gagi225 0 Posted December 8, 2016 Report Share Posted December 8, 2016 Imam problem sa 520i 99 god, malo duze vergla kad pali i ne prima gas, trza u voznji, nekad se ugasi na leru. Cim prebaci na plin radi odlicno bez ikakvih problema. Na benzin radi malo bolje kad je ugrijan ali hladan jedva, zamjenjena pumpa i filter goriva. Sutra ide na dijagnostiku ali da pitam da znam na sta da ciljam. Mislim da su dizne ali nisam siguran Sent from my HUAWEI P7-L10 using Tapatalk Link to post Share on other sites
Dekivozdovac 0 Posted December 8, 2016 Report Share Posted December 8, 2016 Moze da bude i step motor ili katalizator da se zapusio ako ga imas Link to post Share on other sites
gagi225 0 Posted December 8, 2016 Author Report Share Posted December 8, 2016 Kat nemam, a step cu probati ocistiti pa cu vidjeti. Ali da je on zar ne bi zezao i na plin Sent from my HUAWEI P7-L10 using Tapatalk Link to post Share on other sites
Dekivozdovac 0 Posted December 8, 2016 Report Share Posted December 8, 2016 Nemam pojma,ja sam imao iste simptome na mom e46 pa je bio prljav step,nemam plin Link to post Share on other sites
777.boban 0 Posted December 8, 2016 Report Share Posted December 8, 2016 Fals vazduh? Link to post Share on other sites
gagi225 0 Posted December 8, 2016 Author Report Share Posted December 8, 2016 Gdje.. Da probam provjeriti spojeve carb cleanerom Sent from my HUAWEI P7-L10 using Tapatalk Link to post Share on other sites
777.boban 0 Posted December 9, 2016 Report Share Posted December 9, 2016 Kreni redom od kutije filtera do glave,najcesce pucaju creva od protokomera do glave,a moze da s edesi i da je neko crevo spalo,proveri separator ulja,senzor na klapni gasa,zakaci na diagnostiku......nece se samo popraviti Link to post Share on other sites
gagi225 0 Posted December 9, 2016 Author Report Share Posted December 9, 2016 Hvala bobane pravicu to danas, na godisnjem sam pa imam vremena [emoji4] Sent from my HUAWEI P7-L10 using Tapatalk Link to post Share on other sites
gagi225 0 Posted December 12, 2016 Author Report Share Posted December 12, 2016 Pregledao sva crijeva sve uredno, ocistio step motor, dizne ispitane i ociscene. Nisam kacio dijagnostiku crkao laptop od majstora.. Eh sad kako provjeriti separator i senzor na klapni gasa Sent from my HUAWEI P7-L10 using Tapatalk Link to post Share on other sites
777.boban 0 Posted December 13, 2016 Report Share Posted December 13, 2016 senzor bregaste? Link to post Share on other sites
gagi225 0 Posted December 14, 2016 Author Report Share Posted December 14, 2016 Koliko otpor treba biti tacno da izmjerim na poslu, ili da odma trazim drugi Sent from my HUAWEI P7-L10 using Tapatalk Link to post Share on other sites
gagi225 0 Posted December 14, 2016 Author Report Share Posted December 14, 2016 Dijagnostika pokazala Lambda sonda blok 2 I podesavanje ubrizgavanja blok 1 bogata smjesa Da mijenjam obe sonde? Senzor bregaste ispravan Sent from my HUAWEI P7-L10 using Tapatalk Link to post Share on other sites
