bobans1983 0 Posted September 12, 2010 Report Share Posted September 12, 2010 danas sam primetio da pokazivac temperature ne mrda koliko god da se vozikam on "lezi" na plavom,doduse i ne ugreje se motor mnogo ali cini mi se na staroj kad dam kontakt da ona mrdne bar malo. Odakle da pocnem gde da gledam , jel moze da je osigurac neki ili ? Link to post Share on other sites
leon63 0 Posted September 12, 2010 Report Share Posted September 12, 2010 Kada imam problema sa elektronikom, ja bar uvek krecem od osiguraca. Ali iskljucivo proveravam sa prob lampom. P.S. Jednom sam imao veliki problem, jer nisam video da je osigurac pregoreo ( mislio sam da je OK). Izgubio sam dva popodneva pregledajuci celu instalaciju. Link to post Share on other sites
bobans1983 0 Posted September 12, 2010 Author Report Share Posted September 12, 2010 nisu osiguraci i nisu konektori na tabli :) Link to post Share on other sites
max_power 0 Posted September 12, 2010 Report Share Posted September 12, 2010 Termo davac, instalacija od termodavaca. To ti je uvek prvi korak, drugi sama skala u inst. tabli. Link to post Share on other sites
wice 0 Posted September 12, 2010 Report Share Posted September 12, 2010 otkacis kabl sa davaca i spojis ga na masu,das kontakt i ukoliko se skala pomeri do crvenog onda je do davaca,a ako se nista ne desi onda je neki problem na pokazivacu verovatno,nego dali se kazaljka pomeri bar malo kada se motor zagreje? Link to post Share on other sites
majstorbob80 0 Posted September 12, 2010 Report Share Posted September 12, 2010 Bas tako Link to post Share on other sites
bobans1983 0 Posted September 12, 2010 Author Report Share Posted September 12, 2010 gde da nadjem taj termo davac? Link to post Share on other sites
majstorbob80 0 Posted September 12, 2010 Report Share Posted September 12, 2010 Koliko se secam na glavi motora iza regulatora pritiska goriva,malo se teze vidi. Link to post Share on other sites
bobans1983 0 Posted September 13, 2010 Author Report Share Posted September 13, 2010 ne znam na ovom motoru nista gde se nalazi,.kako izgleda ? Ako neko ima slku pa da obelezi ne bilo mu tesko Link to post Share on other sites
CasperBg82 0 Posted September 13, 2010 Report Share Posted September 13, 2010 http://bmwfans.info/parts/catalog/E30/4-do...mostat_housing/ Link to post Share on other sites
bobans1983 0 Posted September 13, 2010 Author Report Share Posted September 13, 2010 Hvala,vidim pa javim Link to post Share on other sites
bobans1983 0 Posted September 14, 2010 Author Report Share Posted September 14, 2010 Ma jok ja ne vidim nista slicno aj slikam pa nek neko obelezi otprilike da bar znam gde da gledam Link to post Share on other sites
bobans1983 0 Posted September 23, 2010 Author Report Share Posted September 23, 2010 Nasao ,ali imam problem. Samo jedna zica na jednom konektoru ovo sto ima dva pipka meni samo jedan,i samo jedna zica ide unutra . Link to post Share on other sites
