iZnoGouD 0 Posted September 10, 2016 Report Share Posted September 10, 2016 Ljudi Da li neko zna sta bi moglo da bude u pitanju, auto kada se upali par sekundi dok gori lampica za ulje ima zvuk kao da radi bez ulja jel ima on neki nepovratni ventil za ulje koji neda da se svo ulje slegne? Jel ima neko ideju sta je problem? Link to post Share on other sites
StunterSM 0 Posted September 10, 2016 Report Share Posted September 10, 2016 U kucistu filtera ventil Link to post Share on other sites
iZnoGouD 0 Posted September 10, 2016 Author Report Share Posted September 10, 2016 Jel moze da ze zameni samo taj ventil? Jel moze da bude nesto drugo ili je to jedino? Link to post Share on other sites
Milan Dimke Dimitrijevic 0 Posted September 10, 2016 Report Share Posted September 10, 2016 Mora celo kuciste. I mene zeza to, nabavio sam drugo kuciste ali ima dostaaa posla da se zameni. Moze da bude i hidro spaner ali pre ce biti da je do ventila u kucistu. Jel ti brzo ugasi lampu kad ga upalis 10ak minuta po gasenju? Link to post Share on other sites
iZnoGouD 0 Posted September 10, 2016 Author Report Share Posted September 10, 2016 Koliko si dao za kuciste? Link to post Share on other sites
Milan Dimke Dimitrijevic 0 Posted September 10, 2016 Report Share Posted September 10, 2016 20E cini mi se.. Link to post Share on other sites
StunterSM 0 Posted September 10, 2016 Report Share Posted September 10, 2016 Posao je minimum 50e Link to post Share on other sites
alexandar_bgd 0 Posted September 11, 2016 Report Share Posted September 11, 2016 Istu stvar moram i ja na mom da radim. Stunter će dobiti šećer  Link to post Share on other sites
iZnoGouD 0 Posted September 11, 2016 Author Report Share Posted September 11, 2016 6 minutes ago, alexandar_bgd said: Istu stvar moram i ja na mom da radim. Stunter će dobiti šećer  Izgleda da svi imamo isti problem  Link to post Share on other sites
Milan Dimke Dimitrijevic 0 Posted September 11, 2016 Report Share Posted September 11, 2016 Ja sam jednom imao dobru volju da zamenim, ispustio antifriz, skinuo plastike sa motora, smorio se, sve vratio, ozracio sistem za hladjenje i otisao sa burazerom na vinjak  Ovde mi za ruke traze 5000 i da donesem nove zaptivke za kuciste i hladnjak ulja sto realno za ovakav sex nije mnogo. Sad pitanje je koliko ovakva voznja steti motoru, na stranim forumima je ovo cest problem ali neki tako voze godinama.. Link to post Share on other sites
iZnoGouD 0 Posted September 11, 2016 Author Report Share Posted September 11, 2016 20 hours ago, Milan Dimke Dimitrijevic said: Mora celo kuciste. I mene zeza to, nabavio sam drugo kuciste ali ima dostaaa posla da se zameni. Moze da bude i hidro spaner ali pre ce biti da je do ventila u kucistu. Jel ti brzo ugasi lampu kad ga upalis 10ak minuta po gasenju? Kada odstoji 10 min kada je auto veće paljen i vruc i nakon toga ga upalim, onda to traje dosta krace, kao da za senundu dobije ulje, dok ako je duze stajao onda je isto kao da je hladan traje i po par sekundi. Kako znati da li je u pitanju hidro spaner ili kuciste?  Link to post Share on other sites
Milan Dimke Dimitrijevic 0 Posted September 11, 2016 Report Share Posted September 11, 2016 Da je spaner i na vrucem paljunju bi dugo gasio lampu po mom laickom misljenju. Link to post Share on other sites
iZnoGouD 0 Posted September 30, 2016 Author Report Share Posted September 30, 2016 Kako zasigurno znati da li je hidro spaner ili nepovratni ventil u nosacu motora? Oba posla zahtevaju dosta vremena i novca pa zbog toga pitam Link to post Share on other sites
gagi225 0 Posted September 30, 2016 Report Share Posted September 30, 2016 Prije da je ventil, bar po tom sto si napisao do sad sta ti se desava Sent from my HUAWEI P7-L10 using Tapatalk Link to post Share on other sites
slavisa27 0 Posted October 14, 2016 Report Share Posted October 14, 2016 aj ako rijesis javni mi jer i ja imam isti problem. Link to post Share on other sites
Milan Dimke Dimitrijevic 0 Posted October 14, 2016 Report Share Posted October 14, 2016 Ispade da svi imaju isti problem. Ja menjam za desetak dana pa cu da javim Link to post Share on other sites
StunterSM 0 Posted October 14, 2016 Report Share Posted October 14, 2016 Menjam to cesto sad, odjednom svima riknulo kuciste Link to post Share on other sites
slavisa27 0 Posted October 19, 2016 Report Share Posted October 19, 2016 imam isti problem..Jel se moze samo taj ventil promjeniti ili cijelo kuciste mora? STUNERSM jel ovo po rednim brojem 8 ? http://www.realoem.com/bmw/enUS/showparts?id=AL71-EUR-06-2000-E46-BMW-320d&diagId=11_2104 Link to post Share on other sites
StunterSM 0 Posted October 19, 2016 Report Share Posted October 19, 2016 Mora celo, a to pod 8 je davac. Mora jos par dihtunga novih da se kupi kad se radi Link to post Share on other sites
