ianullrich 0 Posted September 5, 2008 Report Share Posted September 5, 2008 ovako: imam e34 520i sa m50 motorom hteo bi da razbusim blok na 2.5 sta je sve potrebno da se menja osim klipova naravno Link to post Share on other sites
Misko M 0 Posted September 5, 2008 Report Share Posted September 5, 2008 sa vanosom ili bez ? Link to post Share on other sites
ianullrich 0 Posted September 5, 2008 Author Report Share Posted September 5, 2008 bez vanosa je moj motor Link to post Share on other sites
DRAGANCE 0 Posted September 5, 2008 Report Share Posted September 5, 2008 radilica Link to post Share on other sites
BMW KLINIK 0 Posted September 5, 2008 Report Share Posted September 5, 2008 Radilica i klipovi sa klipnjacama protokomer i dizne .To su ti potrebni delovi za najsiromasniju varijantu B) Link to post Share on other sites
Matics 0 Posted September 8, 2008 Report Share Posted September 8, 2008 Koliko je trajno to resenje sa razbusivanjem? Sta je sa ECU? Menja li se i on? Link to post Share on other sites
DRAGANCE 0 Posted September 9, 2008 Report Share Posted September 9, 2008 trajno je koliko hoces , ne menja se ecu Link to post Share on other sites
sone_666 0 Posted October 27, 2008 Report Share Posted October 27, 2008 koliko para izadje ta igrarija i sta se dobije na kraju i da li se to isplati? Link to post Share on other sites
///M8 0 Posted October 27, 2008 Report Share Posted October 27, 2008 A zar nije pametnije da umesto ovih modifikacija lepo nabaviš M50B25 :) :) ? ECU-engine control unit To ti moze biti jeftinija{a i svakako prostija varijanta} :rolleyes: Link to post Share on other sites
Misko M 0 Posted October 27, 2008 Report Share Posted October 27, 2008 ...jeftinija tesko posto je razlika u registraciji skoro 200eu !!! Link to post Share on other sites
Nidza crveni 0 Posted October 27, 2008 Report Share Posted October 27, 2008 Registruje ga na 2.0! Link to post Share on other sites
Misko M 0 Posted October 27, 2008 Report Share Posted October 27, 2008 a sta mislis da radis sa oznakom motora ? sad kad se ukine broj u saobracajnoj uz pomoc te oznake ce se gledati kubikaza i odredjivati cena !!!??? nece moci vise m50b25 da prodje kao 2.0l !!! Link to post Share on other sites
IxINBG 0 Posted October 27, 2008 Report Share Posted October 27, 2008 Pa logicno.... a i ta varijanta je trajna zato sto su to dva ista motora ( m50b20 i m50b25) samo sto m50b25 ima veci precnik cilindra, tako da kad se razbrushi, na 2,5 ne postoji nikakav problem, samo ce jos bolje biti, jel dolaze novi klipovi i radilica.... Link to post Share on other sites
Misko M 0 Posted October 27, 2008 Report Share Posted October 27, 2008 pa tesko da neko kod nas stavlja nove klipove i novu radilicu... ..eventualno novi lezajevi i karike, sve ostalo ide staro, polovno ! Link to post Share on other sites
Dire 0 Posted October 27, 2008 Report Share Posted October 27, 2008 nece moci vise m50b25 da prodje kao 2.0l !!! pa sto nece moci da prodje, pa puna Srbija auta sa smanjenom kubikazom, onaj na tehickom sigurno vidi razliku izmedju b20 i b25. kako da ne. Link to post Share on other sites
IxINBG 0 Posted October 27, 2008 Report Share Posted October 27, 2008 da ali ako stavi nov motor, broj motora se nece poklapati... a ako ga razbrusi onda ok... Link to post Share on other sites
Dire 0 Posted October 27, 2008 Report Share Posted October 27, 2008 ocarini se motor, ode na tehnicki, u sup, novi broj u saobracajnu i ok. a i tako i tako jos malo pa brojeva motora nece ni biti u saobracajnim Link to post Share on other sites
IxINBG 0 Posted October 27, 2008 Report Share Posted October 27, 2008 da ali onda je reg na 2,5 a mi pricamo da bude registrovan na 2,0... Link to post Share on other sites
Dire 0 Posted October 27, 2008 Report Share Posted October 27, 2008 procitaj malo o cemu pisem, pre nego pises, nemogu crtati Link to post Share on other sites
IxINBG 0 Posted October 27, 2008 Report Share Posted October 27, 2008 sine to nece moci vise u svakom slucaju kao sto ti kazes, tako da me ni ne zanima sta ti pises.... Link to post Share on other sites
Bojan76 0 Posted October 27, 2008 Report Share Posted October 27, 2008 pa ako decko ima para za takve zahvate neka radi... samo da mu posle ne bude zao para kad dodju druge stvari na red da se rade... Link to post Share on other sites
sone_666 0 Posted October 28, 2008 Report Share Posted October 28, 2008 Sve je to lepo ali ja na kraju nisam dobio konkretan odgovor, sta se dobija kada se stave samo radilica klipovi klipnjace dizne i protokomer, sta se desava sa glavom motora jer ostaje ista to jest od 2.0 i ECU, da li se dobija 192hp ili manje i sta je sa obrtnim momentom, da li je isti kao kod fabrickog 2.5, i da naravno koliko to zadovoljstvo na kraju kosta? Link to post Share on other sites
///M8 0 Posted October 28, 2008 Report Share Posted October 28, 2008 Sve je to lepo ali ja na kraju nisam dobio konkretan odgovor, sta se dobija kada se stave samo radilica klipovi klipnjace dizne i protokomer, sta se desava sa glavom motora jer ostaje ista to jest od 2.0 i ECU, da li se dobija 192hp ili manje i sta je sa obrtnim momentom, da li je isti kao kod fabrickog 2.5, i da naravno koliko to zadovoljstvo na kraju kosta? ECU se menja {kod B20 ECU - Siemens DME MS41,a kod B25 - Bosch DME M3.1 ili MS41:0 ne mogu da se setim} Sad glava motora :prečnik cilindara kod B20 je 80 x 66 mm,B25 84 x 75 mm. Kompresioni odnos 11:1 za B20 , 10.5:1 za B25.E sad neznam detaljnu konstrukciju B20 motora.,{Nisam imao priliku da proucim :) }ali sudeći po gore navedenim podacima konverzija nije baš pametna.Zato ostajem pri svom stavu da prodaš postojeći i kupiš B25.{jer je glupo trošiti vremena i novca na razvijanju motora koj već postoji iz razloga da bi se uštedeo neki evro tokom registracije auta!} Link to post Share on other sites
///M8 0 Posted October 28, 2008 Report Share Posted October 28, 2008 pa i nije bas neki euro usteda je oko +- 150e Nebitno!! Link to post Share on other sites
sone_666 0 Posted October 28, 2008 Report Share Posted October 28, 2008 imam M50B20 i kod mene je bosch ECU, mene samo zanima sta se na kraju dobije. Link to post Share on other sites
