BojanK 0 Posted January 28, 2014 Report Share Posted January 28, 2014 pozdrav svima. Ako neko moze da mi pomogne ... imam BMW E36 316i 1995g. ugradjen gas, pali na benzin pa kad predje 2000 obrtaja prebaci na plin. e problem je sad nece da upali na benzin i necuje se da radi pumpa od benzina, proverio sam ne dobija struju na pumpu pa ne znam dali je u pitanju neki relej ili osigurac ... ako neko zna ili da mi preporuci nekog majstora ... hvala! in Link to post Share on other sites
777.boban 0 Posted January 28, 2014 Report Share Posted January 28, 2014 Na poklopcu osiguraca imas spisak koji osigurac je za sta,nadji kraftstopfpumpe i proveri ga.Relej pumpe ti je pored kutije osiguraca imas ih 3 nemogu da se setim koji je tacno,mislim da je beli. Link to post Share on other sites
vlada-t 0 Posted January 29, 2014 Report Share Posted January 29, 2014 od ta tri releja, levi je od pumpe,u sredini dme i desno od sonde http://www.google.rs/imgres?client=opera&hs=dxU&sa=X&channel=suggest&tbm=isch&tbnid=3oBm1n_t4r8kBM%3A&imgrefurl=http%3A%2F%2Fwww.bimmerwerkz.com%2Fforum%2F3-series-e36%2F1994-325i-english-fuse-diagram-wanted-74389.html&docid=RrIVL27_piGaQM&imgurl=http%3A%2F%2Fwww.bimmerwerkz.com%2Fforum%2Fattachments%2F3-series-e36%2F29864d1315673496-1994-325i-english-fuse-diagram-wanted-e36-325i-fuse-relay-diagram.jpg&w=2000&h=1100&ei=2eXoUs-dLerEyQPco4DAAw&zoom=1&ved=0CHAQhBwwCg&iact=rc&dur=599&page=1&start=0&ndsp=25 Link to post Share on other sites
BojanK 0 Posted January 29, 2014 Author Report Share Posted January 29, 2014 hvala, ipak je bila pumpa u pitanju. Link to post Share on other sites
