Strale 0 Posted October 20, 2011 Report Share Posted October 20, 2011 pozzz imam problem sa paljenjem ujutro u pitanju je bmw e30 324td prilikom paljenja grejac nece da mi odradi tj da ugreje pa dugo vergla dok ne sastavi a cim je motor vruc grejaci odrade upali na zub... pa bih vas zamolio ako mozete da mi pomognete unapred hvala... Link to post Share on other sites
marudza 0 Posted October 20, 2011 Report Share Posted October 20, 2011 pa ja mislim da treba da popravis grejace,a ti? :) Link to post Share on other sites
Bmw-manijakkk 0 Posted October 20, 2011 Report Share Posted October 20, 2011 provereni su grejaci i ok su,nesto drugo je u pitanju... :rolleyes: Link to post Share on other sites
Strale 0 Posted October 21, 2011 Author Report Share Posted October 21, 2011 grejaci su ok. da nije vremenski relej mozda??? Link to post Share on other sites
BMW 528iA 0 Posted October 24, 2011 Report Share Posted October 24, 2011 Relej/sklopka... Da li ti pali lampicu? Ako pali lampicu, koliko ona ostaje upaljena? Link to post Share on other sites
Strale 0 Posted November 28, 2011 Author Report Share Posted November 28, 2011 na prvom paljenju jako dugo najduze sam cekao 3 min i nije se ugasila grejaci izmenjani sad dal je opet neki riknuo ne znam ali upali i na minus 7 neki dan isto tako upalio malo verglao i upalio grejem ga 2 puta po 15 sekundi i palim... a kada je vruc odradi grejac i pali... ne znam sta moze da bude pa ako neko moze da pomogne hvala Link to post Share on other sites
vranjin 0 Posted November 28, 2011 Report Share Posted November 28, 2011 Tri minuta je jako dugo. Jesi li gledao da li dobijas struju na grejace? Ako dobijas onda ti ne valjaju grejaci. Link to post Share on other sites
goransremcica 0 Posted November 28, 2011 Report Share Posted November 28, 2011 Kada je prvo paljenje pali se zuta lampica,pa zelena i onda palis,kada je zagrejan pali se samo zelena,ako ti lampice nisu u funkciji onda najbolji nacin da znas kada ti gasi grejace je da slusas kada ce da cakne relej grejaca... Link to post Share on other sites
Strale 0 Posted December 1, 2011 Author Report Share Posted December 1, 2011 grejaci zamenjeni ispravni dobijaju struju ja sumnjam na vremenski relej i lampice su u funkciji ali na prvom paljenju nece da odradi grejac niti da se cuje CAK posle kada se motor zagreje radi samo zelena lampica cak se cuje i pali kao lud. mada i bez grejenja on pali kao lud par puta zavergla i upali... problem je samo prvo paljenje nece relej da odradi sta moye biti ne znam :blink: Link to post Share on other sites
max_power 0 Posted December 1, 2011 Report Share Posted December 1, 2011 Proveri na njemu, imas ona dva dzeka, prvo proveri kontakte na njima, proveri glavnu struju do automata, otvori ga, pogledaj unutra kakav je, da nije uvukao vlagu, da nisu zapekle one ploce, to je kao relej unutra bimetali....to mozes sve sam, a onda krenu dalje.... Link to post Share on other sites
vranjin 0 Posted December 1, 2011 Report Share Posted December 1, 2011 Ako dobijas struju na grejace(koji su novi) ne vidim problem u tom delu. Kad das kontakt dok gori zuta lampica treba da imas struju na grejace. Ti rece da imas struju na grejacima, znaci da greju. U kakvom su stanju akumulator i motor? Popuni profil, odakle si. Mozda ti je neko u blizinio pa da ti pomogne. pozz Link to post Share on other sites
Strale 0 Posted December 2, 2011 Author Report Share Posted December 2, 2011 motor je extra prosle zime na minus 26 koliko je bilo ispravan relej taj bio palio je bez verglanja znaci odradio grejac i upalio akumulator isto dobar... ja sam iz sivca vojvodina mesto u blizini sombora Link to post Share on other sites
Strale 0 Posted December 2, 2011 Author Report Share Posted December 2, 2011 onda mi ostaje to sutra da pogledam pa da znam sta cu dalje :e30: Link to post Share on other sites
goransremcica 0 Posted December 2, 2011 Report Share Posted December 2, 2011 Najjednostavnije ispitivanje vremenskog intervala grejaca je da neko sedi u autu,da kontakt,ti stavis ispitivac na zicu od nekog grejaca i kada se ugasu lampica od ispitivaca,tada ti je relej ugasio grejace... Link to post Share on other sites
Strale 0 Posted December 22, 2011 Author Report Share Posted December 22, 2011 problem resen zamenjen vremenski relej :e30: :e30: :e30: :e30: :e30: :e30: hvala svima u svakom slucaju :preved: Link to post Share on other sites
