G-Man 0 Posted January 8, 2009 Report Share Posted January 8, 2009 Dakle 320i '86 godiste... Stao mi je na sred puta,crkla bobina... Moram danas da ga pomerim,neko ce ga dokaci... Moze li da se iskoristi bobina od nekih drugih kola i ako moze od kojih... Link to post Share on other sites
wice 0 Posted January 8, 2009 Report Share Posted January 8, 2009 ako ima jednu bobinu ,a sto nebi moglo,samo gledaj da je od elektronskog paljenja Link to post Share on other sites
BMW 528iA 0 Posted January 8, 2009 Report Share Posted January 8, 2009 Kako znas da je bobina u pitanju? Mozda je crkao osigurac, mozda nemas benzina, mozda ti ne radi pumpa... Link to post Share on other sites
G-Man 0 Posted January 8, 2009 Author Report Share Posted January 8, 2009 Nema varnice. Link to post Share on other sites
G-Man 0 Posted January 8, 2009 Author Report Share Posted January 8, 2009 Jedino osigurace jos nisam proveravao...To cu sutra..Hvala za sugesiju Link to post Share on other sites
BMW 528iA 0 Posted January 8, 2009 Report Share Posted January 8, 2009 Provjeri osigurace a javi. Link to post Share on other sites
error 0 Posted January 8, 2009 Report Share Posted January 8, 2009 kao na primer... osigurach za shta? Link to post Share on other sites
BMW 528iA 0 Posted January 9, 2009 Report Share Posted January 9, 2009 Paljenje. Link to post Share on other sites
Lemi M5 0 Posted January 9, 2009 Report Share Posted January 9, 2009 moze da bude relej.. Link to post Share on other sites
Suki 0 Posted January 9, 2009 Report Share Posted January 9, 2009 mislim da ide preko osiguraca od kontakta,neverujem da ima osigurac samo za to. Moze bombina od bilo kog auta samo da nije od nekog koji ima platinska. Ali retko crkavaju,probaj drugu pa se javi Link to post Share on other sites
batabmw 0 Posted January 9, 2009 Report Share Posted January 9, 2009 bobina moze i od yugica koji ima el.paljenje nisi rekao dali je Motronic ili LE-jetronic mislim na sistem ubrizgavanja i paljenja Link to post Share on other sites
G-Man 0 Posted January 9, 2009 Author Report Share Posted January 9, 2009 K Jettronic Link to post Share on other sites
G-Man 0 Posted January 9, 2009 Author Report Share Posted January 9, 2009 Tj. nije Motronic. Link to post Share on other sites
Suki 0 Posted January 9, 2009 Report Share Posted January 9, 2009 na ovom konektoru proveri ima li napona ako nema nemoj bezveze traziti bombinu Link to post Share on other sites
G-Man 0 Posted January 9, 2009 Author Report Share Posted January 9, 2009 Provericu...A sta ako tu nema struje? Link to post Share on other sites
Suki 0 Posted January 9, 2009 Report Share Posted January 9, 2009 proveri ako nema opecu ti poslati detalje Link to post Share on other sites
G-Man 0 Posted January 9, 2009 Author Report Share Posted January 9, 2009 Vazi,hvala na pomoci.. Link to post Share on other sites
