June 24, 2017 Report Share Posted June 24, 2017 Evo kako izgleda kada se otvori zastitna kutija: Hoce da pukne ceono, pa se ne vidi da je u prekidu, ali struje nema. Link to post Share on other sites
Baja530i 0 Posted June 24, 2017 Author Report Share Posted June 24, 2017 A sta da radim sa njim ako je pukao? I nema struje? Drugi se kupi ili? Ne mogu da nadjem... Link to post Share on other sites
bobis 0 Posted June 24, 2017 Report Share Posted June 24, 2017 Ja sam menjao, ali sam imao rezervni od neke E32. Link to post Share on other sites
Baja530i 0 Posted June 24, 2017 Author Report Share Posted June 24, 2017 Vazii,hvala,moram da potrazim sad gde se nalazi. Link to post Share on other sites
Baja530i 0 Posted June 24, 2017 Author Report Share Posted June 24, 2017 Druže,neizmerno ti hvala,ko zna sta bih sve rasturio bez veze,ovo je bio problem,pukao osigurac 80A,zalemio sam i sve radi bez problema,hvala jos jednom puno! Ostavi mi tvoj broj telefona negde da mogu da te kontaktiram ako mi jos nekad nesto zatreba! Link to post Share on other sites
Baja530i 0 Posted June 25, 2017 Author Report Share Posted June 25, 2017 Druze,da li znas mozda zbog cega mi se gase kratka svetla,vozim 10min i od jednom se ugase i upale se kad ona hoce,kao da se nesto pregreje pa iskljuce i posle kad se ohlade onda se upale,ista stvar sa ksenonima dok sam imao i sad kad sam stavio obicne H1 sijalice,da li znas mozda u cemu je problem? Ne mogu da otvorim poruku koju si mi poslao niti ja tebi mogu privatno da posaljem,ne znam zasto... Link to post Share on other sites
bobis 0 Posted June 25, 2017 Report Share Posted June 25, 2017 Tvoj mail? Link to post Share on other sites
Baja530i 0 Posted June 25, 2017 Author Report Share Posted June 25, 2017 [email protected] Link to post Share on other sites
