salemaki 0 Posted November 6, 2009 Report Share Posted November 6, 2009 528i, e39. Opis problema: brisaci su radili normalno, primetili smo slucajno da kada su na vremenskom onom krenu malo-jednom, dva puta pa obrisu soferku. Opet se vrate na pocetnu poziciju, krenu jedanput, dva puta obrisu celu soferku i vrate s e na pocetnu poziciju... Zatim iako su na vremenskom podeseni, krenu da brisu bez prestanka odjednom i brisu jedno 5-6 puta levo desno i stanu na pola soferke. Morate ili ugasiti auto i iskulirati par minuta (onda rade normalno 20tak, 30 km), ili ugasiti pa krenuti odmah ali onda ce opet raditi isto (obrisati par puta soferku i stati) ili ce biti normalni (nema pravila). Sta bi moglo biti? Link to post Share on other sites
BMW 528iA 0 Posted November 7, 2009 Report Share Posted November 7, 2009 Skini desni filter polena i otvori poklopac ECU-a. Vidjeces crveni relej: Izvadis, otvoris: On ima kontakte unutra koji su korodirani. Treba da ih odvojis i da ih cistis sa vodobrusnim glanc papiraom: Ovo je glavni kontakt: Job done, enjoy: Link to post Share on other sites
Lemi M5 0 Posted November 7, 2009 Report Share Posted November 7, 2009 relej je prilichno zut?! :) Link to post Share on other sites
BMW 528iA 0 Posted November 7, 2009 Report Share Posted November 7, 2009 Moze bit, ja sam daltonista. :) Link to post Share on other sites
salemaki 0 Posted November 7, 2009 Author Report Share Posted November 7, 2009 Ispred suvozaca filter ili ispred vozaca? Link to post Share on other sites
BMW 528iA 0 Posted November 7, 2009 Report Share Posted November 7, 2009 Ako imas LHD onda ispod suvozacevog. Link to post Share on other sites
salemaki 0 Posted November 7, 2009 Author Report Share Posted November 7, 2009 E, pazi ovako: posto sam odradio tj zapoceo sve pre nego ces ti napisati ovo za LHD skinuo sam i jedan i drugi filter klime. E sada, ispod ovog vozacevog imam cantru za ulje za kvacilo kocnice i ne znam sta jos a ispod suvozacevog imam kutiju zasrafljenu onim torex srafovima. Ovde kod vozaca kada sam skinuo filter primetio sam da mi se zapusila rupica koja odvodi vodu i da je motoric od brisaca kao i oni kontakti buxne sta vec do pola u vodi, skoro. Da li je mozda to uzrok, da ne skidam dzabe te srafove da bih dosao do releja, vec da ocistim malo te kontakte, naprskam vd-om ili slicnim sredstvom i da vratim sve na svoje mesto? Rupu sam otpusio i tu se nece vise nakupljati voda. Sta mislis? Link to post Share on other sites
BMW 528iA 0 Posted November 7, 2009 Report Share Posted November 7, 2009 Pa moze bit da je to, ali ja bih ipak provjerio i drugu stranu, mozda i tamo ima vode. Osusi to sve i prskaj sa contact cleaner, Forch ili neki drugi. Link to post Share on other sites
salemaki 0 Posted November 7, 2009 Author Report Share Posted November 7, 2009 Tnx "tata bmw" :))) siguran sam da sam problem vec resio, samo mi niko to nije javio. Sutra prepodne cu odraditi to sve po uputstvu. Link to post Share on other sites
BMW 528iA 0 Posted November 7, 2009 Report Share Posted November 7, 2009 Nema na cemu. Samo pisi sto je bilo. m:) Link to post Share on other sites
salemaki 0 Posted November 8, 2009 Author Report Share Posted November 8, 2009 E jbg, aj mi sada reci sta da skinem i ocistim...nisu iste slike :) Link to post Share on other sites
salemaki 0 Posted November 8, 2009 Author Report Share Posted November 8, 2009 Dobro, dobro, ne ljutite se...slikao sam na brzaka mob. telefonom, nisam razmisljao da sam uzeo pogresan telefon koji pravi malo "jace" slike :) Skapirao sam gresku, sada je ovaj za brisanje. Sorry Link to post Share on other sites
BMW 528iA 0 Posted November 8, 2009 Report Share Posted November 8, 2009 Dajes kontakt, upalis brisace, skines releje jedan po jedan i tako ces otkrit koji je za brisace. Link to post Share on other sites
salemaki 0 Posted November 8, 2009 Author Report Share Posted November 8, 2009 Nema na cemu.Samo pisi sto je bilo. m:) Sta sta je bilo, ne kapiram? Jesam li ja imao neki problem bese sa brisacima :):):) TNX sto bi moja deca rekla, do neba i nazad :) Link to post Share on other sites
