Resetovanje kompjutera E46
  • 4 weeks later...
  • 3 weeks later...
  • Ignition key must be off.
  • Press and hold the trip odometer button in the instrument cluster (left button) and turn the ignition key to the first position.
  • Keep the button pressed for approx. 5 seconds until one of the following words appear in the display: "Oil Change" or "Inspection" with "Reset".
  • Release the reset button and press and hold again the "Reset " begins to flash.
  • While the display is flashing, press the left button briefly to reset the service interval. After the display has shown the new interval, the following will appear: "End SIA".
The system can only be reset again after 10 liters of fuel have been consumed.
Ako imas problema sa prevodom javi pa cu prevesati.
Inace funkcionise, bas probano na e46, 2001.
POZDRAV
Gyle,
hvala ti za ovo, bice korisno naravno, ali ono sto ja trazim nema veze sa tasterima na instrument tabli, nego kljuc ubacis u kontakt bravu, tri puta vrtis do III, pa onda izvadis kljuc, sacekas par sekundi i pritisnes na kljucu dugme za otkljucavanje ne znam koliko puta, i onda se cuje neko caktanje. Posle toga sve radi perfektno, a ako se popale lampice bezveze, onda se posle ovoga ugase...JEste da je ovo napisano s brda, s dola, ali ko zna za ovo - znace da napise kako se to radi tacno...ja to samo po secanju iz servisa
