daca357 0 Posted January 14, 2012 Report Share Posted January 14, 2012 Dali je izvodljivo naknadno ,,ubaciti ,, bord u automobilu koji nije imao, i sta je sve potrebno da se tako nesto izvede ,znam za rucicu zmigavca da treba da ima onaj taster ali dali treba jos nesto . Link to post Share on other sites
daca357 0 Posted January 14, 2012 Author Report Share Posted January 14, 2012 Uploaded with ImageShack.us Link to post Share on other sites
ntesic 0 Posted February 29, 2012 Report Share Posted February 29, 2012 Jesi li narucio ovo? Ja isto ovo trazim, nemam board. Link to post Share on other sites
leon63 0 Posted March 1, 2012 Report Share Posted March 1, 2012 Kupi to sa slike (rucicu), zameni i sve ce da ti radi. Link to post Share on other sites
ntesic 0 Posted March 1, 2012 Report Share Posted March 1, 2012 Kupi to sa slike (rucicu), zameni i sve ce da ti radi. Gde bi mogo da kupim to, a da nije preko neta (zbog carine)? Link to post Share on other sites
ntesic 0 Posted March 9, 2012 Report Share Posted March 9, 2012 Uploaded with ImageShack.us Gde se moze naci ovaj uredjaj da se kupi? Link to post Share on other sites
brkabl 0 Posted March 10, 2012 Report Share Posted March 10, 2012 potrebna je rucica i sensor temerature koji ide kod levog tocka rucica je ovde 100 KM ili ti 50 eura Link to post Share on other sites
ntesic 0 Posted March 10, 2012 Report Share Posted March 10, 2012 Senzor mislim da imam ugradjen, posto kada je bio zakacen na dijagnostici, pokazivao je spoljasnju temperaturu. E sada, jel je moguce od nekog polovnjaka uzeti samo rucicu i namestiti je na principu plug and play ili je potreban kompletan retrofit kit? Link to post Share on other sites
leon63 0 Posted March 10, 2012 Report Share Posted March 10, 2012 Ako hoces rucicu javi mi se, mogu dati je nabavim. Link to post Share on other sites
ntesic 0 Posted March 11, 2012 Report Share Posted March 11, 2012 Ako hoces rucicu javi mi se, mogu dati je nabavim. Poslat email i zahtev za dodavanje na Skype Link to post Share on other sites
pontdom 0 Posted March 11, 2012 Report Share Posted March 11, 2012 Poslat email i zahtev za dodavanje na Skype lepo je to ... ali , pazi -coveku obecanja idu od ruke ! Link to post Share on other sites
FloydM3 0 Posted March 18, 2012 Report Share Posted March 18, 2012 Ako hoces rucicu javi mi se, mogu dati je nabavim. Mozes li i da je ugradis ....? Link to post Share on other sites
leon63 0 Posted March 18, 2012 Report Share Posted March 18, 2012 Danas je ugradjena jedna. Kolegi sa foruma. Link to post Share on other sites
ntesic 0 Posted March 18, 2012 Report Share Posted March 18, 2012 Pozdrav za tebe leon. I hvala na ugradjenoj rucici, sve pohvale Link to post Share on other sites
FloydM3 0 Posted March 18, 2012 Report Share Posted March 18, 2012 Danas je ugradjena jedna. Kolegi sa foruma. Za koliko mozes da mi nabavis i ugradis. ukupno.? Link to post Share on other sites
leon63 0 Posted March 18, 2012 Report Share Posted March 18, 2012 Novu rucicu sam Nikoli sa foruma nabavio za 50 evra i 10 ugradnja. Samo sada nemam novih vise, bice za jedno 15 dana. Link to post Share on other sites
bgsinger 0 Posted March 18, 2012 Report Share Posted March 18, 2012 Ma samo se aktivira na dijagnostici nakon ugradnje i to je to ;) Link to post Share on other sites
petar dioda 0 Posted March 18, 2012 Report Share Posted March 18, 2012 To mi lici pomalo na ablender,da nadogradim pitanje vezano za ECU,da ne otvaram teme,el moze se nabavi ECU univerzalan prazan,da se mapira i da sluzi na bilo koji automobil,imaju EEprom valjda,ovaj da ima RAM read/write,u kolu sa baterijom. ROM je jednom upisiva memorija,EEPROM je pisi/brisi ali sa svetlom,a RAM je pisi/brisi ali zahteva stalno napajanje,ispravite me ako gresim,a FLASH ne zahteva napajanje. ECU kakav ima interfejs za komunikaciju sa senzorima to su A/D i D/A konvertori. Link to post Share on other sites
ntesic 0 Posted March 19, 2012 Report Share Posted March 19, 2012 Ma samo se aktivira na dijagnostici nakon ugradnje i to je to ;) Jel moze sa INPA da se aktivira? Link to post Share on other sites
ntesic 0 Posted March 19, 2012 Report Share Posted March 19, 2012 Da odgovorim sam sebi, moze, uspeo sam nekako. Ako nekome treba pomoc neka posalje PM Link to post Share on other sites
skohajm 0 Posted March 20, 2012 Report Share Posted March 20, 2012 da li moguce ugraditi i aktivirati ovu rucicu na e46 320d 2000god (auto nema obd2, nego 20pin konektor)? Link to post Share on other sites
ntesic 0 Posted March 20, 2012 Report Share Posted March 20, 2012 Mislim da nebi trebalo da ima problema da li je OBD2 ili 20pin, postoje adapteri za 20pinske kontektore Link to post Share on other sites
leon63 0 Posted March 20, 2012 Report Share Posted March 20, 2012 Moze bez problema. Link to post Share on other sites
casper e46 0 Posted June 25, 2012 Report Share Posted June 25, 2012 Zamenio sam ablender moze li mala pomoc oko aktivacije na dijagnostici? Zna li neko sta se jos moze ukljuciti tipa promena signalizacije prilikom otkljucavanja/zakljucavanja,zakljucavanja prilikom kretanja i sl? Link to post Share on other sites
gmax 0 Posted June 25, 2012 Report Share Posted June 25, 2012 mora da se aktivira opcija borda, pored toga mozes da aktiviras dnevna svetla, mozes da aktiviras zakljucavanje pri odredjenoj brzini, ako imas alarm mozes migavce da aktiviras...itd...sve zavisi koliko je raspolozen onaj koji se igra sa diagnostikom.... Link to post Share on other sites
